Windows XP Home edition seem not to be able to handle version 1.6.7 ?
I Have tested with both the installer and the "non administrator" version but keep getting an empty g++ path in the -w parameter:
D:\arduino-1.6.7\arduino-builder -dump-prefs -logger=machine -hardware "D:\arduino-1.6.7\hardware" -hardware "C:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages" -tools "D:\arduino-1.6.7\tools-builder" -tools "D:\arduino-1.6.7\hardware\tools\avr" -tools "C:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages" -built-in-libraries "D:\arduino-1.6.7\libraries" -libraries "C:\Documents and Settings\arduino\Dokumenter\Arduino\libraries" -fqbn=AMEL:samd:AMEL_SmartEverything_native -ide-version=10607 -build-path "d:\temp\buildbb21e78fdfd06448249e56083638e7a8.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "D:\arduino-1.6.7\examples\10.StarterKit_BasicKit\p02_SpaceshipInterface\p02_SpaceshipInterface.ino"
D:\arduino-1.6.7\arduino-builder -compile -logger=machine -hardware "D:\arduino-1.6.7\hardware" -hardware "C:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages" -tools "D:\arduino-1.6.7\tools-builder" -tools "D:\arduino-1.6.7\hardware\tools\avr" -tools "C:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages" -built-in-libraries "D:\arduino-1.6.7\libraries" -libraries "C:\Documents and Settings\arduino\Dokumenter\Arduino\libraries" -fqbn=AMEL:samd:AMEL_SmartEverything_native -ide-version=10607 -build-path "d:\temp\buildbb21e78fdfd06448249e56083638e7a8.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "D:\arduino-1.6.7\examples\10.StarterKit_BasicKit\p02_SpaceshipInterface\p02_SpaceshipInterface.ino"
"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_SMARTEVERYTHING -DARDUINO_ARCH_SAMD -D__SAMD21J18A__ "-IC:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages\AMEL\hardware\samd\1.1.0\cores\arduino" "-IC:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages\AMEL\hardware\samd\1.1.0\variants\AMEL_SmartEverything" "d:\temp\buildbb21e78fdfd06448249e56083638e7a8.tmp\sketch\p02_SpaceshipInterface.ino.cpp" -o "nul"
"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_SMARTEVERYTHING -DARDUINO_ARCH_SAMD -D__SAMD21J18A__ "-IC:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages\AMEL\hardware\samd\1.1.0\cores\arduino" "-IC:\Documents and Settings\arduino\Lokale indstillinger\Application Data\Arduino15\packages\AMEL\hardware\samd\1.1.0\variants\AMEL_SmartEverything" "d:\temp\buildbb21e78fdfd06448249e56083638e7a8.tmp\sketch\p02_SpaceshipInterface.ino.cpp" -o "d:\temp\buildbb21e78fdfd06448249e56083638e7a8.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
exec: "-w": executable file not found in %PATH%
Fejl i kompilering.
(Translates from Danish to: Error compiling).
Tested with several build-in examples without any luck.
Could someone point me to the config file, the regedit key or the cause of this error?
If not, which version could I download and use for Windows XP Home edition SP3 32-bit that will work with the SmartEverything FOX module?
Everything works like a dream in Windows 7 Pro and Windows 10.
Thanx in advance
/Niels
