I’m making a smart car using an arduino uno, sensor shield v5, motor control with a L298N and a servo motor + HC-SR04 ultrasound sensor. I want to add a IR receiver on the board so I can also control the car with a remote.
The problem is when I add in the code for the IR Receiver and make the 3 additional connections, the right motor doesn’t respond anymore, it only moves at the beginning, though slower than the left one during the initial setup, then only the left motor functions properly.
Here is the whole code with comments next to the IR-Receiver specific code:
#include <Servo.h>
#include <IRremote.h> //IR Receiver
Servo servo ;
const int trigPin = 13;
const int echoPin = 12;
const int servoPin = 11;
const int enAPin = 6;
const int in1Pin = 7;
const int in2Pin = 5;
const int in3Pin = 4;
const int in4Pin = 2;
const int enBPin = 3;
const int receiverPin = 9; //IR Receiver
IRrecv irrecv(receiverPin); //IR Receiver
decode_results signals; //IR Receiver
enum Motor { LEFT, RIGHT };
void go(enum Motor m, int speed)
digitalWrite (m == LEFT ? in1Pin : in3Pin , speed > 0 ? HIGH : LOW );
digitalWrite (m == LEFT ? in2Pin : in4Pin , speed <= 0 ? HIGH : LOW );
analogWrite(m == LEFT ? enAPin : enBPin, speed < 0 ? -speed : speed );
void testMotors ()
static int speed[8] = { 128, 255, 128, 0 , -128, -255, -128, 0};
go(RIGHT, 0);
for (unsigned char i = 0 ; i < 8 ; i++)
go(LEFT, -speed[i]), delay(200);
go(RIGHT, speed[i]), delay(200);
unsigned int readDistance()
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
digitalWrite(trigPin, LOW);
unsigned long period = pulseIn(echoPin, HIGH);
return period * 343 / 2000;
#define NUM_ANGLES 7
unsigned char sensorAngle[NUM_ANGLES] = {60, 70, 80, 90, 100, 110, 120};
unsigned int distance [NUM_ANGLES];
void readNextDistance()
static unsigned char angleIndex = 0;
static signed char step = 1;
distance[angleIndex] = readDistance();
angleIndex += step ;
if (angleIndex == NUM_ANGLES - 1) step = -1;
else if (angleIndex == 0) step = 1;
servo.write(sensorAngle[angleIndex]);
void setup () {
Serial.begin(9600); //IR Receiver
irrecv.enableIRIn(); //IR Receiver
pinMode(trigPin , OUTPUT);
pinMode(echoPin, INPUT);
pinMode(enAPin, OUTPUT);
pinMode(in1Pin, OUTPUT);
pinMode(in2Pin, OUTPUT);
pinMode(in3Pin, OUTPUT);
pinMode(in4Pin, OUTPUT);
pinMode(enBPin, OUTPUT);
servo.attach(servoPin);
servo.write(90);
go(LEFT, 0);
go(RIGHT, 0);
testMotors();
servo.write(sensorAngle[0]);
delay(200);
for (unsigned char i = 0 ; i < NUM_ANGLES ; i ++)
readNextDistance(), delay (200);
void loop () {
//IR Receiver:
if (irrecv.decode(&signals)) {
Serial.println(signals.value);
irrecv.resume();
if (signals.value == 0xFFA25D) {
Serial.println("yeees");
readNextDistance ();
unsigned char tooClose = 0;
for (unsigned char i = 0 ; i < NUM_ANGLES ; i++)
if (distance[i] < 200)
tooClose = 1;
if (tooClose) {
go(LEFT, 180);
go(RIGHT, -80);
go(LEFT, -180);
go(RIGHT, 180);
delay (50);
