Problem Compiling (Arduino Uno + EasyVR shield)
Thank you in advance for the help rendered, I am new to Arduino and programming pardon me if the questions are rather stupid.
I am trying to achieve results similar to the video from this website " Free Porn Videos - Porn ".
I have connected the LED with Negative pin to GND and Positive pin to D11 and the following code is generated from EasyVR Commander.
#include <SoftwareSerial.h>
SoftwareSerial port(12,13);
#include <EasyVR.h>
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_ARDUINO = 0,
enum Group1
  G1_RECORD = 0,
  G1_LED_ON = 1,
  G1_LED_OFF = 2,
EasyVRBridge bridge;
int8_t group, idx;
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(0);
  group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
	// built-in trigger (ROBOT)
	// group = GROUP_X; <-- jump to another group X
	return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_ARDUINO:
        // write your action code here
        // group = GROUP_X; <-- or jump to another group X for composite commands
    case GROUP_1:
      switch (idx)
      case G1_RECORD:
      case G1_LED_ON:
      case G1_LED_OFF:
This is the Error that I've encountered.
ERROR COMPILING
In file included from LED_error.ino:2:
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial/SoftwareSerial.h:52: error: conflicting return type specified for 'virtual void SoftwareSerial::write(uint8_t)'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
Thank you once again.
What version of the IDE are you using? Where is the link to the EasyVR library?
It would appear that the EasyVR library has not been updated for 1.0+ use.
PaulS:
I am using Arduino 1.0.5 & have currently updated the Library with the ones from " https://www.sparkfun.com/products/10963 ".
I have Re-extracted the code from my EasyVR commander 3.4.10 (UPDATED)
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_ARDUINO = 0,
enum Group1
  G1_RECORD = 0,
  G1_LED_ON = 1,
  G1_LED_OFF = 2,
int8_t group, idx;
  // bridge mode?
  if (bridge.check())
    cli();
  // run normally
  port.begin(9600);
    for (;;);
void action();
  do
  if (idx >= 0)
    return;
  if (idx >= 0)
    uint8_t train = 0;
    char name[32];
    Serial.print(idx);
    action();
    if (err >= 0)
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_ARDUINO:
    case GROUP_1:
      switch (idx)
      case G1_RECORD:
      case G1_LED_ON:
      case G1_LED_OFF:
The error have became "SoftwareSerial does not name a type"
LEDTEST.pde:3:30: error: SoftwareSerial.h: No such file or directory
LEDTEST:4: error: 'SoftwareSerial' does not name a type
LEDTEST:12: error: 'port' was not declared in this scope
LEDTEST.pde: In function 'void setup()':
LEDTEST:48: error: 'port' was not declared in this scope
Thank you for your kind help.
