Problem at displaying sensor value in 2.8" TFT touchscreen mcufriend 0x4747
Hello, I want to display sensor value (load cell) in 2.8" TFT touchscreen mcufriend 0x4747, but I get bad result, the value is flickering like in video. I use mcufriend_kbv and HX711 library, here is my code
#include "HX711.h"
#include <TouchScreen.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
//-----------------hx711------------------------
HX711 scale(22, 24);
float calibration_factor = -200.91; // this calibration factor is adjusted according to my load cell
int units;
float ounces;
//-----------------lcd------------------------------
uint8_t YP = A1;  // must be an analog pin, use "An" notation!
uint8_t XM = A2;  // must be an analog pin, use "An" notation!
uint8_t YM = 7;   // can be a digital pin
uint8_t XP = 6;   // can be a digital pin
#define TS_MINX 180
#define TS_MINY 182
#define TS_MAXX 922
#define TS_MAXY 920
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define MINPRESSURE 10
#define MAXPRESSURE 1000
  scale.set_scale();
  scale.tare();  //Reset the scale to 0
  long zero_factor = scale.read_average();
  tft.reset();
  uint16_t identifier = tft.readID();
  tft.begin(identifier);
  Serial.print(identifier);
  Serial.println(scale.get_units());
  tft.fillScreen(WHITE);
  tft.setCursor(130,100);
  tft.setTextColor(BLACK);
  tft.setRotation(1);
  tft.setTextSize(4);
  tft.print(scale.get_units());
What should I do?
Am I do some mistake in my code?
Go on. It is a simple question of putting the right statements in setup() and in loop()
    scale.set_scale();
    tft.reset();
    tft.setRotation(1);
    tft.setTextSize(4);
    tft.setTextColor(BLACK, WHITE);  //set back colour for rubout
    tft.setCursor(130, 100);
    tft.print(" ");                  //rubs out old digit
    delay(1000);                     //wait between readings
You seem to get different readings. It is often wise to take three or four readings and display the average.
David.
I have done it but the value is left behind in display. I use tft.fillscreen(WHITE) to update the value in display.
There is no fillscreen() method. Only a fillScreen()
Compose your message in your own language. Then use Google Translate to convert it to an English message for the Forum.
You do not understand setup() and loop()
You call setup() once. e.g. for tft.fillScreen(WHITE);
loop() is called repeatedly. e.g. for tft.print(scale.get_units());
David.
i’m sorry it looks I’m typo, I mean tft.fillScreen(WHITE). If I put tft.fillScreen(White) in void setup, previous value is left behind, like in attachment. I understand setup() and loop(), the reason I put tft.fillScreen(WHITE) is to refresh the display.
Go on. I corrected your sketch. Did you try it?
I explained about setTextColor(BLACK, WHITE)
yes i’ve tried it, but the result is as shown in the previous attachment, the text is live behind in display.
The Library Manager could not find an “official” HX711 library. So I was not able to reproduce your program exactly.
However, this example illustrates two ways of printing a varying number. I use a YELLOW background to highlight the printed characters.
MCUFRIEND_kbv tft;
#define BLUE    0x001F
#define RED     0xF800
#define CYAN    0x07FF
    tft.setRotation(1);
    tft.setTextSize(4);
    tft.setTextColor(BLACK, YELLOW);  //set back colour for rubout
    float result = 0.01 * random(-10000, 30000); //-100.0 to +300.00
    Serial.println(result, 2);
    tft.print(result, 2);            //2 decimals
    tft.setCursor(130, 140);
    char buf[10];
    dtostrf(result, 6, 2, buf);   //width=6, prec=2
    tft.print(buf);               //-99.99 to 299.99
Note that the “trailing space” method works with similar numbers but goes wrong when the result width varies.
Using dtostrf() gives you nice formatted output. You can even use it for integers if you use prec=0.
David.
thank you so much David, this works. sorry it looks like I have made a mistake. in my previous sketch written setTextColor (BLACK). I must check my sketch more carefully :slightly_frowning_face:
