Problem accessing variables declared outside a ISR routine
I'm making my own servo library but I have a problem accessing the variables declared outside the ISR routine.
I get the following error:
C:\arduino-1.0.2\libraries\Motor\Motor.cpp: In function 'void __vector_13()':
C:\arduino-1.0.2\libraries\Motor\Motor.cpp:52: error: '_counter' was not declared in this scope
C:\arduino-1.0.2\libraries\Motor\Motor.cpp:53: error: '_servoPulse' was not declared in this scope
C:\arduino-1.0.2\libraries\Motor\Motor.cpp:54: error: '_servoPin' was not declared in this scope
C:\arduino-1.0.2\libraries\Motor\Motor.cpp:56: error: '_servoPin' was not declared in this scope
C:\arduino-1.0.2\libraries\Motor\Motor.cpp:61: error: '_girando' was not declared in this scope
C:\arduino-1.0.2\libraries\Motor\Motor.cpp:62: error: 'actualiza_servo' was not declared in this scope
Before making the library it worked so I think it has to be something related to a not included library or some kind of problem.
Here is the header:
 #ifndef Motor_h
 #define Motor_h
  #include <Arduino.h>
  #include <avr/interrupt.h>
 class Motor{
  public:
    Motor(int pin);
    void actualiza_servo(); //Makes servo rotation smooth
    void print_servo_options(); //Serial print of the options
    void opciones(int opt); //Calls the opt function selected
    void girar(int angle ); //Rotates the servo an angle between 0-180
    void velocidad_giro(int velocidad); //Changes rotating velocity (values 0-10)
    void aceleracion_giro(int aceleracion); //Changes acceleration(0:linear 1:cuadratic)
  private:
    int _counter;
    int _vel_servo;
    int _servoPulse;   //Min 500 us - 1500us  - 2500us Max
    int _x;             //Dato introducido por consola
    int _oldValue,_newValue; //Variables auxiliares
    int _option;
    int _acelerador;
    int _servoPin;
    bool _girando;
#endif
And here the code ...
  Motor.h - Library for controlling one servo
  Created by J. Antonio Blazquez, 8 December 2012
  Release into public domain
    void opciones(int opt);     //Switch between the servo options
#include "Motor.h"
#define MAX_SERVO  151   //mínimo valor que puede tomar el servo sin romperse = 500*(tiempo entre interrupciones) - en microsegundos
#define MIN_SERVO  36  //máximo valor que puede tomar el servo sin romperse = 2500*(tiempo entre interrupciones)
#define VEL_SERVO  30
#define OPT_SPEED  0
#define OPT_ACC    1
Motor :: Motor(int servPin){
  _counter = 0;
  _vel_servo = 30;
  _servoPulse = 90;   //Min 500 us - 1500us  - 2500us Max
  _x = 0;             //Dato introducido por consola
  _option = 1;
  _acelerador = 1;
  _servoPin;
  _girando = false;
  _servoPin = servPin;
  pinMode(_servoPin, OUTPUT); //Pin de datos al servo
  _newValue = _servoPulse;
  _oldValue = _servoPulse;
   noInterrupts();           // disable all interrupts
  /***************** CONFIGURACIÓN DEL TIMER ************************/
  TCCR1A = 0X02; //Preescalado /8 -> 16MHz/8 = 2MHz = 0'0005 ms/ciclo
  TCCR1B = 0X1A; //timer1 (16bits = 65536 ciclos) _counter MODO 14 FAST PWM
  TIMSK1= 0x01; //interruption por desbordamiento
  TCNT1= 0xFFE1; //Valor inicial de timer 65505 -> 30ciclos/interrupción
  interrupts();             // enable all interrupts
ISR(TIMER1_OVF_vect) { //Se produce una interrupción cada 0'015 ms          <<<<<<<<<<<<<<<< HERE IS THE PROBLEM>>>>>>>>>>>>>>>>>>>>>>>
  _counter++; //Suma 15 us cada interrupción
  if (_counter < _servoPulse){
    digitalWrite(_servoPin, HIGH);
  }else{
    digitalWrite(_servoPin, LOW);
  if (_counter > 1333){
    _counter=0;
  if (_girando)
    actualiza_servo();
void Motor :: actualiza_servo(){
  if(_option==OPT_ACC){
     if (_newValue<_oldValue){
       _servoPulse-=_acelerador;
       _oldValue-=_acelerador;
       Serial.println(_acelerador);
       delay(_vel_servo);
     }else if(_newValue>_oldValue){
       _servoPulse+=_acelerador;
       _oldValue+=_acelerador;
       delay(_vel_servo);
  if(_option==OPT_SPEED){
     _servoPulse-=1;
     _oldValue-=1;
     delay(_vel_servo);
     _servoPulse+=1;
     _oldValue+=1;
     delay(_vel_servo);
   if (_newValue == _servoPulse){
     _girando = false;
  _acelerador = _acelerador << 1;
  if(_acelerador > abs(_newValue-_oldValue)){
    _acelerador  = 1;
void Motor :: print_servo_options(){
   Serial.println("Opciones:");
   Serial.println("1.- Girar    2.- Cambiar Velocidad    3.- Aceleracion geometrica    4.- Aceleracion lineal");
void Motor :: opciones(int opt){
  int data;
   switch (opt){
     case 1:
       Serial.println("Introducir Angulo (0 -180) :");
       while(Serial.available()==0);
       data = Serial.parseInt();
       girar(data);
     case 2:
       Serial.println("Introducir Velocidad (0-10): ");
       velocidad_giro(data);
     case 3:
       _option = 1;
       Serial.println("Aceleracion cuadratica");
     case 4:
       _option = 0;
       Serial.println("Aceleracion lineal");
void Motor :: girar(int angle ){
      if (angle>=0 && angle<=180){
        _newValue = map(angle,0,180,MIN_SERVO,MAX_SERVO);
        _counter = 0;
        _girando = true;
        Serial.print("Angulo de giro: ");
        Serial.println(angle);
    }else{
        Serial.println("Wrong value: Introduce un valor de 0 a 180 ");
void Motor :: velocidad_giro(int velocidad){
  if(velocidad >=0 && velocidad <= 10){
    _vel_servo = map(velocidad,10,0,0,300);
    Serial.print("Nueva velocidad: ");
    Serial.println(_vel_servo);
  }else{
    Serial.println("Wrong value: Introduce un valor de 0 a 10 ");
// aceleracion = 0 -> lineal
// aceleracion = 1 -> v^2
void Motor :: aceleracion_giro(int aceleracion){
  _option = aceleracion;
I appreciate any help.
Thanks.
You can't access class variables inside an ISR because it doesn't know which instance of the class to use. If it has to use a particular instance, you could qualify the variables by the instance name.
Thank you Nick.
I changed the variables that are shared between instances to the code and I declared them as static volatile because their value can change at any time.
I moved this to Motor.cpp
    static volatile int _servoPin;
    static volatile int _servoPulse;   //Min 500 us - 1500us  - 2500us Max
    static volatile int _counter;
No compiler problems now, but the ISR is not working in my sample program:
#include <Motor.h>
Motor servo(10);
int opt;
void setup(){
  servo.print_servo_options();
void loop(){
  if (Serial.available()>0){
    opt = Serial.parseInt();
    servo.opciones(opt);
