I've got this code which is a infra-red decoder which reads an input IR sig and transcodes it to something else.
* IRTrans: receive and transcode IR signals
* An IR detector/demodulator must be connected to the input RECV_PIN.
* An IR LED must be connected to the output PWM pin 3.
* A resistor and visible LED can be connected to STATUS_PIN to provide status.
* The logic is:
* If a valid IR code in a lookup table is received
* a corresonding different IR is transmitted
* otherwise send the original code
* Version 0.1 September, 2011
* Copyright 2011 Simon Walters based on code copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 4;
//int BUTTON_PIN = 12;
int STATUS_PIN = 2;
IRrecv irrecv(RECV_PIN);
IRsend irsend;
decode_results results;
const int lRows = 19;
const int lCols = 6;
const char* lookupTable[lRows][lCols] = {
"SONT", "338", "SONY", "A8B47","20", "Red->PWR" } ,
"SONT", "F38", "SONY","42B47","20","Blue->Home" } ,
"SONT", "538", "SONY","BCB47","20","Sel->Sel" } ,
"SONT", "490", "SONY","9CB47","20","Up->Up" } ,
"SONT", "C90", "SONY","5CB47","20","Down->Down" } ,
"NEC", "1DE2B946", "SONY","DCB47","20","Left->Left" } ,
"SONT", "290", "SONY","3CB47","20","Right->Right" } ,
"SONT", "B38", "SONY","A8B47","20","Green->PWR" } ,
"SONT", "5E25", "SONY","58B47","20","Play->Play" } ,
"SONT", "738", "SONY","98B47","20","Yellow->Pause" } ,
"NEC", "1D8000FF", "SONY","D8B47","20","Rew->Rew" } ,
"NEC", "1DE2F00F", "SONY","38B47","20","FF->FF" } ,
"NEC", "1D8033CC", "SONY","98B47","20","Stop->Pause" } ,
"SONT", "1D0", "SONY","18B47","20","Backup->Stop" } ,
"NEC", "1DE2D926", "NEC","1D00D926","32","VolUp->AVVolUp" } ,
"NEC", "1DE259A6", "NEC","1D0059A6","32","VolDwn->AVVolDwn" } ,
"SONT", "A50", "NEC","20DFD02F","32","Help->TvAV" } ,
"SONT", "A90", "NEC","20DF10EF","32","Pwr->TvPwr" } ,
"SONT", "90", "NEC","20DF00FF","32","ChUp->ChUp" }
unsigned long valueLTable[lRows][lCols];
irrecv.enableIRIn(); // Start the receiver
// pinMode(BUTTON_PIN, INPUT);
pinMode(STATUS_PIN, OUTPUT);
for (int checkRows =0;checkRows<lRows;checkRows++) {
Serial.println(lookupTable[checkRows][1]);
String outCode = lookupTable[checkRows][3];
Serial.println(outCode);
unsigned long decCode = 0;
unsigned long multiplier = 1;
for (int i=0;i<outCode.length();i++) {
int chr = (int)outCode.charAt(outCode.length()-i-1);
if (chr < 58) {
decCode += (chr-48) * multiplier;
else {
decCode += (chr-55) * multiplier;
multiplier *= 16;
Serial.println(decCode,HEX);
valueLTable[checkRows][3]=decCode;
outCode = lookupTable[checkRows][4];
decCode = 0;
int chr = (int)outCode.charAt(1);
decCode += (chr-48);
chr = (int)outCode.charAt(0);
decCode += (chr-48)*10;
valueLTable[checkRows][4]=decCode;
Serial.println(valueLTable[checkRows][3]);
Serial.println(valueLTable[checkRows][4]);
if (lookupTable[checkRows][2] == "SONY") {
valueLTable[checkRows][2] = SONY;
if (lookupTable[checkRows][2] == "NEC") {
valueLTable[checkRows][2] = NEC;
Serial.println(valueLTable[checkRows][2]);
// Storage for the recorded code
int codeType = -1; // The type of code
unsigned long codeValue; // The code value if not raw
unsigned int rawCodes[RAWBUF]; // The durations if raw
int codeLen; // The length of the code
int toggle = 0; // The RC5/6 toggle state
// Stores the code for later playback
// Most of this code is just logging
void storeCode(decode_results *results) {
codeType = results->decode_type;
int count = results->rawlen;
if (codeType == UNKNOWN) {
Serial.println("Received unknown code, saving as raw");
codeLen = results->rawlen - 1;
// To store raw codes:
// Drop first value (gap)
// Convert from ticks to microseconds
// Tweak marks shorter, and spaces longer to cancel out IR receiver distortion
for (int i = 1; i <= codeLen; i++) {
if (i % 2) {
// Mark
rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK - MARK_EXCESS;
Serial.print(" m");
else {
// Space
rawCodes[i - 1] = results->rawbuf[i]*USECPERTICK + MARK_EXCESS;
Serial.print(" s");
Serial.print(rawCodes[i - 1], DEC);
Serial.println("");
else {
if (codeType == NEC) {
Serial.print("Received NEC: ");
if (results->value == REPEAT) {
// Don't record a NEC repeat value as that's useless.
Serial.println("repeat; ignoring.");
return;
else if (codeType == SONY) {
Serial.print("Received SONY: ");
else if (codeType == RC5) {
Serial.print("Received RC5: ");
else if (codeType == RC6) {
Serial.print("Received RC6: ");
else {
Serial.print("Unexpected codeType ");
Serial.print(codeType, DEC);
Serial.println("");
Serial.println(results->value, HEX);
codeValue = results->value;
codeLen = results->bits;
// Serial.println(codeLen);
void sendCode(int repeat) {
if (repeat) {
// irsend.sendNEC(REPEAT, codeLen);
// Serial.println("Sent NEC repeat");
else {
Serial.print("Sent NEC ");
Serial.println(codeValue, HEX);
irsend.sendNEC(codeValue, codeLen);
// for (int i=1;i<=2;i++) {
codeValue =0xFFFFFFFF;
Serial.print("Sent NEC Repeat Code");
for (int i=1;i<=3;i++) {
irsend.sendSony(codeValue, codeLen);
Serial.print("Sent Sony ");
else if (codeType == RC5 || codeType == RC6) {
if (!repeat) {
// Flip the toggle bit for a new button press
toggle = 1 - toggle;
// Put the toggle bit into the code to send
codeValue = codeValue & ~(1 << (codeLen - 1));
codeValue = codeValue | (toggle << (codeLen - 1));
Serial.print("Sent RC5 ");
irsend.sendRC5(codeValue, codeLen);
else {
irsend.sendRC6(codeValue, codeLen);
Serial.print("Sent RC6 ");
else if (codeType == UNKNOWN /* i.e. raw */) {
// Assume 38 KHz
irsend.sendRaw(rawCodes, codeLen, 38);
Serial.println("Sent raw");
if (irrecv.decode(&results)) {
digitalWrite(STATUS_PIN, HIGH);
Serial.println(" ");
storeCode(&results);
// irrecv.resume(); // resume receiver
digitalWrite(STATUS_PIN, LOW);
delay(200); // Wait a bit before retransmissions
// Serial.println("Transcoding Start");
// Serial.println("rcvd code: ");
// Serial.println(codeValue);
// String sCodeValue = String(2576,HEX);
//Serial.println(sCodeValue);
String sCodeValue = String(codeValue,HEX).toUpperCase();
// Serial.println(sCodeValue);
boolean transcode = false;
// Serial.println(lookupTable[checkRows][1]);
if (sCodeValue == lookupTable[checkRows][1]) {
Serial.println("Found transcode");
codeType = valueLTable[checkRows][2];
codeValue = valueLTable[checkRows][3];
codeLen = valueLTable[checkRows][4];
sendCode(0);
Serial.println(codeValue,HEX);
Serial.println(lookupTable[checkRows][5]);
transcode = true;
delay(100); // Wait a bit between retransmissions
if (!transcode) {
// Serial.println("Just repeat");
// delay(100);
// sendCode(0);
irrecv.enableIRIn(); // Re-enable receiver
My problem is that the code is working fine but if I add one more entry to the lookup table it misbehaves ![]()
I'd be very grateful if someone could test it out - you don't need and hardware as the fault manifests as a strange debug output from the serial com port.
To try and recreate the problem, load in the code (you'll need Ken Sheffiffs IRLibray) and monitor the serail port - you should see a debug list of the lookup table being output.
Now try and add in another entry to the lookup table (and increment lrows as well) and see what happens to the serial com output (it just outputs rubbish AFAIC) ![]()
Any help greatfully received ![]()
Simon
