Problem camera LinkSprite
I go the camera http://www.sparkfun.com/products/10061 and when I bought it works but now I don't know what is going on.
I followed the manual, I tried two example of code but nothing.
I downloaded this script http://www.linksprite.com/download/showdownload.php?id=70&lang=en and I tried to see if after the reset comand I get the right response:
Command (HEX)
56 00 26 00
Return (HEX)
76 00 26 00
I sent the reset but what I got is a result with lot of HEX that there isn't the number 76
I am thinking that my camera is broken or something like that.
I have buied the same camera.
I have success to run code, but i dont see jpeg file.
Format is invalid.
/* Linksprite */
#include <SoftwareSerial.h>
 #include <SD.h>
byte incomingbyte;
SoftwareSerial mySerial(6,7);                     //Configure pin 4 and 5 as soft serial port
//NewSoftSerial mySerial(6,7);                     //Configure pin 4 and 5 as soft serial port
int a=0x0000,j=0,k=0,count=0;                    //Read Starting address
uint8_t MH,ML;
boolean EndFlag=0;
void SendResetCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
File imgFile, imgFile2, imgFile3, imgFile4;
  Serial.begin(38400);
  mySerial.begin(38400);
   pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
     SendResetCmd();
     delay(4000);             //After reset, wait 2-3 second to send take picture command
     imgFile = SD.open("nic20.jpg", FILE_WRITE);
     imgFile2 = SD.open("nic21.jpg", FILE_WRITE);
     imgFile3 = SD.open("nic22.jpg", FILE_WRITE);
     imgFile4 = SD.open("nic23.jpg", FILE_WRITE);
      SendTakePhotoCmd();
     while(mySerial.available()>0)
        incomingbyte=mySerial.read();
      byte a[32];
      while(!EndFlag)
         j=0;
         k=0;
         count=0;
         SendReadDataCmd();
         delay(25);
               k++;
               if((k>5)&&(j<32)&&(!EndFlag))
               a[j]=incomingbyte;
               if((a[j-1]==0xFF)&&(a[j]==0xD9))      //Check if the picture is over
               EndFlag=1;
               j++;
	       count++;
          for(j=0;j<count;j++)
          {   if(a[j]<0x10)
              Serial.print("0");
              Serial.print(a[j],HEX);
              imgFile.print(a[j],HEX);
              imgFile2.write(byte(a[j]));
              //imgFile3.print(byte(a[j]));              sembra sbagliato
              //imgFile4.print(a[j]);              sembra sbagliato
              Serial.print(" ");
          }                                       //Send jpeg picture over the serial port
     imgFile.close();
     imgFile2.close();
     imgFile3.close();
     imgFile4.close();
     while(1);
//Send Reset command
void SendResetCmd()
      mySerial.write(0x56);
      mySerial.write(byte(0x00));
      mySerial.write(0x26);
//Send take picture command
      mySerial.write(0x36);
      mySerial.write(0x01);
//Read data
      MH=a/0x100;
      ML=a%0x100;
      mySerial.write(0x32);
      mySerial.write(0x0c);
      mySerial.write(0x0a);
      mySerial.write(MH);
      mySerial.write(ML);
      mySerial.write(0x20);
      a+=0x20;                            //address increases 32£¬set according to buffer size
      mySerial.write(0x03);
My issue was the operation system, I was using Linux and I couldn't run the script.
I have made this article that may be can help you: Projects of max246: Issue with Linksprite and Linux
contecavour is saving data directly to SD, but probably it is not fast enought, and he loose some data from serial
I never had this kind of problem :slight_smile:
i have founf an error in manual.
I must descrt other 5byte after 32byte of data.
#include <SD.h>
byte incomingbyte;
uint8_t MH,ML;
boolean EndFlag=0;
void HiRes();
void MiRes();
void LoRes();
void ImageSize();
void Speed9600();
void Speed38400();
void Speed115200();
File imgFile;
char buffer[20];
uint8_t i;
int led = 9;
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
  SD.begin(4);
     //Speed38400();
     //delay(1000);
     MiRes();
     delay(100);
     SendResetCmd();
     delay(1000);             //After reset, wait 2-3 second to send take picture command
     strcpy(buffer, "NICJPG00.JPG");
     for (i = 0; i < 100; i++) {
        buffer[6] = '0' + i/10;
        buffer[7] = '0' + i%10;
        // create if does not exist, do not open existing, write, sync after write
        if (! SD.exists(buffer)) {
     imgFile = SD.open(buffer, FILE_WRITE);
     digitalWrite(led, HIGH);
     SendTakePhotoCmd();
      byte a[32];
     while(!EndFlag)
         j=0;
         k=0;
         count=0;
         SendReadDataCmd();
         delay(35); //con tempi piu bassi sembrano esserci piu errori
               k++;
               if((k>5)&&(j<37)&&(!EndFlag)) //portato a 37 e scarto gli ultimi 5
                 if (j<32)
                  a[j]=incomingbyte;
                  EndFlag=1;
	          count++;
               j++;
//              if(a[j]<0x10)
//                Serial.print("0");
//              Serial.print(a[j],HEX);
              imgFile.write(byte(a[j]));     //il piu vicino ai jpeg
              // trovato anche così imgFile.write((char*)a);
//              Serial.print(" ");
//          Serial.println();
          //delay(25);
     imgFile.close();
     while(1);
void SendResetCmd()
//Read data
      MH=a/0x100;
      ML=a%0x100;
      mySerial.write(MH);
      mySerial.write(ML);
void HiRes()
      mySerial.write(0x31);
      mySerial.write(0x05);
      mySerial.write(0x04);
      mySerial.write(0x19);
void LoRes()
      mySerial.write(0x22);
void MiRes()
      mySerial.write(0x11);
void ImageSize()
      mySerial.write(0x34);
void Speed9600()
      mySerial.write(0x24);
      mySerial.write(0xAE);
      mySerial.write(0xC8);
void Speed38400()
      mySerial.write(0x2A);
      mySerial.write(0xF2);
void Speed115200()
      mySerial.write(0x0D);
      mySerial.write(0xA6);
