Problem: Arduino Uno + Ultra Compact RS232 to TTL Converter -> Projector-Control
Hello ladies and gentleman,
i looking for an answer of my problem. I want to control a Nec Beamer with a Arduino – Power On / Off. So i bought a RS232 to TTL Converter at Amazon and connected it with my Arduino. But it seems that it doesn’t works. I don’t know why.
I tested it with a USB-RS232-Adapter and CoolTerm for OSX and sended the HEX-String “02 00 00 00 00 02” for Power ON and “02 01 00 00 00 03” for Power OFF – It works (send_data_usbadapter_to_projector _ WORKS).
When i connect my Arduino over RS232 to my RS232-USB-Adapter, it receives Data like in the attachment (send_data_arduino_to_usbadapter.png): 200002200002200002
Because it is a Loop, see the Arduino-Code:
#include <SoftwareSerial.h>
const int rx = 10; // rx pin of Arduino, SO(serial out)of TRex.
const int tx = 11; // tx pin of Arduino, SI(serial in)of TRex.
SoftwareSerial mySerial (rx, tx); // RX to SO of Trex, TX to SI of Trex
mySerial.begin(9600);
mySerial.print(0x02,HEX);
mySerial.print(0x00,HEX);
if (mySerial.peek() == -1) {
Serial.println(“no response”);
while (mySerial.peek() != -1) {
Serial.println(mySerial.read());
I also tested it with Serial.print and the RX, TX-Pins, but it doesn’t work to.
Who knows the problem and help me? :slight_smile:
Best regards
Benni
I also tested:
void setup() { Serial.begin(9600); }
Serial.write(0x02); Serial.write(0x00); Serial.write(0x00); Serial.write(0x00); Serial.write(0x00); Serial.write(0x02);
Serial.write(02); Serial.write(00); Serial.write(00); Serial.write(00); Serial.write(00); Serial.write(02);
Serial.write("02 00 00 00 00 02);
Looking at a NEC serial protocol manual here it looks like you might need a different baud rate to the 9600 your using.
i already tested 9600 and 38400... My projector is the NEC M403H and i could find it in your pdf ;)
i changed the settings of the projector already form 38400 to 9600 :)
With the usbadapter and CoolTerm it works with baudrate 9600, I think thats not the problem.
Now it works... i used a cross gender changer, because it doesn't worked without. The manual tells me to use a crosscable... With the the USB-Adapter i need a crosscable, instead of the RS232-Konverter – its crossed internal ;D
Thanks a lot
das_benni: Now it works... i used a cross gender changer, because it doesn't worked without. The manual tells me to use a crosscable... With the the USB-Adapter i need a crosscable, instead of the RS232-Konverter – its crossed internal ;D
Glad you got it working though I was of no help in doing so.
