Hello everyone,
i have seem to be stuck in a very strange situation. I have an Pro Micro and a RFID reader which i am trying to work together. The sketch works since i have uploaded it to a MEGA 2560 and a UNO R3 and it works like it should. It also works with the Pro Micro but only when the port is listening. As soon as i close the port, it stops working. Would someone please shed some light on what might be my issue. I'm new to this and your help is greatly appreciated. Thank you.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 10 // Configurable, see typical pin layout above
#define SS_PIN 2 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
String read_rfid;
String ok_rfid_1 = "xxxxxxxx";
String ok_rfid_2 = "xxxxxxxx";
int access = 0;
int did = 0;
int lockSig = 3; //signal from arduino.
int unlockSig = 4; //signal to arduino.
int RXLED = 17;
pinMode(RXLED, OUTPUT);
pinMode(unlockSig, OUTPUT);
digitalWrite(unlockSig, LOW);
pinMode(lockSig, INPUT);
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
void dump_byte_array(byte *buffer, byte bufferSize) {
read_rfid = "";
for (byte i = 0; i < bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX);
void allow_access() {
access = 1;
did = 1;
void deny_access(){
access = 0;
did = 0;
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
if (read_rfid == ok_rfid_1) {
Serial.println(read_rfid);
Serial.print("What's up?");
allow_access();
if (read_rfid == ok_rfid_2) {
allow_access();
mfrc522.PICC_HaltA();
// else not needed. Anything else is not ok, and will not open the door...
//------------------------------Signal to Arduino loop--------------------------------------
if (access == 1 && did == 1) { //Card was read.
digitalWrite(unlockSig, HIGH);
delay(50);
digitalWrite(RXLED, HIGH); // set the LED off
did = 2;
if (digitalRead(lockSig) == HIGH && did == 2) {
digitalWrite(RXLED, LOW); // set the LED off
deny_access();
