Problem calling the TimerOne library from my Charlieplex library
This is Charlieplex.cpp (I have removed most of the code):
#include "Arduino.h"
#include "Charlieplex.h"
Charlieplex::Charlieplex(char* p, char n)
  CharlieIntensity = 0;
// Equivalent to digitalWrite, but for a virtual pin
void Charlieplex::wled(int p, char v)
  CharlieMode[p] = v;
// Equivalent to digitalRead, but for a virtual pin
byte Charlieplex::rled(int p)
  return CharlieMode[p];
// Turns off all LEDS
void Charlieplex::reset()
  int i;
  for(i = 0; i < CharlieNum * 2; i++) CharlieMode[i] = LOW;
// Turns on all LEDS
void Charlieplex::set()
  int i;
  for(i = 0; i < CharlieNum * 2; i++) CharlieMode[i] = HIGH;
void Charlieplex::intensity(unsigned char v)
  CharlieIntensity = 7 - v;
// Starts Charlieplex, with interval p microseconds between updates
// (p * 1-8) if using intensity
void Charlieplex::start(int p)
  Timer1.initialize(400);
  Timer1.attachInterrupt(IntrCharlieplex);
// Stops Charlieplex
void Charlieplex::stop()
  Timer1.stop();
// Interrupt routine, not called by user
void Charlieplex::IntrCharlieplex()
This is Charlieplex.h:
#ifndef CHARLIEPLEX_h
#define CHARLIEPLEX_h
#if defined(ARDUINO) && ARDUINO >= 100
#else
  #include "WProgram.h"
#endif
#include <TimerOne.h>
class Charlieplex {
  public:
    Charlieplex(char *p, char n);
    void wled(int p, char v);
    byte rled(int p);
    void reset();
    void set();
    void intensity(unsigned char v);
    void start(int p);
    void stop();
  private:
    void IntrCharlieplex();
    int CharlieCurrent;
    byte CharlieNum;
    int CharlieState;
    byte CharlieIntensity;
    byte CharliePins[20];
    byte CharliePairs[380][2];
    byte CharlieMode[380];
#endif
And this is the sketch:
#include <Charlieplex.h>
// Array of pin numbers
char pins[3] = { 11, 12, 13 };
Charlieplex charlieplex(pins, 3);
  char i;
  // If using intensity, periods of > about 400
  // will cause the LEDS to flicker
  charlieplex.start(400);
  for(i = 0; i < 8; i++) {
    // 0 = dim, 7 = full on
    charlieplex.intensity(i);
    charlieplex.set();
    charlieplex.reset();
  charlieplex.intensity(7);
char val;
  int i;
  charlieplex.rled(3);
  for(i = 0; i < (3 * 2); i++) charlieplex.wled(i, (val >> i) & 1);
  val++;
  if(val >= 60) val = 0;
The error I get is:
H:\My Documents\Arduino\libraries\Charlieplex\Charlieplex.cpp: In member function ‘void Charlieplex::start(int)’:
H:\My Documents\Arduino\libraries\Charlieplex\Charlieplex.cpp:60: error: ‘Timer1’ was not declared in this scope
H:\My Documents\Arduino\libraries\Charlieplex\Charlieplex.cpp: In member function ‘void Charlieplex::stop()’:
H:\My Documents\Arduino\libraries\Charlieplex\Charlieplex.cpp:67: error: ‘Timer1’ was not declared in this scope
I can’t work out how to fix this. :sweat_smile:
I can't work out how to fix this.
The same way everyone else does. Quit trying to hide the use of a library from the sketch. Any library used MUST be included in the sketch, too.
Thanks. That fixed it - gave me another error, but there you go.
I wonder where you could help on that one.
