Hello everybody,
I'm trying to compile examples from the arduinoCloudIoT library, but all the examples give me an error when compiling, I attach an image of the error, if anyone can help, thank you in advance, I'm available for clarifications that are necessary.
Please post the actual error message.
All of it.
Sorry, but I don't understand what the actual message means, I made a print of the error and posted the image, which would be the real error, so I try to do that, thanks for your interest in helping.
Hi @kwiek. We need the full text of the error, not a picture of the fragment of it that happened to be showing in the output panel of the IDE.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
- When you encounter an error, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
- Open a forum reply here by clicking the Reply button.
- Click the
icon on the post composer toolbar.
This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V.
This will paste the compilation output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the Reply button to post the output.
It means "all of the text in the lower pane of the IDE", using the "copy error messages" control visible to the right of your picture.
I apologise for not being more specific.
That's a lot of error message for such a small amount of code
Please post the code, in code tags.
Arduino: 1.8.13 (Windows 8.1), Placa:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 1152C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Carla\AppData\Local\Arduino15\packages -hardware C:\Users\Carla\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Carla\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Carla\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Carla\AppData\Local\Temp\arduino_build_579887 -warnings=none -build-cache C:\Users\Carla\AppData\Local\Temp\arduino_cache_731770 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -verbose C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\examples\ArduinoIoTCloud-Basic\ArduinoIoTCloud-Basic.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Carla\AppData\Local\Arduino15\packages -hardware C:\Users\Carla\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Carla\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Carla\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Carla\AppData\Local\Temp\arduino_build_579887 -warnings=none -build-cache C:\Users\Carla\AppData\Local\Temp\arduino_cache_731770 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.python3.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -verbose C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\examples\ArduinoIoTCloud-Basic\ArduinoIoTCloud-Basic.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1
Using core 'esp8266' from platform in folder: C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1
Detecting libraries used...
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\sketch\\ArduinoIoTCloud-Basic.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_ConnectionHandler.h: [Arduino_ConnectionHandler@0.6.3]
ResolveLibrary(Arduino_ConnectionHandler.h)
-> candidates: [Arduino_ConnectionHandler@0.6.3]
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\sketch\\ArduinoIoTCloud-Basic.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\sketch\\ArduinoIoTCloud-Basic.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_DebugUtils.h: [Arduino_DebugUtils@1.1.0]
ResolveLibrary(Arduino_DebugUtils.h)
-> candidates: [Arduino_DebugUtils@1.1.0]
DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\sketch\\ArduinoIoTCloud-Basic.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ArduinoIoTCloud.h: [ArduinoIoTCloud@1.6.0]
ResolveLibrary(ArduinoIoTCloud.h)
-> candidates: [ArduinoIoTCloud@1.6.0]
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\sketch\\ArduinoIoTCloud-Basic.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ArduinoMqttClient.h: [ArduinoMqttClient@0.1.5]
ResolveLibrary(ArduinoMqttClient.h)
-> candidates: [ArduinoMqttClient@0.1.5]
\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\sketch\\ArduinoIoTCloud-Basic.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src\\Arduino_ConnectionHandler.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src\\Arduino_GSMConnectionHandler.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src\\Arduino_LoRaConnectionHandler.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src\\Arduino_NBConnectionHandler.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src\\Arduino_WiFiConnectionHandler.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\BearSSLHelpers.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\CertStoreBearSSL.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFi.cpp" -o nul -
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiAP.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGeneric.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGratuitous.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/lwip2/include" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\cores\\esp8266" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\variants\\nodemcu" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiMulti.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_ConnectionHandler\\src" "-IC:\\Users\\Carla\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\Arduino_DebugUtils\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src" "-IC:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoMqttClient\\src" "C:\\Users\\Carla\\Documents\\Arduino\\libraries\\ArduinoIoTCloud\\src\\cbor\\lib\\tinycbor\\src\\cbortojson.c" -o "C:\\Users\\Carla\\AppData\\Local\\Temp\\arduino_build_579887\\libraries\\ArduinoIoTCloud\\cbor\\lib\\tinycbor\\src\\cbortojson.c.o"
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c: In function 'add_value_metadata':
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c:297:39: error: expected ')' before '__INT64'
297 | if (fprintf(out, "\"tag\":\"%" PRIu64 "\"%s", status->lastTag,
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c:316:40: error: expected ')' before '__INT64'
316 | if (fprintf(out, ",\"v\":\"%c%" PRIx64 "\"", flags & NumberWasNegative ? '-' : '+',
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c: In function 'tagged_value_to_json':
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c:351:35: error: expected ')' before '__INT64'
351 | if (fprintf(out, "{\"tag%" PRIu64 "\":", tag) < 0)
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c:359:39: error: expected ')' before '__INT64'
359 | if (fprintf(out, ",\"tag%" PRIu64 "$cbor\":{", tag) < 0 ||
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c: In function 'value_to_json':
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c:578:38: error: expected ')' before '__INT8'
578 | if (fprintf(out, "\"simple(%" PRIu8 ")\"", simple_type) < 0)
C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud\src\cbor\lib\tinycbor\src\cbortojson.c:637:39: error: expected ')' before '__INT64'
637 | r = fprintf(out, "%s%" PRIu64, val < 0 ? "-" : "", ival);
Usando a biblioteca Arduino_ConnectionHandler na versão 0.6.3 na pasta: C:\Users\Carla\Documents\Arduino\libraries\Arduino_ConnectionHandler
Usando a biblioteca ESP8266WiFi na versão 1.0 na pasta: C:\Users\Carla\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi
Usando a biblioteca Arduino_DebugUtils na versão 1.1.0 na pasta: C:\Users\Carla\Documents\Arduino\libraries\Arduino_DebugUtils
Usando a biblioteca ArduinoIoTCloud na versão 1.6.0 na pasta: C:\Users\Carla\Documents\Arduino\libraries\ArduinoIoTCloud
Usando a biblioteca ArduinoMqttClient na versão 0.1.5 na pasta: C:\Users\Carla\Documents\Arduino\libraries\ArduinoMqttClient
exit status 1
Erro compilando para a placa NodeMCU 1.0 (ESP-12E Module)
I stopped copying and pasting some excerpts, because it seems to me that they are repetitions of the same thing.
Thanks for your help.
Thanks. That was indeed helpful.
I'm sorry that the massive quantity of output produced by the build system for "Thing" sketches in combination with the forum limitations made my instructions not possible to follow.
I was able to determine the cause of the error from this:
You are using the latest version 3.0.1 of the ESP8266 Arduino boards platform. That is usually the sensible thing to do. Unfortunately, Arduino has an outdated version 2.5.0 of that boards platform installed on the Arduino Create/Arduino Cloud servers, and the Arduino IoT Cloud libraries are written to work with that version. This is the cause of the error.
Fortunately, the Arduino IDE Boards Manager makes it easy to install the required version of the platform:
- Select Tools > Board > Boards Manager from the Arduino IDE menus.
- Wait for the updates to finish.
- Scroll down through the list of boards platforms until you see "esp8266 by ESP8266 Community". Click on it.
- Select "2.5.0" from the dropdown version menu.
- Click the Install button.
- Wait for the installation to finish.
- Click the Close button.
Now try compiling your "Thing" sketch again. The error should no longer occur.
Friend,
I followed your step by step, and the result was that now everything is working, you are right, the problem was what you indicated.
I am immensely grateful not only for helping me, but for your kindness, education, and willingness to take your time to help, I really appreciate it and I regret not being able to do more than that, I wish you a lot of health and harmony in your life.
I attach an image just to be registered in the forum and who knows how to serve others.
Greetings from Brazil!
You are welcome. I'm very glad if I was able to be of assistance.
