Problem between RF transmitter and Pulse
I have to comment out pulseSensor.begin() for the transmitter to work. how do I fix this so that I can send bpm and temperature data.
#include <RH_ASK.h>
#include <SPI.h>
#include "DHT.h";
#define ONE_WIRE_BUS 7
#define USE_ARDUINO_INTERRUPTS true
#include <PulseSensorPlayground.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define DHTPIN 8
#define DHTTYPE DHT11
float hum;
float temp;
float temp2;
float myBPM;
String str_bpm;
String str_temp2;
String str_out;
const int PulseWire = 0;
const int LED13 = 13;
int Threshold = 550;
const unsigned long event_temphum = 2000;
const unsigned long event_send = 3000;
const unsigned long event_display = 3500;
const unsigned long event_pulse = 4000;
unsigned long previousTime_1 = 0;
unsigned long previousTime_2 = 0;
unsigned long previousTime_3 = 0;
unsigned long previousTime_4 = 0;
RH_ASK rf_driver;
DHT dht(DHTPIN, DHTTYPE);
PulseSensorPlayground pulseSensor;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd(0x27, 16, 2);
  rf_driver.init();
  dht.begin();
  Serial.begin(9600); lcd.init();
  lcd.init();
  lcd.backlight();
  pulseSensor.analogInput(PulseWire);
  pulseSensor.setThreshold(Threshold);
  /*updates frequently*/
  unsigned long currentTime = millis();
  //tempdht event
  if (currentTime - previousTime_1 >= event_temphum)
    sensors.requestTemperatures();
    float hic = dht.computeHeatIndex(temp, hum, false);
    hum = dht.readHumidity();
    temp = dht.readTemperature();
    temp2 = sensors.getTempCByIndex(0);
    previousTime_1 = currentTime;
  //send event
  if (currentTime - previousTime_2 >= event_send)
    str_bpm = String(myBPM);
    str_temp2 = String(temp2);
    str_out = str_bpm + "," + str_temp2;
    static char *msg = str_out.c_str();
    rf_driver.send((uint8_t *)msg, strlen(msg));
    rf_driver.waitPacketSent();
    previousTime_2 = currentTime;
  //display event
  if (currentTime - previousTime_3 >= event_display)
    Serial.print(" BPM: ");
    Serial.println(myBPM);
    Serial.print(F(" Humidity: "));
    Serial.print(hum);
    Serial.print(F("% Temperature: "));
    Serial.print(temp); Serial.print(" Body Temperature: ");
    Serial.print(sensors.getTempCByIndex(0));
    Serial.print("C | ");
    lcd.setCursor(0, 0); lcd.print("BPM:");
    lcd.setCursor(4, 0); lcd.print(myBPM);
    lcd.setCursor(8, 0);
    lcd.print("RTp:");
    lcd.setCursor(12, 0);
    lcd.print(temp);
    lcd.setCursor(0, 1);
    lcd.print("BTp:");
    lcd.setCursor(4, 1);
    lcd.print(sensors.getTempCByIndex(0));
    lcd.setCursor(8, 1);
    lcd.print("Hum:");
    lcd.setCursor(12, 1);
    lcd.print(hum);
    previousTime_3 = currentTime;
  //pulse event
  if (currentTime - previousTime_4 >= event_pulse)
    //pulseSensor.begin();
    myBPM = pulseSensor.getBeatsPerMinute();
    previousTime_4 = currentTime;
Reciever Code
//Tech Trends Shameer
//Receiver Program
// Include RadioHead Amplitude Shift Keying Library
#include <RH_ASK.h>
// Include dependant SPI Library
#include <SPI.h>
byte degree_symbol[8] =
  0b00111,
  0b00101,
  0b00111,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000
// Define output strings
String str_bpm;
String str_temp;
String str_out;
// Create Amplitude Shift Keying Object
RH_ASK rf_driver;
  // Initialize ASK Object
  rf_driver.init();
  // Setup Serial Monitor
  // Set buffer to size of expected message
  byte temperature = 0;
  byte BeatsPerMinute = 0;
  uint8_t buf[11];
  uint8_t buflen = sizeof(buf);
  // Check if received packet is correct size
  if (rf_driver.recv(buf, &buflen))
    // Message received with valid checksum
    // Get values from string
    // Convert received data into string
    str_out = String((char*)buf);
    // Split string into two values
    for (int i = 0; i < str_out.length(); i++)
      if (str_out.substring(i, i + 1) == ",")
        str_bpm= str_out.substring(0, i);
        str_temp = str_out.substring(i + 1);
    // Print values to Serial Monitor
    Serial.print("BPM: ");
    Serial.print(str_bpm);
    Serial.print("  - Temperature: ");
    Serial.println(str_temp);
   /* lcd.begin();
    // Turn on the blacklight and print a message.
    lcd.backlight();
     lcd.setCursor(0,0);
      lcd.print("Temperature &");
      lcd.setCursor(0,1);
      lcd.print("Humidity Monitor");
      delay(2000);
      lcd.clear();
    lcd.print("Temperature ");
    //lcd.print((int)str_temp);
    lcd.print(str_temp);
    lcd.print("BeatsPerMin  ");
    //  lcd.print((int)str_bpm);
    lcd.print(str_bpm);
    lcd.setCursor(14, 0);
    lcd.write(1);
    lcd.createChar(1, degree_symbol);
    lcd.setCursor(15, 0);
    lcd.print("C");
    lcd.setCursor(14, 1);
    lcd.print(" %");*/
When you uncomment what happens exactly
You are doing these before pulseSensor.begin() ?
No I just do this //pulseSensor.begin();
Then the transmitter would work
Seems there is a conflicting interrupt between RF and Heartbeat pulse sensor
This is my new code. Tried to stop the timer of heartbeat pulse sensor so it won't interfere with the timer of RF transmitter. Logically it should work, but it seems it still won't.
#include <RH_ASK.h>
#include <SPI.h>
#include "DHT.h";
#define DHTPIN 8
float hum;
float temp;
float temp2;
float myBPM;
float myBPM2;
String str_bpm;
String str_temp2;
String str_out;
const unsigned long event_pulsego = 1000;
const unsigned long event_pulseend = 1500;
unsigned long previousTime_5 = 0;
RH_ASK rf_driver;
  rf_driver.init();
  dht.begin();
  lcd.init();
  lcd.backlight();
  //pulse event
  if (currentTime - previousTime_1 >= event_pulsego)
    pulseSensor.resume();
  //pulse end
  if (currentTime - previousTime_2 >= event_pulseend)
    pulseSensor.pause();
  //tempdhtpulse event
  if (currentTime - previousTime_3 >= event_temphum)
    myBPM2 = pulseSensor.getLastBeatTime();
  //send event
  if (currentTime - previousTime_4 >= event_send)
    str_bpm = String(myBPM2);
  //display event
  if (currentTime - previousTime_5 >= event_display)
    Serial.print(hum);
    lcd.print("RTp:");
    lcd.print(temp);
    lcd.print("BTp:");
    lcd.print("Hum:");
    lcd.print(hum);
    previousTime_5 = currentTime;
