Hello, For my school project I am working on an LED strip on music. I am new to this forum so sorry if I forget to mention anything.
Materials
Arduino Uno
WS2812B LED strip 2m, 60 LED / m
HC-05 BT module
Jack chassis (To do jack input to analog port)
I have different modes in my app for different types of music. I also have a separate section for a static color, so not on music.
I want to be able to operate the LED strip using the app.
#include <SoftwareSerial.h>
#include <FastLED.h>
#define NUM_LEDS 120
#define PIN 7
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
SoftwareSerial Bluetooth(3,2);
int k = 2040;
int k2 = 340;
int k3 = 340;
int k4 = 340;
int k5 = 340;
int k6 = 340;
int k7 = 340;
int kleur = 0;
int kleur2 = 0;
int kleur3 = 0;
int kleur4 = 150;
int kleur5 = 120;
int kleur6 = 250;
int kleur7 = 150;
int kleur8 = 120;
int kleur9 = 250;
int kleur10 = 150;
int kleur11 = 120;
int kleur12 = 250;
int kleur13 = 150;
int kleur14 = 120;
int kleur15 = 250;
int kleur16 = 150;
int kleur17 = 120;
int kleur18 = 250;
int kleur19 = 150;
int kleur20 = 120;
int kleur21 = 250;
int R = 0;
int G = 0;
int B = 0;
int brightness = 50;
String dataIn ="";
String mode = "0";
FastLED.addLeds<WS2812B, PIN, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness(brightness);
Bluetooth.begin(9600);
if ((Bluetooth.available() > 0) && (mode == "0")){
dataIn = Bluetooth.readString();
Serial.println(dataIn);
delay(20);
if (dataIn.startsWith("M")){
mode = dataIn.substring(dataIn.indexOf("M") + 1);
Serial.println(mode);
} else if (dataIn.startsWith("2")) {
delay(10);
String stringR = dataIn.substring(dataIn.indexOf("R") + 1, dataIn.indexOf("G"));
R = stringR.toInt();
String stringG = dataIn.substring(dataIn.indexOf("G") + 1, dataIn.indexOf("B"));
G = stringG.toInt();
String stringB = dataIn.substring(dataIn.indexOf("B") + 1, dataIn.indexOf("E"));
B = stringB.toInt();
mode = "4";
else if (dataIn.startsWith("3")){
String stringBrightness = dataIn.substring(dataIn.indexOf("3") + 1, dataIn.length());
brightness = stringBrightness.toInt();
if (mode == "1"){
int audioInput = analogRead(A0);
int ledSterkte0 = map(audioInput, 0, 60, 0, 120);
FastLED.clear();
Serial.println(audioInput);
for (int i = 0; i < ledSterkte0; i++) {
leds[i].setRGB (R, G, B);
k++;
if(k > 2040){
R = random(0, 150);
G = random(0, 240);
B = random(0, 170);
k = 0;
FastLED.show();
if (Bluetooth.available() > 0){
mode = "0";
else if (mode == "2"){
int ledSterkte0 = map(audioInput, 0, 60, 0, 59);
int ledSterkte1 = map(audioInput, 0, 60, 120, 60);
FastLED.clear();
leds[i].setRGB (kleur, kleur2, kleur3);
k++;
if(k > 2040){
kleur = random(10, 255);
kleur2 = random(10, 255);
kleur3 = random(10, 255);
k = 0;
for (int i2 = 120; i2 > ledSterkte1; i2--) {
leds[i2].setRGB (kleur, kleur2, kleur3);
k++;
if(k > 2040){
k = 0;
FastLED.show();
mode = "0";
else if (mode == "3"){
int ledSterkte0 = map(audioInput, 0, 60, 0, 19);
int ledSterkte1 = map(audioInput, 0, 60, 20, 39);
int ledSterkte2 = map(audioInput, 0, 60, 40, 59);
int ledSterkte3 = map(audioInput, 0, 60, 60, 79);
int ledSterkte4 = map(audioInput, 0, 60, 80, 99);
int ledSterkte5 = map(audioInput, 0, 60, 100, 120);
FastLED.clear();
leds[i].setRGB (kleur4, kleur5, kleur6);
k2++;
if(k2 > 340){
kleur4 = random(10, 255);
kleur5 = random(10, 255);
kleur6 = random(10, 255);
k2 = 0;
for (int i2 = 20; i2 < ledSterkte1; i2++) {
leds[i2].setRGB (kleur7, kleur8, kleur9);
k3++;
if(k3 > 340){
kleur7 = random(10, 255);
kleur8 = random(10, 255);
kleur9 = random(10, 255);
k3 = 0;
for (int i3 = 40; i3 < ledSterkte2; i3++) {
leds[i3].setRGB (kleur10, kleur11, kleur12);
k4++;
if(k4 > 340){
kleur10 = random(10, 255);
kleur11 = random(10, 255);
kleur12 = random(10, 255);
k4 = 0;
for (int i4 = 60; i4 < ledSterkte3; i4++) {
leds[i4].setRGB (kleur13, kleur14, kleur15);
k5++;
if(k5 > 340){
kleur13 = random(10, 255);
kleur14 = random(10, 255);
kleur15 = random(10, 255);
k5 = 0;
for (int i5 = 80; i5 < ledSterkte4; i5++) {
leds[i5].setRGB (kleur16, kleur17, kleur18);
k6++;
if(k6 > 340){
kleur16 = random(10, 255);
kleur17 = random(10, 255);
kleur18 = random(10, 255);
k6 = 0;
for (int i6 = 100; i6 < ledSterkte5; i6++) {
leds[i6].setRGB (kleur19, kleur10, kleur11);
k7++;
if(k7 > 340){
kleur19 = random(10, 255);
kleur20 = random(10, 255);
kleur21 = random(10, 255);
k7 = 0;
FastLED.show();
mode = "0";
else if (mode == "4"){
for (int i = 0; i < NUM_LEDS; i++) {
mode = "0";
FastLED.show();
delay(20);
delay(10);
String stringBr = dataIn.substring(dataIn.indexOf("I") + 1, dataIn.indexOf("J"));
brightness = stringBr.toInt();
Serial.println(brightness);
FastLED.show();
This has already worked out quite well. I manage to get colors and to choose modes, only I put it all together and now it doesn't work anymore. In the code I retrieve the incoming data from the bluetooth, so that a mode is selected. Only when I choose a mode in the app do I get an inverted question mark in the output of the Arduino. In another code I tested the bluetooth module and got good values out.
I send information to the bluetooth module using the app. I have 4 buttons, mode 1, mode 2, mode 3 and colors.
Photos of the app + code: Arduino Uno Hulp - Album on Imgur
Code 1, code of mode button
Code 2, code of color button
The above code ensures that I get a code with the help of a colorpicker, consisting of 2R ... G ... B ... E
The RGB values of that color are then placed on the dots.
When you click on a mode button it sends the value M1, M2, or M3. When you click the color button, it will send the value M4.
At the beginning of the code I make sure that the variable becomes mode 1, 2, 3 or 4. Only I have the problem that these codes are not retrieved properly, in the output I sometimes get an inverted question mark and sometimes it works, but then I cannot change the mode. How can I fix that? The app works the way I want, I tested this with a different code.
Thanks in advance!
PS you can download the app via these links
.apk: File on MEGA
.aia; MEGA
You can upload the aia file in MIT App Inventor so that you can access the complete code.
