#include <serLCD.h>
#include <SoftwareSerial.h>
#include <Arduino.h>
#define COMMA 0x2C // zum GPS-Daten in String trennen
SoftwareSerial GPS (2,0); // Pin 2 Eingang vom GPS TX-1
serLCD lcd(3); // Pin 3 Ausgang zu Serlcd RX
char gps_string[55]; // Zeichen vom GPS-Empfänger
char d_string[40]; // Data String 33 Zeichen
char p_string[55]; // Position String 49 Zeichen
char z =0; // Zähler für die Anzahl empfangenen Zeichen
char c=0; // Speicher für NewSoftSerial Zeichen hinterlegt
char _state = 0; // Zähler für erhaltene GPS-String
char *s; // Adresse vom Lat/Lon_String zum Umwandeln in float
char *pChar; // Adresse für die Bildung vom Lat/Lon_String
unsigned char j, k; // Zähler für die Bildung vom Lat/Lon_String
float _decimal(char* s);// convert degree-decimal value of latitude terms
char lat_string[10];
char lon_string[10];
float _lat,_lat1;
float _lon, _lon1;
float _degs;
boolean feedgps();
Serial.begin(57600);
GPS.begin(4800); //Set data rate from GPS Receiver
delay(100);
//This initialize the display to blank with the backlight on
lcd.clear();
delay(100);
lcd.print(" Globalposition ");
lcd.setCursor(2, 1);
lcd.print(" Willy Klemenz");
delay(5000);
lcd.clear();
void loop() // run over and over again
boolean newdata= false;
if (feedgps())
newdata = true;
if (newdata)
Serial.println("receive data");
Serial.println(d_string);
Serial.println(p_string);
daten();
Serial.println(lat_string);
Serial.println(lon_string);
lcd.clear();
lcd.setCursor(1,1);
lcd.print(lat_string);
If I want display also data from GPS on the LCD screen then Serial Monitor show me:
receive data
GPGLL,4730.3712,N,00924.9408,E,170110.00,A,A62
,A,A62
2
If I turn off the display commands in loop
//lcd.clear();
//lcd.setCursor(1,1);
//lcd.print(lat_string);
the Serial-Monitor shows me correct data:
receive data
GPZDA,165245.00,21,01,2013,65
GPGLL,4730.3732,N,00924.9421,E,165240.00,A,A69
4730.3732
00924.9421
Maybe someone knows where can be the problem?
Willy
