Problem breaking a for loop
Hi guys,
Not sure what I'm doing wrong. I have the following code and it works when written like this
byte val = 0;
int pos = 40;
int on = 3000;
int servo_delay;
byte other = 0;
  myservo.attach(9);
  pinMode(SERVO_POWER, OUTPUT);
  digitalWrite(SERVO_POWER, LOW);
  if (Serial.available() > 0)
   val = Serial.read();
   if (val > 0)
      if (val == '8')
      {  pos = 40;
         for (int i = 1; i <= 30; i++)
          {  pos = pos + 4;
             digitalWrite(SERVO_POWER, HIGH);
              myservo.write(pos);
             delay(on);
             servo_delay = 4000-on;
             delay(servo_delay);
             Serial.print(pos);
It prints from 40 to 160 and the servo follows. I wanted to add the ability to break the for loop.
So I added the following after the Serial.print(pos);
    if ((Serial.available() > 0) && (val > 0))
             other = Serial.read();
             if ((other = '1') || (other = '2') || (other = '3'))
After I added this, all I get is 44 from the Serial.print over and over again. Is there something I'm missing here?
thanks!
Perhaps you want:
if ((other == '1') || (other == '2') || (other == '3'))
Assignment vs. Comparison - the assignment evaluates to TRUE, so it always breaks...
:slight_smile:
Oh...haha....a little lost here why that doesn't work
but I re-wrote it to:
if ((other >= '1') && (other <= '3'))
and it works, thanks!
The equals sign "=" in C is an assignment operator. It assigns the value on the right to the variable on the left.
If you write an assignment in a conditional like this:
if ((a = 3)) { , this is perfectly legal, but the logic goes like this:
  1. assign the value 3 to the variable a
  2. evaluate the result of this assignment
  3. 3 is non-zero, so the condition is true.
oh i didn't notice the difference in our code, = vs. == duh!
thanks
