Problem combining color sensor and temperature sensor program
Hello everyone,
this is my first question on this forum. I'm currently participating in a contest named Cansat. We have to make a satellite with the size of a soda can. I'm now working on the programming of our satellite, but I'm experiencing a problem.
I have two programs: one for a BMP200 sensor, which measures the air temperature and the air pressure and the other program is for a TCS230 color sensor, which measures the RGB values. Both sensors have to send their data wireless back to our ground station. If I use each program separate from each other, they work perfect, but when I combine them, the data only comes through to our ground station when I turn the satellite off, not every second as it is supposed to do.
This is my code:
#include <SoftwareSerial.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP2800.h>
#define S0 5
#define S1 4
#define S2 1
#define S3 6
#define sensorOut 7
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
// Stores frequency read by the photodiodes
int redFrequency = 0;
int greenFrequency = 0;
int blueFrequency = 0;
SoftwareSerial mySerial(10,11);//RX, TX
int number = 0;
//Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO,  BMP_SCK);
  // Setting the outputs
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  // Setting the sensorOut as an input
  pinMode(sensorOut, INPUT);
 // Setting frequency scaling to 20%
  digitalWrite(S0,HIGH);
  digitalWrite(S1,LOW);
mySerial.begin(9600);
mySerial.println(F("BMP280 test"));
if (!bmp.begin()) {
    mySerial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
    while (1);
 // Setting RED (R) filtered photodiodes to be read
  digitalWrite(S2,LOW);
  digitalWrite(S3,LOW);
  // Reading the output frequency
  redFrequency = pulseIn(sensorOut, LOW);
   // Printing the RED (R) value
  mySerial.print("R = ");
  mySerial.print(redFrequency);
  delay(100);
  // Setting GREEN (G) filtered photodiodes to be read
  digitalWrite(S2,HIGH);
  digitalWrite(S3,HIGH);
  greenFrequency = pulseIn(sensorOut, LOW);
  // Printing the GREEN (G) value
  mySerial.print(" G = ");
  mySerial.print(greenFrequency);
  delay(100);
  // Setting BLUE (B) filtered photodiodes to be read
  blueFrequency = pulseIn(sensorOut, LOW);
  // Printing the BLUE (B) value
  mySerial.print(" B = ");
  mySerial.println(blueFrequency);
  delay(100);
    mySerial.print(F("Temperature = ")); //Woordje 'temperature' doorgeven
    mySerial.print(bmp.readTemperature()); //gemeten temperatuur doorgeven
    mySerial.println(" *C"); //graden celsius teken erachter zetten
    mySerial.print(F("Pressure = ")); //Woordje 'pressure' doorgeven
    mySerial.print(bmp.readPressure()); //gemeten luchtdruk doorgeven
    mySerial.println(" Pa"); //Pascal erachter zetten
    mySerial.print(F("Approx altitude = ")); //Woordje 'Approx altitude' doorgeven
    mySerial.print(bmp.readAltitude(1023.75)); // this should be adjusted to your local forcase
    mySerial.println(" m");
    mySerial.println();
  delay(500);                  //1 second delay
I hope somebody can help me with this question (ps. sorry if my English is bad :b)
Welcome to the forum.
What model Arduino are you using?
#define S0 5
#define S1 4
#define S2 1
#define S3 6
If these are your output pins, pin 1 is one of the two programming pins. It is used when you serially communicate with the outside world.
This will explain your problem.
Can you post the two codes that worked before you combined them?
I'm using the arduino uno Rev3.
The codes are:
#include <Wire.h>
#include <SPI.h>
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
int number = 0;
if (!bmp.begin()) {
    while (1);
    mySerial.println();
  delay(1000);                  //1 second delay
and
#define S0 5
#define S1 4
#define S2 1
#define S3 6
#define sensorOut 7
   // Begins serial communication
  delay(100);
  delay(100);
  delay(100);
Did you write these codes yourself?
Have read my comment about
#define S2 1
And what pin 1 is?
Tom... :slight_smile:
One of the codes was included with a file from the contest itself. I found the code for the color sensor on the internet.
I don't now exactly what you mean with the pin 1 thing??
Mika
#define S2 1
Assigns to value of 1 to a variable called S2.
Then you have this statement in setup;
This assigns pin 1 as an OUTPUT, however pin 1 is one of the pins along with pin 0 that is used for programming.
You need to give S2 another pin value and change you circuit accordingly.
PS, do you have teachers/instructors that can help teach you to code?
Hi Tom,
I have now connected the cable that was connected to pin 1 to pin 2 and I have changed the code for it. I have tested it and I stil have the same problem: I only get the data when I turn off the arduino.
I don't have any teachers that can help me with this, because they only know how to support us with the contest :b.
Mika
Okay, post your new combined code please.
Also post a circuit diagram please.
Hi Tom,
The code i'm now using:
#include <Wire.h>
#include <SPI.h>
#define S0 5
#define S1 4
#define S2 2
#define S3 6
#define sensorOut 7
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
int number = 0;
if (!bmp.begin()) {
    while (1);
  delay(100);
  delay(100);
  delay(100);
    mySerial.println();
I'm going to work on a diagram, but it's going to take me a minute.
Mika
Where do you get;
Library from?
Your code has too many { and }.
I have commented them out so you can see where your problems could have been.
It compiles, but only you can say if it runs.
#include <Wire.h>
#include <SPI.h>
//#include <Adafruit_BMP2800.h>
#define S0 5
#define S1 4
#define S2 2
#define S3 6
#define sensorOut 7
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
SoftwareSerial mySerial(10, 11); //RX, TX
int number = 0;
  digitalWrite(S0, HIGH);
  digitalWrite(S1, LOW);
  if (!bmp.begin()) {
    while (1);
  digitalWrite(S2, LOW);
  digitalWrite(S3, LOW);
  delay(100);
  digitalWrite(S2, HIGH);
  digitalWrite(S3, HIGH);
  delay(100);
  delay(100);
  mySerial.println();
Now that you've got pins zero and one available, I'd start using Serial.print to see how far your sketch gets.
If you no-joy with the current setup, maybe a different approach will work:
#include <Wire.h>
#include <SPI.h>
#define S0 5
#define S1 4
#define S2 2
#define S3 6
#define sensorOut 7
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
int number = 0;
    if( !bmp.begin() )
        while (1);
    }//if
}//setup
bool ReadPhotoDiodes()
    static byte
        stateDiodes = DIODE_RED;
    unsigned long
        timeNow;
    static unsigned long
        timeDiode = 0,
        timeDiodeDly = 0;
    timeNow = millis();
    if( (timeNow - timeDiode) < timeDiodeDly )
        return;
    switch( stateDiodes )
        case    DIODE_RED:
            digitalWrite(S2,LOW);   // Setting RED (R) filtered photodiodes to be read
            redFrequency = pulseIn(sensorOut, LOW); // Reading the output frequency
            timeDiode = millis();
            timeDiodeDly = 100;
            stateDiodes = DIODE_GREEN;
            return false;
        case    DIODE_GREEN:
            digitalWrite(S2,HIGH);  // Setting GREEN (G) filtered photodiodes to be read
            greenFrequency = pulseIn(sensorOut, LOW);   // Reading the output frequency
            timeDiodeDly = 100;
            stateDiodes = DIODE_BLUE;
            return false;
        case    DIODE_BLUE:
            digitalWrite(S2,LOW);   // Setting BLUE (B) filtered photodiodes to be read
            blueFrequency = pulseIn(sensorOut, LOW);    // Reading the output frequency
            timeDiodeDly = 100;
            stateDiodes = DIODE_REPORT_RSLTS;
            return false;
        case    DIODE_REPORT_RSLTS:
            //print RED (R) value
            //print GRN (G) value
            //print BLU (B) value
            mySerial.print(blueFrequency);
            timeDiodeDly = 0;
            return true;
    }//switch
}//ReadPhotoDiodes
void ReadWXFactors( void )
    mySerial.println();
}//ReadWXFactors
        timeThen = millis();
    timeNow = millis();
    if( (timeNow - timeThen) >= 1000 )
        timeThen = timeNow;
        //read all the diodes at once; done when reports are printed
        while( !ReadPhotoDiodes() );
        ReadWXFactors();
    }//if
}//loop
Hello everyone,
Thanks for all your replies. I have tried the script without to many { and } and I have tried the different approach.
The script with too many { and } won't compile in my case.
With the different approach I get an error message that says: 'DIODE RED' was not declared in this scope in this line:
    static byte
Sorry. Add the following near the top of the program, after the includes:
#define DIODE_RED               0
#define DIODE_GREEN             1
#define DIODE_BLUE              2
#define DIODE_REPORT_RSLTS      3
I now get this error message: timeNow was not declared in this scope.
    timeNow = millis();
        timeThen = timeNow;
        ReadWXFactors();
    }//if
Mikado_03:
Hello everyone,
This is my code:
#include <Wire.h>
#include <SPI.h>
#define S0 5
#define S1 4
#define S2 1
#define S3 6
#define sensorOut 7
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
int number = 0;
if (!bmp.begin()) {
    while (1);
  delay(100);
  delay(100);
  delay(100);
mySerial.println();
Can somebody help me please, the contest is in 2 days...
See if this helps get you closer. I left the 100mS delays between reads in; not sure if you had a reason for that but it shouldn't affect the 1-second timing.
#include <Wire.h>
#include <SPI.h>
#define S0 5
#define S1 4
#define S2 1
#define S3 6
#define sensorOut 7
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 9
#define BMP_CS 8
int number = 0;
    mySerial.println( F("BMP280 test") );
    if (!bmp.begin())
        while (1);
    }//if
}//setup
        timeLoop = 0;
    unsigned long
        timeNow;
    timeNow = millis();
    if( (timeNow - timeLoop) <= 1000 )
        return;
    timeLoop = timeNow;
    redFrequency = pulseIn( sensorOut, LOW );
    mySerial.print( F("R = ") ); mySerial.print(redFrequency);
    delay(100);
    greenFrequency = pulseIn( sensorOut, LOW );
    mySerial.print( F(" G = ") ); mySerial.print(greenFrequency);
    delay(100);
    mySerial.print( F(" B = ") ); mySerial.println(blueFrequency);
    mySerial.print( F("Temperature = ") ); //Woordje 'temperature' doorgeven
    mySerial.println();
}//loop
Hey,
thanks for your answer. I now only get the "BMP280 test'' line through. The rest still only comes through when I turn off the arduino.
