problem by uploading programs
Hello programs from the Internet I do not know I'm listing exit status 1. why? Help me.
ballscrewbob could say
Thank you very much for helping me keep doing nothing
but, he probably won't. :slight_smile:
When you encounter an error you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button. Paste the error in a message here using code tags (</> button on the forum toolbar).
“exit status 1” is just a very generic error that only tells you something went wrong. There are an infinite number of potential causes. You need to scroll up the black console window at the bottom of the Arduino IDE window to see the more specific error message that will tell you what is wrong.
Arduino: 1.8.5 (Windows 7), Vývojová doska:“Arduino/Genuino Uno”
sketch_dec30c:12: error: stray ‘\304’ in program
void sluÄŤka () {
sketch_dec30c:12: error: stray ‘\215’ in program
sketch_dec30c:23: error: stray ‘\303’ in program
int teplota = analógové čítanie (pin);
sketch_dec30c:23: error: stray ‘\263’ in program
sketch_dec30c:23: error: stray ‘\251’ in program
sketch_dec30c:23: error: stray ‘\304’ in program
sketch_dec30c:23: error: stray ‘\215’ in program
sketch_dec30c:23: error: stray ‘\255’ in program
sketch_dec30c:25: error: stray ‘\303’ in program
plavákové napätie = teplota * 5,0;
sketch_dec30c:25: error: stray ‘\241’ in program
sketch_dec30c:25: error: stray ‘\251’ in program
sketch_dec30c:25: error: stray ‘\244’ in program
sketch_dec30c:26: error: stray ‘\303’ in program
napätie = napätie / 1024,0;
sketch_dec30c:26: error: stray ‘\244’ in program
sketch_dec30c:27: error: stray ‘\303’ in program
návrat ((napätie - 0,5) * 100);
sketch_dec30c:27: error: stray ‘\241’ in program
sketch_dec30c:27: error: stray ‘\244’ in program
sketch_dec30c:30: error: stray ‘\303’ in program
návrat (temp * 9/5) + 32;
sketch_dec30c:30: error: stray ‘\241’ in program
sketch_dec30c:36: error: stray ‘\303’ in program
neplatné nastavenie ()
sketch_dec30c:36: error: stray ‘\251’ in program
sketch_dec30c:40: error: stray ‘\304’ in program
void sluÄŤka ()
sketch_dec30c:40: error: stray ‘\215’ in program
sketch_dec30c:42: error: stray ‘\303’ in program
int hodnota = analógové čítanie (inPin); // prečítajte hodnotu zo snímača
sketch_dec30c:42: error: stray ‘\263’ in program
sketch_dec30c:42: error: stray ‘\251’ in program
sketch_dec30c:42: error: stray ‘\304’ in program
sketch_dec30c:42: error: stray ‘\215’ in program
sketch_dec30c:42: error: stray ‘\255’ in program
sketch_dec30c:1: error: expected unqualified-id before ‘<’ token
// zahrĹ?te kĂłd kniĹľnice #include
C:\Users\Hrotko Attila\Documents\Arduino\sketch_dec30c\sketch_dec30c.ino: In function ‘void setup()’:
sketch_dec30c:10: error: ‘lcd’ was not declared in this scope
lcd.begin (16, 2);
C:\Users\Hrotko Attila\Documents\Arduino\sketch_dec30c\sketch_dec30c.ino: At global scope:
sketch_dec30c:12: error: expected initializer before ‘ka’
void sluÄŤka () {
C:\Users\Hrotko Attila\Documents\Arduino\sketch_dec30c\sketch_dec30c.ino: In function ‘int get_temperature(int)’:
sketch_dec30c:23: error: ‘anal’ was not declared in this scope
sketch_dec30c:25: error: ‘plav’ was not declared in this scope
sketch_dec30c:26: error: ‘nap’ was not declared in this scope
sketch_dec30c:27: error: ‘n’ was not declared in this scope
C:\Users\Hrotko Attila\Documents\Arduino\sketch_dec30c\sketch_dec30c.ino: In function ‘int celsius_to_fahrenheit(int)’:
sketch_dec30c:30: error: ‘n’ was not declared in this scope
sketch_dec30c:31: error: expected unqualified-id before ‘<’ token
} </ P>
sketch_dec30c:34: error: ‘LiquidCrystal’ does not name a type
LiquidCrystal lcd (12, 11, 5, 4, 3, 2); // Digitálne kolíky, ku ktorým pripojíte LCD
sketch_dec30c:36: error: ‘neplatn’ does not name a type
sketch_dec30c:40: error: expected initializer before ‘ka’
void sluÄŤka ()
exit status 1
Táto správa by mala mať viac informácií v
“Zobrazenie podrobného výstupu pri kompilácii”
podľa zapnutá voľba v Súbor → Nastavenia.
stray '\215' in programand other similar errors
At a guess you copied the program from a Web page and have included a lot of Unicode (2 byte) characters the the IDE does not understand. Until these are sorted out you will get nowhere
Where did you get the code from ?
I do not know. Please detail. Why do I give wrong Internet programs?
@atilka25 please stop posting basic variations of the same question in different parts of the forum, and start answering the questions people are asking you.
@atilka25
You cannot use SK characters in source code for names. Compiler does not understand to it. You have to rewrite it without diacritical marks.
"Bez dĺžňov a mäkčeňov." :slight_smile:
atilka25:
there are forums for different languages.
it might help to cut though any language barriers.
go to the main forum page and scroll all the way down
