Hope someone can help as a little lost as to what is going on.
So I built a small outside box with a Pro Mini, and NRF2401 2.4Ghz transmitter and a BME280 Temperature/Humidity sensor.
As its a pro mini there is no USB so only have the header pins to connect to, am using a serial to TTL converter to dump the code to the Arduino.
That all works great.
As this is going to be a battery based outside unit, I removed the power led, the voltage regulator and am using the low power library.
When its all powered up using the laptop and the 5 connections, VCC, GND, TX, RX and reset it all works great.
If I remove the laptop and just supply power to VCC and Ground nothing happens, if I reconnect the reset pin , so have VCC, GND and reset connected to the laptop it works again.
Any ideas why I cant get it working with just VCC and GND?
Are you connecting Reset or DTR?
How confident are you that you haven't damaged the board with your desoldering attempts? If the Pro Mini doesn't work with VCC and GND connected (which it should) but does work with VCC, GND and Reset connected then it implies that the reset line is being held low when it isn't connected to the USB-Serial adapter.
Try connecting VCC and GND to the USB-Serial adapter and then measuring the voltage on the Reset pin. What voltage do you get?
Appologies, on closer inspection of the pro mini board its not a reset pin but marked GRN, and if its connected to the Serial TTL adaptor on that board it would be the reset, so I assume its the same on the pro mini.
Its the 3.3v 8Mhz version, and I measured the voltage on the GRN pin with just VCC and GND and the reading is Zero volts
I'm really confused. There's no "reset" pin on the FTDI header of the pro mini, at least not on the schematic I have. Nor is there any GRN pin. There might be a RTS pin on the USB adapter, but that's not reset. In any case, it still ought to work with Vcc and GND.
The 'GRN' pin is the DTR pin. Is that the one that you connect to Reset on the USB-Serial adapter?
The reset signal is explicitly pinned out on the Pro Mini - you could add a delay circuit to this to ensure
correct reset is asserted on power up. Perhaps a MAX803 or similar supply monitor/reset generator?
If you connect only power and ground to a pro mini, or any Arduino, it should boot up and run. It should not be necessary to do a reset. As MarkT said, the Reset pin of the 328 is pinned out on the pro mini, to two pins it looks like, and if you measure the voltage on either of those pins it should be high. It has an external 10k pullup resistor (R2). So I think it's still a mystery.
