Problem about loop with in statement
Hello,
I have a project to setup LED with turn on / off by IR Remote, the button 01 - 05 is static LED (in case 1 to case 5), it can success to turn on or off by press the remote button.
But in the case 6, this is a marquee lighting, when I press button 6, it will start the marquee lighting one times only, then stopped.
I want to set to when I press button 6, it will start the marquee lighting until I press the button 6 again for stop it (or set to other button for stop, it is fine).
Who can help to review my code, where has issue? Thank you very much.
#include <IRremote.h>
int RECV_PIN = A0;
#define code1  0xFF6897  // code received from button 1
#define code2  0xFF9867  // code received from button 2
#define code3  0xFFB04F  // code received from button 3
#define code4  0xFF30CF  // code received from button 4
#define code5  0xFF18E7  // code received from button 5
#define code6  0xFF7A85  // code received from button 6
IRrecv irrecv(RECV_PIN);
decode_results results;
const byte NUM = 5;
const byte Blueled[] = {3, 4, 5, 6, 7};
const int RedLED01 = 10;
const int RedLED02 = 11;
const int YellowLED03 = 12;
const int WhiteLED01 = 13;
const int GunplaLED01 = A1;
int itsONled[] = {0, 0, 0, 0, 0, 0, 0, 0};
const int delaytime = 15;
int i;
int blink = 0;
  Serial.begin(9600);   // you can comment this line
  irrecv.enableIRIn();  // Start the receiver
  pinMode(RedLED01, OUTPUT);
  pinMode(RedLED02, OUTPUT);
  pinMode(YellowLED01, OUTPUT);
  pinMode(YellowLED02, OUTPUT);
  pinMode(YellowLED03, OUTPUT);
  pinMode(WhiteLED01, OUTPUT);
  for (i = 0; i < NUM; i++)
    pinMode(Blueled[i], OUTPUT);
    digitalWrite(Blueled[i], HIGH);
  if (irrecv.decode(&results)) {
    unsigned int value = results.value;
    switch (value) {
      case code1:
        if (itsONled[1] == 1) {
          digitalWrite(RedLED01, LOW);
          itsONled[1] = 0;
          digitalWrite(RedLED01, HIGH);
          itsONled[1] = 1;
      case code2:
        if (itsONled[2] == 1) {
          digitalWrite(YellowLED03, LOW);
          itsONled[2] = 0;
          digitalWrite(YellowLED03, HIGH);
          itsONled[2] = 1;
      case code3:
        if (itsONled[3] == 1) {
          digitalWrite(RedLED02, LOW);
          itsONled[3] = 0;
          digitalWrite(RedLED02, HIGH);
          itsONled[3] = 1;
      case code4:
        if (itsONled[4] == 1) {
          digitalWrite(WhiteLED01, LOW);
          itsONled[4] = 0;
          digitalWrite(WhiteLED01, HIGH);
          itsONled[4] = 1;
      case code5:
        if (itsONled[5] == 1) {
          digitalWrite(GunplaLED01, LOW);
          itsONled[5] = 0;
          digitalWrite(GunplaLED01, HIGH);
          itsONled[5] = 1;
      case code6:
          if (itsONled[6] == 0) {
            delay(delaytime);
            digitalWrite(Blueled[i], LOW);
          itsONled[6] = 0;
            itsONled[6] = 1;
    Serial.println(value);           // you can comment this line
    irrecv.resume();                 // Receive the next value
The value method of the results struct is not defined as an unsigned int. Storing the unsigned long value in an unsigned int is a mistake and completely unnecessary. Simply switch on results.value.
            itsONled[6] = 1;
Why is it necessary to assign 1 to itsONled[6] five times?
What is the value in itsONled[6] the second time button 6 is pressed?
PaulS, thank you very much.
I just use Arduino one month only and never touch C language before, all of my code is copy from Internet then merge to one.
I will try to understanding you comment and change with test on my code. Thanks
