I'm currently developing a program on my Arduino uno.
The purpose of my project is to get the water and energy consumption of my home.
The first step of this project is to be able to browse files stored on the SD card and to publish the content of a text file on a web interface. Then I would be able to treat and display data with a web application.
I need your help because I encounter problems with my code.
I manage to display all the files stored (3 files) in my SD card on the web browser of my PC.
The problem comes when I refresh the page. No more files are displayed.
Here is my code :
#include <SD.h>
#include <Ethernet.h>
#include <SPI.h>
//Objet permettant d'accéder aux fichiers de la carte SD
File myFile;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Ouvrir la communication série et attendre l'ouverture du port
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// Démarrer le lecteur de carte SD
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// Démarrer le service Ethernet
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
#define BUFSIZ 100
char clientline[BUFSIZ];
int index = 0;
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.println(c);
//Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0)
Serial.println("Publier la liste des fichiers du répertoire");
PublierListeFichiers("/",client);
//PublierListeFichiers("/",client);
else if (strstr(clientline, "GET /") != 0)
//PublierFichier("/ARDTEST2.CSV",client);
if (c == '\n' && currentLineIsBlank)
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
//Publier l'entête HTML
void PublierEnteteHTML(EthernetClient client)
// send a standard http response header
client.write("HTTP/1.1 200 OK\n");
client.write("Content-Type: text/html\n");
client.write("Connnection: close\n");
client.write("\n");
client.write("<!DOCTYPE HTML>\n");
client.write("<html>");
client.write("<body>");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
//client.println("<meta http-equiv=\"refresh\" content=\"5\">");
//Publier la liste des fichier présent dans un répertoire
boolean PublierListeFichiers(char* path,EthernetClient client)
File myDir, entry;
PublierEnteteHTML(client);
client.write("Liste des fichiers du répertoire ");
//client.write(path);
//client.write(" :</p>");
myDir=SD.open(path,FILE_READ);
// myDir.rewindDirectory();
myDir.seek(0);
entry = myDir.openNextFile();
client.write("<ul>");
while(entry)
Serial.println(entry.name());
client.write("<li>");
//client.write(myDir.position());
client.write("<a href=\"");
client.write(entry.name());
client.write("\">");
client.write("</a>");
// files have sizes, directories do not
client.write(" ");
client.print(entry.size(), DEC);
client.write(" octets</li>");
//close files
myDir.close();
entry.close();
client.write("</ul>");
client.write("fin </P>");
client.write("</body>");
client.write("</html>");
//Publier le contenu du fichier sur une page WEB
boolean PublierFichier(char* filename,EthernetClient client)
//Ouvrir le fichier
myFile = SD.open(filename,FILE_READ);
if (myFile) {
Serial.print("Affichage du fichier ");
Serial.println(filename);
// read from the file until there's nothing else in it:
while (myFile.available()) {
client.write(myFile.read());
//client.println((char)myFile.read());
// close the file:
myFile.close();
else {
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
client.println("</body>");
client.println("</html>");
return true;
Further more, when I uncomment those 2 lines :
client.write(path);
Only 2 files appears ... It's really bizarre
Is somebody have an idea of what is wrong in my source code ?
Thanks
Adrien
