Pro Mini Will not Upload, Uno Will, Same USB port
Pro-Mini ATMega328 (5V, 16MHz) on /dev/cu.usbserial-AH00SAY2.
Will not upload Blink.
Error message (verbose): “avrdude: usbdev_open(): did not find any USB device “USB”” (see screen shot, below)
FTDI Drivers installed on Mac Mini 2.8GHz Intel Core i5.
When plugged into USB port, Sparkfun 5V FTDI Breakout Red (TX) and green (RX) are on continuously (no flashing) and Pro-Mini red LED on continuously.
However, upload works for Blink to UNO board on same USB port. Yellow light blinks.
Here is an update. Error messages are much shorter. Drivers appear correctly installed on MAC and PC according to an FTDI US Support Engineer. Nevertheless, I am unable to upload “Blink” to my Pro Mini 386 5V 16MHz board using the SparkFun FTDI Basic Breakout Board. The board, shown below, is set to 5V.
I would appreciate guidance. Thank you.
Arduino uploading error messages on my Mac Mini are:
Arduino 1.6.5 Messages July 9, 2015
Hardware: Mac Mini 2.6GHz Intel Core i5
OS: OSX Ver. 10.10.3
Sketch: Uploading “Blink”
FTDI Driver: D2xx
Compiling Message (3 lines)
Sketch uses 1030 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
/Users/vernludwig/Arduino-v1_6_5.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/ vernludwig/Arduino-v1_6_5.app/ Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-AH00SAY2 -b57600 -D
-Uflash:w:/var/folders/9r/rrmdp1vn7mg9p6zbmg8cspvw0000gn/T/build8757107234764560168.tmp sketch_jul05a.cpp.hex:i “
Upload Message (Verbose - 21 lines)
“avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is “/Users/vernludwig/Arduino-v1_6_5.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf”
User configuration file is “/Users/vernludwig/.avrduderc”
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-AH00SAY2
Using Programmer : arduino
Overriding Baud Rate : 57600avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
avrdude done. Thank you.”
Arduino error messages on my Mini PC notebook are:
Hardware: Asus EeePC 1.66Ghz Intel Atom
OS: Microsoft Windows XP
FTDI Driver:
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v
-patmega328p -carduino -PCOM4 -b57600 -D -Uflash:w:C:\DOCUME -1\VERNEL-1\LOCALS-1\Temp \build1d56363123218336675886.tmp/Blink.cpp.hex:i”
“avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
System wide configuration file is “C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM4
