Pro Tools Crashes Board
Hello there!
I´m new here and not very experienced in programming, so please excuse me for any mistakes.
My problem is with an Adafruit Feather RP2040 board, but maybe someone one here has some good insights, since there is also an Arduino board based on the RP2040. I chose the Adafruit one because of the Native USB with USB C connector basically.
So here is the problem:
i want to make the board control the Audio Software "Pro Tools". But when the software sets up the connection to the board, the board crashes. I know the board freezes beacause i can no longer upload new sketches unless i reset the board and from the blinking LED function. Sometimes it freezes with the LED on, sometimes off.
The board is seen from the computer as a midi device, and other software such as MIDI ox can interact with the board with no problems.
i stripped the code to the minimum possible and it still crashes.
From my research it could have something to do with the MIDI buffer, since Pro Tools dumps a lot of MIDI messages at startup (or begin of the midi connection). As a new user i cannot upload files, so i will paste the LOG of this messages at the end of my post.
Is there a way to know if the buffer overflowed and to prevent this from happening?
I appreciate any help!
here is the code:
#include <Arduino.h>
#include <Adafruit_TinyUSB.h>
#include <MIDI.h>
int led = LED_BUILTIN;
bool led_status = 0;
unsigned long timer_led = 0;
Adafruit_USBD_MIDI usb_midi; // Declare MIDI interface object
MIDI_CREATE_INSTANCE(Adafruit_USBD_MIDI, usb_midi, MIDI); // Create a new instance of the Arduino MIDI Library, and attach usb_midi as the transport.
void blink_led(uint _led_offtime, uint _led_ontime){         // Basic blink function for Board function check
  if (led_status == 0)          // if LED is Turned OFF
    if (micros() - timer_led > _led_offtime * 1000)  // check if elapsed time is greater than led_offtime (Converted to microseconds)
      timer_led = micros();         // Update Timer
      led_status = 1;     // Switch led-Status to 1
      digitalWrite(led,led_status);  // Turn LED on
  else if (micros() - timer_led > _led_ontime * 1000)  // if LED is ON, checks if elapsed time since LED was turned on is greater than led_ontime (Converted to microseconds)
    led_status = 0;     // Switch led-Status to 0
    digitalWrite(led,led_status);  // Turn LED off
  MIDI.begin(MIDI_CHANNEL_OMNI);;   // Setup for midi communication. !! HAS TO BE CALLED BEFORE Serial.begin() !!
  pinMode(led, OUTPUT);
  while (!Serial) {;;}  // wait for serial port to connect. Needed for native USB
  Serial.println("");
  Serial.println("\t\t Serial.ready");
  // Debug
    if (TinyUSBDevice.mounted()) {Serial.println("\t \t MIDI device mounted \t "); };      // check if MIDI Interface was successfully mounted
  Serial.println("");
  blink_led(1000,100);    // Function to blink LED for assessing if CPU is running properly
  MIDI.read();
  // HUI Ping (0x 90 00 00) every second
  static uint32_t ping_timer = 0;
  if (millis() - ping_timer > 1000) {
    ping_timer += 1000;
    MIDI.sendNoteOn(0, 0x7f, 1);
    // Serial.println("ping");
The board also crashes with midi_test.ino example from the library.
Board: Adafruit Feather RP2040
Arduino IDE: 2.0.2
Pro Tools 12HD
Pro Tools MIDI messages at start of MIDI Connection (HUI Protocol):
 ===> MIDI-OX Version: 7.0.2.372
 ===> Log Opened: Tue 16-Jul-2024 00:12:43 ===>
  TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
 0000C7B6   4  --     90    00    00    1  C -1 Note Off
 0000C95C   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 12 00 50 72 6F 20 54 6F 6F 6C 73 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 01 68 61 73 20 61 20 64 69 61 6C
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 02 6F 67 20 6F 6E 73 63 72 65 65
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 03 6E 21 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 04 45 6E 74 65 72 20 3D 20 4F 4B
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 05 2C 20 46 38 2F 45 73 63 20 3D
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 06 20 43 61 6E 63 65 6C 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 07 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 0000C983   4  --     B0    0C    10    1  ---  Control Change
 0000C983   4  --     B0    2C    01    1  ---  Control Change
 0000C983   4  --     B0    2C    04    1  ---  Control Change
 0000C983   4  --     B0    2C    02    1  ---  Control Change
 0000C983   4  --     B0    2C    03    1  ---  Control Change
 0000C983   4  --     F0  Buffer:    16 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 11 20 20 20 20 20 20 20 20 F7
 0000C983   4  --     B0    0C    0E    1  ---  Control Change
 0000C984   4  --     B0    2C    04    1  ---  Control Change
 0000C984   4  --     B0    0C    0E    1  ---  Control Change
 0000C984   4  --     B0    2C    03    1  ---  Control Change
 0000C984   4  --     B0    2C    43    1  ---  Control Change
 0000C984   4  --     B0    2C    05    1  ---  Control Change
 0000C984   4  --     B0    0C    0F    1  ---  Control Change
 0000C984   4  --     B0    2C    02    1  ---  Control Change
 0000C984   4  --     B0    0C    0D    1  ---  Control Change
 0000C984   4  --     B0    0C    08    1  ---  Control Change
 0000C984   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F7
 0000C989   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 0000C989   4  --     B0    0C    08    1  ---  Control Change
 0000C989   4  --     B0    2C    07    1  ---  Control Change
 0000C989   4  --     B0    0C    0C    1  ---  Control Change
 0000C989   4  --     B0    2C    02    1  ---  Control Change
 0000C989   4  --     B0    0C    19    1  ---  Control Change
 0000C989   4  --     B0    2C    03    1  ---  Control Change
 0000C98B   4  --     B0    0C    0F    1  ---  Control Change
 0000C98B   4  --     B0    2C    43    1  ---  Control Change
 0000C991   4  --     B0    0C    0C    1  ---  Control Change
 0000C991   4  --     B0    2C    06    1  ---  Control Change
 0000C991   4  --     B0    0C    0F    1  ---  Control Change
 0000C991   4  --     B0    2C    04    1  ---  Control Change
 0000C992   4  --     B0    0C    16    1  ---  Control Change
 0000C992   4  --     B0    2C    03    1  ---  Control Change
 0000C992   4  --     B0    0C    17    1  ---  Control Change
 0000C992   4  --     B0    2C    42    1  ---  Control Change
 0000C992   4  --     B0    2C    41    1  ---  Control Change
 0000C992   4  --     B0    2C    45    1  ---  Control Change
 0000C992   4  --     B0    2C    44    1  ---  Control Change
 0000C992   4  --     B0    2C    43    1  ---  Control Change
 0000C992   4  --     B0    2C    40    1  ---  Control Change
 0000C992   4  --     F0  Buffer:    13 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 10 00 20 20 20 20 F7
 0000C992   4  --     B0    0C    00    1  ---  Control Change
 0000C993   4  --     B0    2C    05    1  ---  Control Change
 0000C993   4  --     F0  Buffer:    13 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 10 01 20 20 20 20 F7
 0000C993   4  --     B0    0C    01    1  ---  Control Change
 SYSX: F0 00 00 66 05 00 10 02 20 20 20 20 F7
 0000C993   4  --     B0    0C    02    1  ---  Control Change
 SYSX: F0 00 00 66 05 00 10 03 20 20 20 20 F7
 0000C993   4  --     B0    0C    03    1  ---  Control Change
 SYSX: F0 00 00 66 05 00 10 04 20 20 20 20 F7
 0000C993   4  --     B0    0C    04    1  ---  Control Change
 SYSX: F0 00 00 66 05 00 10 05 20 20 20 20 F7
 0000C993   4  --     B0    0C    05    1  ---  Control Change
 0000C994   4  --     B0    2C    05    1  ---  Control Change
 0000C994   4  --     F0  Buffer:    13 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 10 06 20 20 20 20 F7
 0000C994   4  --     B0    0C    06    1  ---  Control Change
 SYSX: F0 00 00 66 05 00 10 07 20 20 20 20 F7
 0000C994   4  --     B0    0C    07    1  ---  Control Change
 0000C994   4  --     B0    0C    19    1  ---  Control Change
 0000C994   4  --     B0    2C    01    1  ---  Control Change
 0000C994   4  --     B0    0C    16    1  ---  Control Change
 0000C994   4  --     B0    2C    00    1  ---  Control Change
 0000C994   4  --     B0    2C    02    1  ---  Control Change
 0000C994   4  --     B0    0C    0C    1  ---  Control Change
 0000C995   4  --     B0    2C    01    1  ---  Control Change
 0000C995   4  --     B0    0C    0C    1  ---  Control Change
 0000C995   4  --     B0    2C    02    1  ---  Control Change
 0000C995   4  --     B0    2C    03    1  ---  Control Change
 0000C995   4  --     B0    2C    04    1  ---  Control Change
 0000C995   4  --     B0    2C    05    1  ---  Control Change
 0000C995   4  --     B0    2C    06    1  ---  Control Change
 0000C995   4  --     F0  Buffer:    13 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 10 08 20 20 20 20 F7
 0000C995   4  --     B0    0C    0B    1  ---  Control Change
 0000C995   4  --     B0    2C    00    1  ---  Control Change
 0000C996   4  --     B0    0C    0B    1  ---  Control Change
 0000C996   4  --     B0    2C    02    1  ---  Control Change
 0000C996   4  --     B0    2C    03    1  ---  Control Change
 0000C996   4  --     B0    2C    04    1  ---  Control Change
 0000C996   4  --     B0    2C    05    1  ---  Control Change
 0000C996   4  --     B0    2C    06    1  ---  Control Change
 0000C996   4  --     B0    2C    07    1  ---  Control Change
 0000C996   4  --     B0    0C    08    1  ---  Control Change
 0000C996   4  --     B0    2C    00    1  ---  Control Change
 0000C996   4  --     B0    2C    01    1  ---  Control Change
 0000C997   4  --     B0    2C    07    1  ---  Control Change
 0000C997   4  --     B0    0C    17    1  ---  Control Change
 0000C997   4  --     B0    2C    00    1  ---  Control Change
 0000C997   4  --     B0    2C    01    1  ---  Control Change
 0000C997   4  --     B0    2C    02    1  ---  Control Change
 0000C997   4  --     B0    2C    03    1  ---  Control Change
 0000C997   4  --     B0    2C    04    1  ---  Control Change
 0000C997   4  --     B0    2C    05    1  ---  Control Change
 0000C997   4  --     B0    0C    18    1  ---  Control Change
 0000C997   4  --     B0    0C    19    1  ---  Control Change
 0000C998   4  --     B0    2C    04    1  ---  Control Change
 0000C998   4  --     B0    0C    19    1  ---  Control Change
 0000C998   4  --     B0    2C    05    1  ---  Control Change
 0000C998   4  --     B0    0C    1A    1  ---  Control Change
 0000C998   4  --     B0    2C    00    1  ---  Control Change
 0000C998   4  --     B0    2C    01    1  ---  Control Change
 0000C998   4  --     B0    2C    02    1  ---  Control Change
 0000C998   4  --     B0    2C    03    1  ---  Control Change
 0000C998   4  --     B0    0C    1B    1  ---  Control Change
 0000C998   4  --     B0    2C    06    1  ---  Control Change
 0000C998   4  --     B0    2C    07    1  ---  Control Change
 0000C998   4  --     B0    0C    13    1  ---  Control Change
 0000C999   4  --     B0    0C    13    1  ---  Control Change
 0000C999   4  --     B0    2C    03    1  ---  Control Change
 0000C999   4  --     B0    2C    04    1  ---  Control Change
 0000C999   4  --     B0    2C    05    1  ---  Control Change
 0000C999   4  --     B0    2C    06    1  ---  Control Change
 0000C999   4  --     B0    2C    07    1  ---  Control Change
 0000C999   4  --     B0    0C    14    1  ---  Control Change
 0000C999   4  --     B0    2C    00    1  ---  Control Change
 0000C999   4  --     B0    2C    01    1  ---  Control Change
 0000C999   4  --     B0    0C    15    1  ---  Control Change
 0000C999   4  --     B0    2C    02    1  ---  Control Change
 0000C99A   4  --     B0    0C    15    1  ---  Control Change
 0000C99A   4  --     B0    2C    07    1  ---  Control Change
 0000C99A   4  --     B0    0C    09    1  ---  Control Change
 0000C99A   4  --     B0    2C    00    1  ---  Control Change
 0000C99A   4  --     B0    2C    01    1  ---  Control Change
 0000C99B   4  --     B0    0C    09    1  ---  Control Change
 0000C99B   4  --     B0    2C    02    1  ---  Control Change
 0000C99B   4  --     B0    2C    03    1  ---  Control Change
 0000C99B   4  --     B0    2C    04    1  ---  Control Change
 0000C99B   4  --     B0    2C    05    1  ---  Control Change
 0000C99B   4  --     B0    0C    16    1  ---  Control Change
 0000C99B   4  --     B0    2C    00    1  ---  Control Change
 0000C99B   4  --     B0    2C    01    1  ---  Control Change
 0000C99C   4  --     B0    2C    03    1  ---  Control Change
 0000C99C   4  --     B0    0C    0A    1  ---  Control Change
 0000C99C   4  --     B0    2C    00    1  ---  Control Change
 0000C99C   4  --     B0    2C    01    1  ---  Control Change
 0000C99C   4  --     B0    2C    02    1  ---  Control Change
 0000C99C   4  --     B0    0C    10    1  ---  Control Change
 0000C9A1   4  --     B0    0C    10    1  ---  Control Change
 0000C9A1   4  --     B0    2C    01    1  ---  Control Change
 0000C9A1   4  --     B0    2C    02    1  ---  Control Change
 0000C9A1   4  --     B0    2C    03    1  ---  Control Change
 0000C9A1   4  --     B0    2C    04    1  ---  Control Change
 0000C9A1   4  --     B0    0C    0D    1  ---  Control Change
 0000C9A1   4  --     B0    2C    00    1  ---  Control Change
 0000C9A2   4  --     B0    2C    02    1  ---  Control Change
 0000C9A2   4  --     B0    0C    0D    1  ---  Control Change
 0000C9A2   4  --     B0    2C    03    1  ---  Control Change
 0000C9A2   4  --     B0    2C    04    1  ---  Control Change
 0000C9A2   4  --     B0    2C    05    1  ---  Control Change
 0000C9A2   4  --     B0    2C    06    1  ---  Control Change
 0000C9A2   4  --     B0    0C    0E    1  ---  Control Change
 0000C9A2   4  --     B0    2C    01    1  ---  Control Change
 0000C9A3   4  --     B0    0C    0F    1  ---  Control Change
 0000C9A3   4  --     B0    2C    00    1  ---  Control Change
 0000C9A3   4  --     B0    2C    01    1  ---  Control Change
 0000C9A3   4  --     B0    2C    02    1  ---  Control Change
 0000C9A3   4  --     B0    2C    03    1  ---  Control Change
 0000C9A3   4  --     B0    2C    04    1  ---  Control Change
 0000C9A3   4  --     B0    0C    1C    1  ---  Control Change
 0000C9A3   4  --     B0    2C    05    1  ---  Control Change
 0000C9A3   4  --     B0    2C    06    1  ---  Control Change
 0000C9A3   4  --     B0    2C    07    1  ---  Control Change
 0000C9A3   4  --     B0    2C    08    1  ---  Control Change
 0000C9A4   4  --     B0    0C    1C    1  ---  Control Change
 0000C9A4   4  --     B0    2C    09    1  ---  Control Change
 0000C9A4   4  --     B0    2C    0A    1  ---  Control Change
 0000C9A4   4  --     B0    2C    0B    1  ---  Control Change
 0000C9A4   4  --     B0    0C    00    1  ---  Control Change
 0000C9A4   4  --     B0    2C    01    1  ---  Control Change
 0000C9A4   4  --     B0    2C    02    1  ---  Control Change
 0000C9A4   4  --     B0    2C    03    1  ---  Control Change
 0000C9A4   4  --     B0    2C    04    1  ---  Control Change
 0000C9A4   4  --     B0    2C    05    1  ---  Control Change
 0000C9A4   4  --     B0    2C    06    1  ---  Control Change
 0000C9A4   4  --     B0    2C    07    1  ---  Control Change
 0000C9A4   4  --     B0    10    00    1  ---  Control Change
 0000C9A4   4  --     A0    00    10    1  C -1 Key Aftertouch
 0000C9A5   4  --     A0    00    00    1  C -1 Key Aftertouch
 0000C9A5   4  --     A0    00    30    1  C -1 Key Aftertouch
 0000C9A5   4  --     A0    00    20    1  C -1 Key Aftertouch
 0000C9A5   4  --     B0    0C    01    1  ---  Control Change
 0000C9A5   4  --     B0    2C    01    1  ---  Control Change
 0000C9A5   4  --     B0    2C    02    1  ---  Control Change
 0000C9A5   4  --     B0    2C    03    1  ---  Control Change
 0000C9A5   4  --     B0    2C    04    1  ---  Control Change
 0000C9A5   4  --     B0    2C    05    1  ---  Control Change
 0000C9A5   4  --     B0    2C    06    1  ---  Control Change
 0000C9A5   4  --     B0    2C    07    1  ---  Control Change
 0000C9A5   4  --     B0    11    00    1  ---  Control Change
 0000C9A6   4  --     A0    01    10    1  C#-1 Key Aftertouch
 0000C9A6   4  --     A0    01    00    1  C#-1 Key Aftertouch
 0000C9A6   4  --     A0    01    30    1  C#-1 Key Aftertouch
 0000C9A6   4  --     A0    01    20    1  C#-1 Key Aftertouch
 0000C9A6   4  --     B0    0C    02    1  ---  Control Change
 0000C9A6   4  --     B0    2C    01    1  ---  Control Change
 0000C9A6   4  --     B0    2C    02    1  ---  Control Change
 0000C9A6   4  --     B0    2C    03    1  ---  Control Change
 0000C9A6   4  --     B0    2C    04    1  ---  Control Change
 0000C9A6   4  --     B0    2C    05    1  ---  Control Change
 0000C9A6   4  --     B0    2C    06    1  ---  Control Change
 0000C9A6   4  --     B0    2C    07    1  ---  Control Change
 0000C9A6   4  --     B0    12    00    1  ---  Control Change
 0000C9A6   4  --     A0    02    10    1  D -1 Key Aftertouch
 0000C9A7   4  --     A0    02    00    1  D -1 Key Aftertouch
 0000C9A7   4  --     A0    02    30    1  D -1 Key Aftertouch
 0000C9A7   4  --     A0    02    20    1  D -1 Key Aftertouch
 0000C9A7   4  --     B0    0C    03    1  ---  Control Change
 0000C9A7   4  --     B0    2C    01    1  ---  Control Change
 0000C9A7   4  --     B0    2C    02    1  ---  Control Change
 0000C9A7   4  --     B0    2C    03    1  ---  Control Change
 0000C9A7   4  --     B0    2C    04    1  ---  Control Change
 0000C9A7   4  --     B0    2C    05    1  ---  Control Change
 0000C9A7   4  --     B0    2C    06    1  ---  Control Change
 0000C9A7   4  --     B0    2C    07    1  ---  Control Change
 0000C9A7   4  --     B0    13    00    1  ---  Control Change
 0000C9A7   4  --     A0    03    10    1  Eb-1 Key Aftertouch
 0000C9A7   4  --     A0    03    00    1  Eb-1 Key Aftertouch
 0000C9A9   4  --     A0    03    30    1  Eb-1 Key Aftertouch
 0000C9A9   4  --     A0    03    20    1  Eb-1 Key Aftertouch
 0000C9A9   4  --     B0    0C    04    1  ---  Control Change
 0000C9A9   4  --     B0    2C    01    1  ---  Control Change
 0000C9A9   4  --     B0    2C    02    1  ---  Control Change
 0000C9A9   4  --     B0    2C    03    1  ---  Control Change
 0000C9A9   4  --     B0    2C    04    1  ---  Control Change
 0000C9A9   4  --     B0    2C    05    1  ---  Control Change
 0000C9A9   4  --     B0    2C    06    1  ---  Control Change
 0000C9A9   4  --     B0    2C    07    1  ---  Control Change
 0000C9A9   4  --     B0    14    00    1  ---  Control Change
 0000C9A9   4  --     A0    04    10    1  E -1 Key Aftertouch
 0000C9A9   4  --     A0    04    00    1  E -1 Key Aftertouch
 0000C9A9   4  --     A0    04    30    1  E -1 Key Aftertouch
 0000C9A9   4  --     A0    04    20    1  E -1 Key Aftertouch
 0000C9A9   4  --     B0    0C    05    1  ---  Control Change
 0000C9AA   4  --     B0    0C    05    1  ---  Control Change
 0000C9AA   4  --     B0    2C    03    1  ---  Control Change
 0000C9AA   4  --     B0    2C    04    1  ---  Control Change
 0000C9AA   4  --     B0    2C    05    1  ---  Control Change
 0000C9AA   4  --     B0    2C    06    1  ---  Control Change
 0000C9AA   4  --     B0    2C    07    1  ---  Control Change
 0000C9AA   4  --     B0    15    00    1  ---  CC: 21 (E-MU)
 0000C9AA   4  --     A0    05    10    1  F -1 Key Aftertouch
 0000C9AA   4  --     A0    05    00    1  F -1 Key Aftertouch
 0000C9AA   4  --     A0    05    30    1  F -1 Key Aftertouch
 0000C9AA   4  --     A0    05    20    1  F -1 Key Aftertouch
 0000C9AA   4  --     B0    0C    06    1  ---  Control Change
 0000C9AA   4  --     B0    2C    01    1  ---  Control Change
 0000C9AA   4  --     B0    2C    02    1  ---  Control Change
 0000C9AB   4  --     B0    0C    06    1  ---  Control Change
 0000C9AB   4  --     B0    2C    04    1  ---  Control Change
 0000C9AB   4  --     B0    2C    05    1  ---  Control Change
 0000C9AB   4  --     B0    2C    06    1  ---  Control Change
 0000C9AB   4  --     B0    2C    07    1  ---  Control Change
 0000C9AB   4  --     B0    16    00    1  ---  CC: 22 (E-MU)
 0000C9AB   4  --     A0    06    10    1  F#-1 Key Aftertouch
 0000C9AB   4  --     A0    06    00    1  F#-1 Key Aftertouch
 0000C9AB   4  --     A0    06    30    1  F#-1 Key Aftertouch
 0000C9AB   4  --     A0    06    20    1  F#-1 Key Aftertouch
 0000C9AB   4  --     B0    0C    07    1  ---  Control Change
 0000C9AB   4  --     B0    2C    01    1  ---  Control Change
 0000C9AB   4  --     B0    2C    02    1  ---  Control Change
 0000C9AB   4  --     B0    2C    03    1  ---  Control Change
 0000C9AC   4  --     B0    2C    04    1  ---  Control Change
 0000C9AC   4  --     B0    0C    07    1  ---  Control Change
 0000C9AC   4  --     B0    2C    05    1  ---  Control Change
 0000C9AC   4  --     B0    2C    06    1  ---  Control Change
 0000C9AC   4  --     B0    2C    07    1  ---  Control Change
 0000C9AC   4  --     B0    17    00    1  ---  CC: 23 (E-MU)
 0000C9AC   4  --     A0    07    10    1  G -1 Key Aftertouch
 0000C9AC   4  --     A0    07    00    1  G -1 Key Aftertouch
 0000C9AC   4  --     A0    07    30    1  G -1 Key Aftertouch
 0000C9AC   4  --     A0    07    20    1  G -1 Key Aftertouch
 0000C9AC   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 12 00 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 01 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 02 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 03 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 0000C9AF   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 12 04 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 05 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F0 00 00 66 05 00 12 06 20 20 20 20 20 20 20 20 20 20
 SYSX: F7
 SYSX: F7
 0000C9AF   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9AF   4  --     B0    0C    00    1  ---  Control Change
 0000C9AF   4  --     B0    2C    03    1  ---  Control Change
 0000C9AF   4  --     B0    2C    04    1  ---  Control Change
 0000C9B0   4  --     B0    2C    04    1  ---  Control Change
 0000C9B0   4  --     B0    0C    00    1  ---  Control Change
 0000C9B0   4  --     B0    2C    01    1  ---  Control Change
 0000C9B0   4  --     B0    2C    07    1  ---  Control Change
 0000C9B0   4  --     B0    2C    02    1  ---  Control Change
 0000C9B0   4  --     B0    00    00    1  ---  CC: Bank MSB
 0000C9B0   4  --     B0    20    00    1  ---  CC: Bank LSB
 0000C9B0   4  --     B0    10    00    1  ---  Control Change
 0000C9B0   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9B0   4  --     B0    0C    01    1  ---  Control Change
 0000C9B0   4  --     B0    2C    03    1  ---  Control Change
 0000C9B1   4  --     B0    2C    07    1  ---  Control Change
 0000C9B1   4  --     B0    0C    01    1  ---  Control Change
 0000C9B1   4  --     B0    2C    02    1  ---  Control Change
 0000C9B1   4  --     B0    01    00    1  ---  CC: Modulation
 0000C9B1   4  --     B0    21    00    1  ---  Control Change
 0000C9B1   4  --     B0    11    00    1  ---  Control Change
 0000C9B1   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9B1   4  --     B0    0C    02    1  ---  Control Change
 0000C9B1   4  --     B0    2C    03    1  ---  Control Change
 0000C9B1   4  --     B0    2C    04    1  ---  Control Change
 0000C9B1   4  --     B0    2C    01    1  ---  Control Change
 0000C9B2   4  --     B0    2C    07    1  ---  Control Change
 0000C9B2   4  --     B0    0C    02    1  ---  Control Change
 0000C9B2   4  --     B0    2C    02    1  ---  Control Change
 0000C9B2   4  --     B0    02    00    1  ---  CC: Breath
 0000C9B2   4  --     B0    22    00    1  ---  Control Change
 0000C9B2   4  --     B0    12    00    1  ---  Control Change
 0000C9B2   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9B2   4  --     B0    0C    03    1  ---  Control Change
 0000C9B2   4  --     B0    2C    03    1  ---  Control Change
 0000C9B2   4  --     B0    2C    04    1  ---  Control Change
 0000C9B2   4  --     B0    2C    01    1  ---  Control Change
 0000C9B2   4  --     B0    03    00    1  ---  Control Change
 0000C9B3   4  --     B0    23    00    1  ---  Control Change
 0000C9B3   4  --     B0    13    00    1  ---  Control Change
 0000C9B3   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9B3   4  --     B0    0C    04    1  ---  Control Change
 0000C9B3   4  --     B0    2C    03    1  ---  Control Change
 0000C9B3   4  --     B0    2C    04    1  ---  Control Change
 0000C9B3   4  --     B0    2C    01    1  ---  Control Change
 0000C9B3   4  --     B0    2C    07    1  ---  Control Change
 0000C9B3   4  --     B0    2C    02    1  ---  Control Change
 0000C9B3   4  --     B0    04    00    1  ---  CC: Foot Controller
 0000C9B3   4  --     B0    24    00    1  ---  Control Change
 0000C9B3   4  --     B0    14    00    1  ---  Control Change
 0000C9B4   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9B4   4  --     B0    0C    05    1  ---  Control Change
 0000C9B4   4  --     B0    2C    03    1  ---  Control Change
 0000C9B4   4  --     B0    2C    04    1  ---  Control Change
 0000C9B4   4  --     B0    2C    01    1  ---  Control Change
 0000C9B4   4  --     B0    2C    07    1  ---  Control Change
 0000C9B4   4  --     B0    2C    02    1  ---  Control Change
 0000C9B4   4  --     B0    05    00    1  ---  CC: Portamento Time
 0000C9B4   4  --     B0    25    00    1  ---  Control Change
 0000C9B4   4  --     B0    15    00    1  ---  CC: 21 (E-MU)
 0000C9B4   4  --     B0    0C    06    1  ---  Control Change
 0000C9B5   4  --     B0    2C    04    1  ---  Control Change
 0000C9B5   4  --     B0    0C    06    1  ---  Control Change
 0000C9B5   4  --     B0    2C    01    1  ---  Control Change
 0000C9B5   4  --     B0    2C    07    1  ---  Control Change
 0000C9B5   4  --     B0    2C    02    1  ---  Control Change
 0000C9B5   4  --     B0    06    00    1  ---  CC: Data Entry MSB
 0000C9B5   4  --     B0    26    00    1  ---  CC: Data Entry LSB
 0000C9B5   4  --     B0    16    00    1  ---  CC: 22 (E-MU)
 0000C9B5   4  --     F0  Buffer:    13 Bytes   System Exclusive
 0000C9B5   4  --     B0    0C    07    1  ---  Control Change
 0000C9B5   4  --     B0    2C    03    1  ---  Control Change
 0000C9B7   4  --     B0    2C    02    1  ---  Control Change
 0000C9B7   4  --     B0    07    00    1  ---  CC: Volume
 0000C9B7   4  --     B0    27    00    1  ---  Control Change
 0000C9B7   4  --     B0    17    00    1  ---  CC: 23 (E-MU)
 0000C9B7   4  --     B0    0C    0E    1  ---  Control Change
 0000C9B7   4  --     B0    2C    04    1  ---  Control Change
 0000C9B7   4  --     B0    2C    03    1  ---  Control Change
 0000C9B7   4  --     B0    2C    43    1  ---  Control Change
 0000C9B7   4  --     B0    2C    05    1  ---  Control Change
 0000C9B7   4  --     B0    0C    0F    1  ---  Control Change
 0000C9B7   4  --     B0    0C    0D    1  ---  Control Change
 0000C9B8   4  --     B0    0C    09    1  ---  Control Change
 0000C9B8   4  --     B0    2C    01    1  ---  Control Change
 0000C9B8   4  --     B0    2C    00    1  ---  Control Change
 0000C9B8   4  --     B0    2C    02    1  ---  Control Change
 0000C9B8   4  --     B0    2C    03    1  ---  Control Change
 0000C9B8   4  --     B0    2C    04    1  ---  Control Change
 0000C9B8   4  --     B0    0C    08    1  ---  Control Change
 0000C9B8   4  --     B0    0C    1C    1  ---  Control Change
 0000C9B8   4  --     B0    2C    07    1  ---  Control Change
 0000C9B8   4  --     B0    0C    10    1  ---  Control Change
 0000C9B8   4  --     F0  Buffer:    16 Bytes   System Exclusive
 0000C9B8   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F7
 SYSX: F7
 SYSX: F7
 0000C9B9   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 0000C9B9   4  --     B0    0C    08    1  ---  Control Change
 0000C9B9   4  --     B0    2C    07    1  ---  Control Change
 0000C9B9   4  --     B0    0C    0C    1  ---  Control Change
 0000C9B9   4  --     B0    2C    02    1  ---  Control Change
 0000C9B9   4  --     B0    0C    19    1  ---  Control Change
 0000C9B9   4  --     B0    2C    03    1  ---  Control Change
 0000C9B9   4  --     B0    0C    0F    1  ---  Control Change
 0000C9B9   4  --     B0    2C    43    1  ---  Control Change
 0000C9B9   4  --     B0    2C    06    1  ---  Control Change
 0000C9B9   4  --     B0    2C    04    1  ---  Control Change
 0000C9BA   4  --     B0    0C    16    1  ---  Control Change
 0000C9BA   4  --     B0    2C    03    1  ---  Control Change
 0000C9BA   4  --     B0    0C    17    1  ---  Control Change
 0000C9BA   4  --     B0    2C    42    1  ---  Control Change
 0000C9BA   4  --     B0    2C    41    1  ---  Control Change
 0000C9BA   4  --     B0    2C    45    1  ---  Control Change
 0000C9BA   4  --     B0    2C    44    1  ---  Control Change
 0000C9BA   4  --     B0    2C    43    1  ---  Control Change
 0000C9BA   4  --     B0    2C    40    1  ---  Control Change
 0000C9BA   4  --     B0    0C    00    1  ---  Control Change
 0000C9BA   4  --     B0    2C    05    1  ---  Control Change
 0000C9BA   4  --     B0    0C    01    1  ---  Control Change
 0000C9BA   4  --     B0    0C    02    1  ---  Control Change
 0000C9BA   4  --     B0    0C    03    1  ---  Control Change
 0000C9BB   4  --     B0    2C    05    1  ---  Control Change
 0000C9BB   4  --     B0    0C    04    1  ---  Control Change
 0000C9BB   4  --     B0    0C    05    1  ---  Control Change
 0000C9BB   4  --     B0    0C    06    1  ---  Control Change
 0000C9BB   4  --     B0    0C    07    1  ---  Control Change
 0000C9BE   4  --     B0    0C    19    1  ---  Control Change
 0000C9BE   4  --     B0    2C    01    1  ---  Control Change
 0000C9BE   4  --     B0    0C    10    1  ---  Control Change
 0000C9BE   4  --     B0    2C    04    1  ---  Control Change
 0000C9BE   4  --     B0    0C    16    1  ---  Control Change
 0000C9BE   4  --     B0    2C    00    1  ---  Control Change
 0000C9BE   4  --     B0    2C    02    1  ---  Control Change
 0000C9BE   4  --     B0    0C    1B    1  ---  Control Change
 0000C9BF   4  --     B0    2C    01    1  ---  Control Change
 0000C9BF   4  --     B0    0C    19    1  ---  Control Change
 0000C9BF   4  --     B0    0C    0B    1  ---  Control Change
 0000C9BF   4  --     B0    2C    42    1  ---  Control Change
 0000C9BF   4  --     B0    2C    07    1  ---  Control Change
 0000C9BF   4  --     B0    2C    06    1  ---  Control Change
 0000C9BF   4  --     B0    2C    05    1  ---  Control Change
 0000C9BF   4  --     B0    2C    04    1  ---  Control Change
 0000C9BF   4  --     B0    2C    03    1  ---  Control Change
 0000C9BF   4  --     B0    2C    00    1  ---  Control Change
 0000C9BF   4  --     F0  Buffer:    13 Bytes   System Exclusive
 SYSX: F0 00 00 66 05 00 10 08 50 61 6E 20 F7
 0000C9BF   4  --     B0    10    00    1  ---  Control Change
 0000C9C0   4  --     B0    0C    00    1  ---  Control Change
 0000C9C0   4  --     B0    2C    05    1  ---  Control Change
 0000C9C0   4  --     B0    11    00    1  ---  Control Change
 0000C9C0   4  --     B0    0C    01    1  ---  Control Change
 0000C9C0   4  --     B0    12    00    1  ---  Control Change
 0000C9C0   4  --     B0    0C    02    1  ---  Control Change
 0000C9C0   4  --     B0    13    00    1  ---  Control Change
 0000C9C0   4  --     B0    0C    03    1  ---  Control Change
 0000C9C0   4  --     B0    14    00    1  ---  Control Change
 0000C9C0   4  --     B0    0C    04    1  ---  Control Change
 0000C9C0   4  --     B0    15    00    1  ---  CC: 21 (E-MU)
 0000C9C0   4  --     B0    0C    05    1  ---  Control Change
 0000C9C0   4  --     B0    16    00    1  ---  CC: 22 (E-MU)
 0000C9C0   4  --     B0    0C    06    1  ---  Control Change
 0000C9C1   4  --     B0    17    00    1  ---  CC: 23 (E-MU)
 0000C9C1   4  --     B0    0C    07    1  ---  Control Change
 0000C9C1   4  --     B0    2C    05    1  ---  Control Change
 0000C9C1   4  --     B0    0C    00    1  ---  Control Change
 0000C9C1   4  --     B0    2C    06    1  ---  Control Change
 0000C9C1   4  --     B0    0C    01    1  ---  Control Change
 0000C9C1   4  --     B0    0C    02    1  ---  Control Change
 0000C9C1   4  --     B0    0C    03    1  ---  Control Change
 0000C9C1   4  --     B0    0C    04    1  ---  Control Change
 0000C9C1   4  --     B0    0C    05    1  ---  Control Change
 0000C9C1   4  --     B0    0C    06    1  ---  Control Change
 0000C9C1   4  --     B0    0C    1C    1  ---  Control Change
 0000C9C1   4  --     B0    2C    00    1  ---  Control Change
 0000C9C2   4  --     B0    0C    1C    1  ---  Control Change
 0000C9C2   4  --     B0    2C    02    1  ---  Control Change
 0000C9C2   4  --     B0    2C    03    1  ---  Control Change
 0000C9C2   4  --     B0    2C    04    1  ---  Control Change
 0000C9C2   4  --     B0    2C    05    1  ---  Control Change
 0000C9C2   4  --     B0    0C    0D    1  ---  Control Change
 0000C9C2   4  --     B0    0C    10    1  ---  Control Change
 0000C9C2   4  --     B0    2C    00    1  ---  Control Change
 0000C9C2   4  --     B0    2C    01    1  ---  Control Change
 0000C9C2   4  --     B0    0C    0B    1  ---  Control Change
 0000C9C2   4  --     B0    2C    42    1  ---  Control Change
 0000C9C2   4  --     B0    2C    07    1  ---  Control Change
 0000C9C2   4  --     B0    2C    06    1  ---  Control Change
 0000C9C2   4  --     B0    0C    0C    1  ---  Control Change
 0000C9C4   4  --     B0    2C    05    1  ---  Control Change
 0000C9C4   4  --     B0    0C    0C    1  ---  Control Change
 0000C9C4   4  --     B0    2C    03    1  ---  Control Change
 0000C9C4   4  --     A0    00    00    1  C -1 Key Aftertouch
 0000C9C4   4  --     A0    00    10    1  C -1 Key Aftertouch
 0000C9C4   4  --     A0    00    20    1  C -1 Key Aftertouch
 0000C9C4   4  --     A0    00    30    1  C -1 Key Aftertouch
 0000C9C4   4  --     A0    01    00    1  C#-1 Key Aftertouch
 0000C9C4   4  --     A0    01    10    1  C#-1 Key Aftertouch
 0000C9C4   4  --     A0    01    20    1  C#-1 Key Aftertouch
 0000C9C4   4  --     A0    01    30    1  C#-1 Key Aftertouch
 0000C9C4   4  --     A0    02    00    1  D -1 Key Aftertouch
 0000C9C4   4  --     A0    02    10    1  D -1 Key Aftertouch
 0000C9C4   4  --     A0    02    20    1  D -1 Key Aftertouch
 0000C9C4   4  --     A0    02    30    1  D -1 Key Aftertouch
 0000C9C4   4  --     A0    03    00    1  Eb-1 Key Aftertouch
 0000C9C4   4  --     A0    03    10    1  Eb-1 Key Aftertouch
 0000C9C4   4  --     A0    03    20    1  Eb-1 Key Aftertouch
 0000C9C4   4  --     A0    03    30    1  Eb-1 Key Aftertouch
 0000C9C4   4  --     A0    04    00    1  E -1 Key Aftertouch
 0000C9C4   4  --     A0    04    10    1  E -1 Key Aftertouch
 0000C9C4   4  --     A0    04    20    1  E -1 Key Aftertouch
 0000C9C4   4  --     A0    04    30    1  E -1 Key Aftertouch
 0000C9C4   4  --     A0    05    00    1  F -1 Key Aftertouch
 0000C9C4   4  --     A0    05    10    1  F -1 Key Aftertouch
 0000C9C4   4  --     A0    05    20    1  F -1 Key Aftertouch
 0000C9C4   4  --     A0    05    30    1  F -1 Key Aftertouch
 0000C9C4   4  --     A0    06    00    1  F#-1 Key Aftertouch
 0000C9C4   4  --     A0    06    10    1  F#-1 Key Aftertouch
 0000C9C4   4  --     A0    06    20    1  F#-1 Key Aftertouch
 0000C9C4   4  --     A0    06    30    1  F#-1 Key Aftertouch
 0000C9C4   4  --     A0    07    00    1  G -1 Key Aftertouch
 0000C9C5   4  --     A0    07    10    1  G -1 Key Aftertouch
 0000C9C5   4  --     A0    07    20    1  G -1 Key Aftertouch
 0000C9C5   4  --     A0    07    30    1  G -1 Key Aftertouch
 0000C9C5   4  --     B0    0C    1B    1  ---  Control Change
 0000C9C5   4  --     B0    2C    05    1  ---  Control Change
 0000C9C5   4  --     B0    0C    09    1  ---  Control Change
 0000C9C5   4  --     B0    0C    00    1  ---  Control Change
 0000C9C5   4  --     B0    2C    06    1  ---  Control Change
 0000C9C8   4  --     B0    0C    01    1  ---  Control Change
 0000C9C8   4  --     B0    2C    06    1  ---  Control Change
 0000C9C8   4  --     B0    0C    02    1  ---  Control Change
 0000C9C8   4  --     B0    0C    03    1  ---  Control Change
 0000C9C8   4  --     B0    0C    04    1  ---  Control Change
 0000C9C8   4  --     B0    0C    05    1  ---  Control Change
 0000C9C8   4  --     B0    0C    06    1  ---  Control Change
 0000C9C8   4  --     B0    0C    07    1  ---  Control Change
 0000C9C8   4  --     B0    0C    1C    1  ---  Control Change
 0000C9C8   4  --     B0    2C    00    1  ---  Control Change
 0000C9C8   4  --     B0    2C    02    1  ---  Control Change
 0000C9C9   4  --     B0    0C    1C    1  ---  Control Change
 0000C9C9   4  --     B0    2C    03    1  ---  Control Change
 0000C9CA   4  --     B0    0C    1C    1  ---  Control Change
 0000C9CA   4  --     B0    2C    04    1  ---  Control Change
 0000C9CA   4  --     B0    2C    05    1  ---  Control Change
 0000C9CA   4  --     B0    0C    10    1  ---  Control Change
 0000C9CA   4  --     B0    2C    01    1  ---  Control Change
 0000C9CC   4  --     B0    0C    10    1  ---  Control Change
 0000C9CC   4  --     B0    2C    02    1  ---  Control Change
 0000C9CC   4  --     B0    2C    03    1  ---  Control Change
 0000C9CC   4  --     B0    0C    0E    1  ---  Control Change
 0000C9CC   4  --     B0    2C    05    1  ---  Control Change
 0000C9CC   4  --     B0    0C    0F    1  ---  Control Change
 0000C9CC   4  --     B0    0C    0D    1  ---  Control Change
 0000C9CC   4  --     B0    0C    08    1  ---  Control Change
 0000C9CC   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F7
 SYSX: F7
 SYSX: F7
 0000C9CD   4  --     F0  Buffer:    19 Bytes   System Exclusive
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 SYSX: F7
 0000C9CD   4  --     B0    0C    08    1  ---  Control Change
 0000C9CD   4  --     B0    2C    07    1  ---  Control Change
 0000C9CD   4  --     B0    0C    0C    1  ---  Control Change
 0000C9CD   4  --     B0    2C    02    1  ---  Control Change
 0000C9CD   4  --     B0    0C    19    1  ---  Control Change
 0000C9CD   4  --     B0    2C    03    1  ---  Control Change
 0000C9CD   4  --     B0    0C    0F    1  ---  Control Change
 0000C9CD   4  --     B0    2C    43    1  ---  Control Change
 0000C9CD   4  --     B0    2C    06    1  ---  Control Change
 0000C9CD   4  --     B0    2C    04    1  ---  Control Change
 0000C9CD   4  --     B0    0C    16    1  ---  Control Change
 0000C9CD   4  --     B0    0C    17    1  ---  Control Change
 0000C9CD   4  --     B0    2C    42    1  ---  Control Change
 0000C9CD   4  --     B0    2C    41    1  ---  Control Change
 0000C9CD   4  --     B0    2C    45    1  ---  Control Change
 0000C9CD   4  --     B0    2C    44    1  ---  Control Change
 0000C9CE   4  --     B0    2C    43    1  ---  Control Change
 0000C9CE   4  --     B0    0C    17    1  ---  Control Change
 0000C9CE   4  --     B0    2C    41    1  ---  Control Change
 0000C9CE   4  --     B0    2C    40    1  ---  Control Change
 0000C9CE   4  --     B0    0C    00    1  ---  Control Change
 0000C9CE   4  --     B0    2C    05    1  ---  Control Change
 0000C9CE   4  --     B0    0C    01    1  ---  Control Change
 0000C9CE   4  --     B0    0C    02    1  ---  Control Change
 0000C9CE   4  --     B0    0C    03    1  ---  Control Change
 0000C9CE   4  --     B0    0C    04    1  ---  Control Change
 0000C9CE   4  --     B0    0C    05    1  ---  Control Change
 0000C9CE   4  --     B0    0C    06    1  ---  Control Change
 0000C9CE   4  --     B0    0C    07    1  ---  Control Change
 0000C9CE   4  --     B0    0C    19    1  ---  Control Change
 0000C9CE   4  --     B0    2C    01    1  ---  Control Change
 0000C9CE   4  --     B0    0C    16    1  ---  Control Change
 0000C9CE   4  --     B0    2C    00    1  ---  Control Change
 0000C9CE   4  --     B0    2C    02    1  ---  Control Change
 0000CAC2   4  --     90    00    00    1  C -1 Note Off
 0000CDCA   4  --     90    00    00    1  C -1 Note Off
 0000CFCE   4  --     B0    0C    00    1  ---  Control Change
 0000CFCE   4  --     B0    2C    05    1  ---  Control Change
 0000CFCE   4  --     B0    0C    01    1  ---  Control Change
 0000CFCE   4  --     B0    0C    02    1  ---  Control Change
 0000CFCE   4  --     B0    0C    03    1  ---  Control Change
 0000CFCE   4  --     B0    0C    04    1  ---  Control Change
 0000CFCE   4  --     B0    0C    05    1  ---  Control Change
 0000CFCE   4  --     B0    0C    06    1  ---  Control Change
 0000CFCF   4  --     B0    0C    07    1  ---  Control Change
 0000CFCF   4  --     B0    2C    05    1  ---  Control Change
 0000D0E5   4  --     90    00    00    1  C -1 Note Off
 0000D3F0   4  --     90    00    00    1  C -1 Note Off
(from now on the only thing that happens is pro tools sends the HUI ping -90 00 00-)
 <=== MIDI-OX Log Closed: Tue 16-Jul-2024 00:13:28 <===
Oh yes, forgot to mention i am using the earlphilhower core and the Adafruit_TinyUSB stack.
As far as i understood this cores must be used with the TinyUSB stack, is that right?
Unfortunately, this is a long-standing issue with the Adafruit TinyUSB library:
That sucks.
Thank you very much for the info Pieter!
They suggest a workaround, gonna try that and see what happens.
