shreyagrawal_28:
Hi. I am trying to communicate between Arduino and RPi via RS485 bus. But when I try to read data from arduino, nothing is received on the RPi side, it just keeps printing blank spaces.
I have tried with low baudrate as suggested in some posts.
I am using arduino pro mini (Atmega 328).Here is the arduino code.
void setup () {
pinMode(3, OUTPUT); //RS485 pin
delay(50);
digitalWrite(3, LOW); //Enabling in receive mode
Serial.begin(4800);
delay(100);
if (Serial.available())
digitalWrite(3, HIGH); //Enabling transmit
delay(5);
Serial.println('hello');
delay(20);
digitalWrite(3, LOW); //Disabling transmit
delay(5);
Instead of your fixed delays on the write use:
unsigned long deadtime=0;
void loop(){
if(Serial.availabe()){
deadTime = millis(); // require 50ms of inactivity on the bus before switching to TX
char ch=Serial.read(); // do something with the input
else {
if(millis()-deadtime>50){ // serial bus has been inactive for over 50 ms
Serial.flush(); // make sure all data has actually exited the TX pin before switching to RX
digitalWrite(3, LOW); //Disabling transmit back into RX mode
deadTime = millis(); // restart dead counter
It also look like your Arduino code was waiting for a byte from Serial() before it would send?
Chuck.
