Problem adding 433Mhz RF module into potentiometer control Servo Motor
Hi, I'm a newbie on the Programming. Can you please help me, I would like to use potentiometer to control my Servo Motor by using 433MHz RF module. I can't found a sketch or example of this. I'm not sure my following type of RF module are able to use on this project or not. So i need help.
I have:
2 x Servo Motor 2 x Potentiometer 433Mhz Transmitter and Receiver 2 x Arduino Uno
Thank you Very Much! http://www.icstation.com/433mhz-transmitter-receiver-arduino-project-p-1402.html
Start by getting each piece of the project working separately.
Learn to control a servo using the potentiometer, learn to send data by radio from one Arduino to another, then put the two together.
There are many example of each task on the web.
