Problem Combining Multiple Codes
Having problems joining these three codes in to one.
Keeping getting changeLED not declared in scope error message. I am completely new to this, so I am using codes found on the internet that I have edited.
My Try at Joining
int led = 2;
int led1 = 3;
int led2 = 4;
int led3 = 5;
int led4 = 6;
int led5 = 7;
int led6 = 8;
long heartBeatArray[] = {
  50, 100, 15, 1200 };
int hbeatIndex = 1;   // this initialization is important or it starts on the "wrong foot"
long prevMillis;
byte ledPin[] = {2, 3, 4, 6, 7, 8}; // Create array for LED pins
int ledDelay = 65; // delay between changes
int direction = 1;
int currentLED = 0;
unsigned long changeTime;
  pinMode(led, OUTPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(led6, OUTPUT);
  for (int x = 0; x < 10; x++) { // set all pins to output
    pinMode(ledPin[x], OUTPUT);
  changeTime = millis();
    digitalWrite(led3, HIGH);// turn the LED on (HIGH is the voltage level                       // wait for a second
    digitalWrite(led2, HIGH);    // turn the LED off by making the voltage LO                       // wait for a second
    digitalWrite(led4, HIGH);   // turn the LED on (HIGH is the voltage level)
    digitalWrite(led2, LOW);
    digitalWrite(led4, LOW);// turn the LED on (HIGH is the voltage level                       // wait for a second
    digitalWrite(led4, HIGH);// turn the LED on (HIGH is the voltage level                       // wait for a second
    digitalWrite(led1, HIGH);    // turn the LED off by making the voltage LO                       // wait for a second
    digitalWrite(led5, HIGH);// turn the LED off by making the voltage LOW
    digitalWrite(led1, LOW);    // turn the LED off by making the voltage LO                       // wait for a second
    digitalWrite(led5, LOW);
    digitalWrite(led, HIGH);    // turn the LED off by making the voltage LO                       // wait for a second
    digitalWrite(led6, HIGH);// turn the LED on (HIGH is the voltage level)
    digitalWrite(led, LOW);    // turn the LED off by making the voltage LO                       // wait for a second
    digitalWrite(led6, LOW);// turn the LED on (HIGH is the voltage level)
    delay(500); // wait for a second
    if ((millis() - changeTime) > ledDelay) { // if it has been ledDelay ms since last change
      changeLED();
  void changeLED() {
    for (int x = 0; x < 10; x++) { // turn off all LED's
      digitalWrite(ledPin[x], LOW);
    digitalWrite(ledPin[currentLED], HIGH); // turn on the current LED
    currentLED += direction; // increment by the direction value
    // change direction if we reach the end
    if (currentLED == 7) {
      direction = -1;
    if (currentLED == 0) {
      direction = 1;
    heartBeat(1.5);   // try changing the parameter
  void heartBeat(float tempo) {
    if ((millis() - prevMillis) > (long)(heartBeatArray[hbeatIndex] * tempo)) {
      hbeatIndex++;
      if (hbeatIndex > 3) hbeatIndex = 0;
      if ((hbeatIndex % 2) == 0) {
        delay((int)heartBeatArray[hbeatIndex]) ;
        digitalWrite(led3, LOW);
      hbeatIndex++;
      // Serial.println(hbeatIndex);
      prevMillis = millis();
Any help greatly appreciated, its for university project. Thanks
In C/C++ you can't declare a function inside another function. You have the changeLED and heartBeat functions inside the loop() function. Move them so that they are outside it.
Pete
