Problem about rotary encoders (pls reply quick)
So this is the code:
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
#include <Encoder.h>
hd44780_I2Cexp lcd;
const int tempPin = A0; // Temperature sensor pin
Encoder thresholdEncoder(2, 3); // Rotary encoder pins A and B for threshold value
Encoder durationEncoder(4, 5); // Rotary encoder pins A and B for watering duration
Encoder intervalEncoder(6, 7); // Rotary encoder pins A and B for watering interval
int thresholdValue = 50;       // Default threshold value
int wateringDuration = 5;      // Default watering duration in seconds
int wateringInterval = 60;     // Default watering interval in minutes
  Serial.begin(9600); // Start serial communication
  lcd.begin(20, 4); // Initialize the LCD with 20 columns and 4 rows
  lcd.setBacklight(HIGH); // Turn on the backlight
  // Read temperature value
  int tempValue = readTemperature();
  // Display temperature value
  lcd.setCursor(0, 0);
  lcd.print("Temp: ");
  lcd.print(tempValue);
  lcd.print("C");
  // Read encoder values
  int thresholdEncoderValue = thresholdEncoder.read();
  int durationEncoderValue = durationEncoder.read();
  int intervalEncoderValue = intervalEncoder.read();
  // Update threshold value
  thresholdValue += thresholdEncoderValue;
  // Display threshold value
  lcd.setCursor(0, 1);
  lcd.print("Threshold: ");
  lcd.print(thresholdValue);
  // Update watering duration
  if (durationEncoderValue > 0) {
    wateringDuration++;
  } else if (durationEncoderValue < 0 && wateringDuration > 0) {
    wateringDuration--;
  // Display watering duration
  lcd.setCursor(0, 2);
  lcd.print("Duration: ");
  lcd.print(wateringDuration);
  lcd.print("s");
  // Update watering interval
  if (intervalEncoderValue > 0) {
    wateringInterval++; // Clockwise rotation
  } else if (intervalEncoderValue < 0 && wateringInterval > 0) {
    wateringInterval--; // Counterclockwise rotation
  // Display watering interval
  lcd.setCursor(0, 3);
  lcd.print("Interval: ");
  lcd.print(wateringInterval);
  lcd.print("min");
  // Reset encoder values
  thresholdEncoder.write(0);
  durationEncoder.write(0);
  intervalEncoder.write(0);
int readTemperature() {
  // Simulated temperature reading
  return 25;
The variables should increase and decrease depending on the rotation of the encoder. The problem is duration and interval changes inaccurately and adds random value and increases/decreases randomly whether rotated left or right. The wiring is ok, so I think it's the code
Why don’t you let the encoder manage the values?
which arduino do you have ?
how long does one loop take?
I alr solved it thanks for the reply tho
Ok have fun
