Problem after adding TFT_eWidget ? T-Display s3
New to Arduino but until today no problems. Have lilygo t display s3. Below is the file I have been working on, was running perfectly earlier, installed TFT_eWidget and I am now getting a communication error when I attempt to upload.
Screen is now blacked out so I know some communication has happened but received the following message and just cant figure out what has changed. I am sure its something simple.
"A serial exception error occurred: Write timeout
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
Failed uploading: uploading error: exit status 1"
//FUEL AND OIL
//320x170
//LILYGO T DISPLAY S3
//MAKE SURE ESP IS VERSION LOWER THAN 3.0
//analog in pin 1, 2 for esp32-S3
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite sprite = TFT_eSprite(&tft);
TFT_eSprite img = TFT_eSprite(&tft);
#define color1 0xff9e  //almost white
#define color2 0x39e7  //almost black
#define color3 0xf800  //red-ish
#define color4 0x3fe7  //green 0x3fe7   0x1de3
#define color5 0x39c7  //grey
int values[2] = { 0 };
  // initialize serial communication at 9600 bits per second:
  //Serial.begin(9600);
  tft.init();
  tft.setRotation(3);
  sprite.createSprite(320, 170);
  sprite.fillSprite(color1);
void drawGraph() {
  //oil label
  sprite.fillRoundRect(10, 20, 82, 54, 6, color5);  //1st bar oil label bckgrd
  sprite.setTextSize(3);
  sprite.setTextColor(TFT_RED);
  sprite.drawString("OIL", 20, 36, 1);
  //fuel label
  sprite.fillRoundRect(10, 96, 82, 54, 6, color5);  //2nd bar oil label bckgrd
  sprite.drawString("FUEL", 16, 112, 1);
  sprite.pushSprite(0, 0);  //goes at end just before loop
// the loop routine runs over and over again forever:
  drawGraph();
  //OIL GAUGE
  //this reads pin 2, remaps 0-100, prnts mapped value to serial print
  int sensorValue = analogRead(2);                      // read the input on analog pin 34:
  int mappedVal = map(analogRead(2), 0, 4095, 0, 200);  // scale the value
  //oil bar graph bkgrd
  sprite.fillRoundRect(100, 20, 210, 54, 5, color2);  // 1st bar graph bkgrd oil (frm left,frm top,length,hght,rad)
                                                      //oil bar graph slider
  sprite.setCursor(104, 10);
  sprite.fillRoundRect(104, 26, mappedVal, 42, 5, color4);  //Draw a rectangle (x,y,width,height,color)
  // FUEL GAUGE
  //this reads pin 3
  int fuelValue = analogRead(3);
  int fuelVal = map(analogRead(3), 0, 4095, 0, 200);       // scale the value
                                                           //fuel bar bkgrd
  sprite.fillRoundRect(100, 96, 210, 54, 5, color2);       //2nd bar graph bkgrd(frm left,frm top,length,hght,rad)
                                                           //fuelbar graph slider
  sprite.fillRoundRect(104, 102, fuelVal, 42, 5, color4);  //2nd bar graph (frm left,frm top,length,hght,rad)
  sprite.setCursor(104, 100);
  Serial.println(mappedVal);  // print out the value:
  delay(1);  // delay in between reads for stability
I guess what I am asking is what would installing that library change that would cause a communication problem with no other changes
Try to hold "boot" button while you plug the usb cable, and release after few seconds:
immagine
Ciao, Ale.
Thank You, I tried that before posting, ide recognizes board on port 14 no problem, have checked all settings in tools and notice they are diff after adding library, had no problem uploading minutes earlier. Just trying to figure out what/why adding a library would change.
Finally figured it out,
After adding the espi widget library Arduino was stuck at about 85% updating
https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_dev_index.json , for a few hours.
Deleted that line from additional board manager, rebooted and pasted it back and everything is normal. Just posting follow up in the event someone down the road has a similar problem.
