Hi,everyone I am working on a project which works as a mixer of Hot and Cold water at proper temperature and discharge it at set flow rate.The problem which i am facing is that when the arduino commands the motor to open or close the ball valve at that time the water flow sensor shows variable results.My code is using water sensor flow rate value to set the position of motorised ball valve and due to wrong value output from water flow sensor the arduino runs the wrong if statement.
I am unable to figure out why this is happening ,so i request everyone to help me with my code..thanks in advance..
apologies for my bad english
#include <OneWire.h> //one wire library add
#include <DallasTemperature.h> //dallas library add
#define ONE_WIRE_BUS 12 //one wire port declaration
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
int speed;
// Motor 1
int dir1PinA = 17;
int dir2PinA = 16;
int speedPinA = 5; // Needs to be a PWM pin to be able to control motor speed
// Motor 2
int dir1PinB = 15;
int dir2PinB = 14;
int speedPinB = 6; // Needs to be a PWM pin to be able to control motor speed
int sensVal;
unsigned int flowSpeed; //declaring variable for flow speed
//water flow sensor
volatile int flow_frequency; // Measures flow sensor pulses
unsigned int l_min; // Calculated litres/min
unsigned char flowsensor = 2; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
flow_frequency++;
int minFlowRate=3;
//declaring water flow range
int maxFlowRate=5;
int minTemp=28;
//declarring water temp range
int maxTemp=30;
int Unidelay=1000;
int mot1delay=50;
int mot2delay=200;
pinMode(flowsensor, INPUT);
digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
pinMode(dir1PinA,OUTPUT);
pinMode(dir2PinA,OUTPUT);
pinMode(speedPinA,OUTPUT);
pinMode(dir1PinB,OUTPUT);
pinMode(dir2PinB,OUTPUT);
pinMode(speedPinB,OUTPUT);
analogWrite(speedPinB, 255);
digitalWrite(dir1PinB, LOW);
digitalWrite(dir2PinB, HIGH);//motor 2 reverse
delay(4000);
digitalWrite(dir2PinB, LOW); //motor 2 stop
analogWrite(speedPinA, 255);
digitalWrite(dir1PinA, HIGH);
digitalWrite(dir2PinA, LOW);//motor 1 reverse
delay(4000);
digitalWrite(dir1PinA, LOW);
digitalWrite(dir2PinA, LOW); // motor 1 stop
sensors.begin();
attachInterrupt(0, flow, FALLING); // Setup Interrupt
sei(); // Enable interrupts
currentTime = millis();
cloopTime = currentTime;
// Every second, calculate and print litres/hour
if(currentTime = (cloopTime + 1000))
cloopTime = currentTime; // Updates cloopTime
// Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
l_min = (flow_frequency / 3.50); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
flow_frequency = 0; // Reset Counter
Serial.print(l_min, DEC); // Print litres/min
Serial.println(" L/min");
unsigned int flowSpeed = l_min ; //setting flowSpeed equals to output of water flow sensor
sensors.requestTemperatures(); // Send the command to get temperatures
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
int sensVal= (sensors.getTempCByIndex(0)); //declaring variable for sensor reading
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(sensVal);
if((sensVal>=minTemp && sensVal<=maxTemp) && (flowSpeed>=minFlowRate && flowSpeed<=maxFlowRate)){
digitalWrite(dir1PinA, LOW); //motor 1 stop
Serial.println("1 STOP");
digitalWrite(dir2PinB, LOW);//motor 2 stop
Serial.println("2 STOP");
Serial.println("TEMP AND FLOW RATE STABLE");
delay(200);
else if((sensVal>maxTemp) && (flowSpeed<minFlowRate)) {
digitalWrite(dir1PinB, HIGH);
digitalWrite(dir2PinB, LOW);//motor 2 forward
delay(mot2delay);
Serial.println("2 forward");
Serial.println("statement 2");
else if ((sensVal>maxTemp) && (flowSpeed>maxFlowRate)) {
digitalWrite(dir2PinA,LOW);//motor 1 reverse
delay(mot1delay);
digitalWrite(dir2PinA,LOW); //motor 1 stop
Serial.print("1 reverse");
Serial.println("statement new 1");
delay(Unidelay);//wait sensor to stablize
else if((sensVal<minTemp ) && (flowSpeed<minFlowRate)) {
digitalWrite(dir2PinA, HIGH);//motor 1 forward
delay(mot1delay);
Serial.println("1 forward");
digitalWrite(dir1PinA, LOW);//motor 1 stop
//analogWrite(speedPinB, 200);
//digitalWrite(dir1PinB, HIGH);
//digitalWrite(dir2PinB, LOW);//motor 2 forward
//delay(mot2delay);
//Serial.println("2 forward");
Serial.println("statement 3");
//digitalWrite(dir1PinB, LOW);//motor 2 stop
else if((sensVal<minTemp)&&(flowSpeed>maxFlowRate)) {
delay(mot2delay);
Serial.println("2 reverse");
Serial.println("statement 2 new");
else if((sensVal<minTemp)&&(flowSpeed>=minFlowRate && flowSpeed<=maxFlowRate)) {
delay(mot1delay);
delay(100);
Serial.println("statement 4");
else if((sensVal>maxTemp) && (flowSpeed>=minFlowRate && flowSpeed<=maxFlowRate)) {
delay(mot2delay);
delay(mot1delay);
Serial.println("1 reverse");
Serial.println("statement 5");
else if((sensVal>=minTemp && sensVal<=maxTemp) && (flowSpeed<minFlowRate)) {
delay(mot1delay);
delay(mot2delay);
Serial.println("statement 6");
else if((sensVal>=minTemp && sensVal<=maxTemp) && (flowSpeed>maxFlowRate)) {
delay(mot1delay);
delay(100);
Serial.println("statement 7");
