Problem about convert array of string to char using toCharArray
My code only convert the fraction part of string to char. For example, the string is 123.8724; i get 0.8724
My code is:
if (inbyte == '!'){ // Handle delimiter, ! IS MY endline character.
for (int i =0;i< counter;i++)
data*.toCharArray(carray, 12); //put readStringinto an array*
  • float f = atof(carray + 1); //convert the array into an Integer*
  • desiredT = f;*
  • Serial.println(desiredT,5);*
  • inbyte = 0;*
If you are using the String library you can use standard array logic to access the pointer rather than toCharArray which copies the entire array.
  String data = "123.456";
  char * carray = &data[ 0 ];
  float f = atof( carray  );
  Serial.begin( 9600 );
  Serial.print( f, 5 );
void loop() {}
The alternative using toCharArray works like this: ( carray must be an array, or pointer to valid data )
  char carray[ 10 ];
  data.toCharArray( carray, 10 );
void loop() {}
chenni1:
My code is:
  • desiredT = f;*
  • inbyte = 0;*
    [/quote]
  • if (inbyte == '!')
      /// you get your string into a null terminated array somehow....
char dot = strstr(carray, ".");
    Serial.println(dot);
