So, to get a better view, i turned the breadboard 180° and wired everything again. Just changed the wireing in the code:
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 8 Feb 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(2, 3, 9, 10, 11, 12);
// set up the LCD's number of columns and rows:
lcd.begin(20, 4);
// Print a message to the LCD.
lcd.print("hello, world!");
pinMode(13, OUTPUT);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
digitalWrite(13, HIGH);
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
digitalWrite(13, LOW);
Aaaand at last: A picture of the tidied wireing
and still nothin works...
What else can I do to may fix it? I already asked the LCD wheter it will work as a christmas present, but it didn't wanted to... damn!
greetings kuhni
