My goal is to send the results of four analogRead commands and 4 digitalRead commands. It is two joysticks and some buttons for a remote controlled vehicle so it needs to be transmitting constantly to reduce lag for the controls.
What would be the best way of doing this with NRF24L01 modules? If I load up the Mirf library examples for both the server and client (UNO boards), it works fine and makes a ping of 11ms. I am new to using C programming (used to PICAXE BASIC). If I modify the example programs, I get various variable errors as it appears the module will only send the data after a certain amount of bytes have been received (that you can set).
Who has used these wireless modules and could provide a basic example of sending some data that I could work from.
