Hello,
I have a problem regarding combining the code for LIDAR and GPS. The name/type of components I am using is tf-Luna for LIDAR and a neo-6M GPS module. I've tested both of the codes individually with their respective component, and it works fine. Both of them could produce readings that I want onto the serial monitor. But when I tried combining the two codes, only the data from GPS comes up and not the distance reading from the LIDAR. I've read up about SoftwareSerial and the limitations of it is that only one can receive data at a time when using multiple software serial ports. I wonder if it is related to my problem but I got confused of it instead. Is there a way to get both readings from the LIDAR and GPS to show up on serial monitor?
Here is the code:
[code]
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
TinyGPSPlus tinyGPS;
#define GPS_BAUD 9600
#define gpsPort ssGPS
#define ARDUINO_GPS_RX 4
#define ARDUINO_GPS_TX 3
#define ARDUINO_lidar_RX 10
#define ARDUINO_lidar_TX 11
SoftwareSerial ssGPS(ARDUINO_GPS_TX, ARDUINO_GPS_RX);
SoftwareSerial ssLidar(ARDUINO_lidar_RX,ARDUINO_lidar_TX);
int dist;
int check;
int i;
int uart[9];
const int HEADER=0x59;
ssLidar.begin(115200);
gpsPort.begin(GPS_BAUD);
if (ssLidar.available()) {
if(ssLidar.read() == HEADER) {
uart[0]=HEADER;
if (ssLidar.read() == HEADER) {
uart[1] = HEADER;
for (i = 2; i < 9; i++) {
uart[i] = ssLidar.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)){
dist = uart[2] + uart[3] * 256;
Serial.print("Lidar distance = ");
Serial.println(dist);
printGPSInfo();
smartDelay(1000);
void printGPSInfo()
Serial.print("Lat: "); Serial.println(tinyGPS.location.lat(), 6);
Serial.print("Long: "); Serial.println(tinyGPS.location.lng(), 6);
Serial.print("Alt: "); Serial.println(tinyGPS.altitude.feet());
Serial.print("Course: "); Serial.println(tinyGPS.course.deg());
Serial.print("Speed: "); Serial.println(tinyGPS.speed.mph());
Serial.print("Date: "); printDate();
Serial.print("Time: "); printTime();
Serial.print("Sats: "); Serial.println(tinyGPS.satellites.value());
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (gpsPort.available())
tinyGPS.encode(gpsPort.read());
} while (millis() - start < ms);
void printDate()
Serial.print(tinyGPS.date.day());
Serial.print("/");
Serial.print(tinyGPS.date.month());
Serial.print("/");
Serial.println(tinyGPS.date.year());
void printTime()
Serial.print(tinyGPS.time.hour());
Serial.print(":");
if (tinyGPS.time.minute() < 10) Serial.print('0');
Serial.print(tinyGPS.time.minute());
Serial.print(":");
if (tinyGPS.time.second() < 10) Serial.print('0');
Serial.println(tinyGPS.time.second());
[/code]
Here is the reading from the serial Monitor. Lidar distance does not show up here:
Lat: 0.000000
Long: 0.000000
Alt: 0.00
Course: 0.00
Speed: 0.00
Date: 0/0/2000
Time: 0:00:00
Sats: 0
