Problem about Uploading Arduino Ethernet Board
Dear Sir,
I just buy An Arduino Ethernet board w/o POE from this website, then I found the problem that
I can't upload my sketch TT_TT.
Now I have an USB to Serial and install the driver already, but it give 3 Wire Tx Rx Gnd as a picture below
When I upload this show error as
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\Lecturer01\Desktop\micro\arduino-101\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM17
Using Programmer : stk500v1
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
Please give me some advice to troubleshoot this problem
Best regradly,
Panwit
Give the Reset button a quick press when you see the "Binary sketch size:" message. Your USB-to-Serial device doesn't connect to the Auto Reset hardware on the Arduino so you have to do the reset manually.
Dear Johnwasser
I try to quick press a setup botton as you advice , It is not work, I still can't upload.
So I try to use 6 wire connect a DB9 pin of USB to serial to a board as
Upload Pin at Arduino board Serial pin of USB to serial
Pin1 : Gnd Pin 5
Pin2 : CTS Pin 8
Pin3 : +5 +5 of arduino board
Pin4 : Tx Pin 3
Pin5 : Rx Pin 2
Pin6 : DTR Pin 4
reference by a picture in this link below, but it still not work .
Best regard
If your USB-to-Serial adapter has a 9-pin D conector as is shown in your diagram it is probably using RS232 logic levels which are not the same as TTL logic levels. You should probably invest in a USB-to-TTL (5V) Serial cable such as:
http://www.foogra.com/products/43320/
http://serialstuff.amazonwebstore.com/USB-to-5v-TTL-Header-Like/M/B004LC28G2.htm
Dear Johnwasser
I already buy an usb to serial with TTL.
I use a sketch with boards Arduino ethernet which follow this link http://scuola.arduino.cc/en/content/getting-started-arduino-ethernet
When I upload an example code : Basic => Blink
It appear
################################## | 100% 0.05s
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude done. Thank you.
How to Resolve and Solve this Problems ?
Best regradly,
Panwit
