Problem compiling UDPSendRecieveString example with Arduino 1.0.
I just downloaded the 1.0 Linux 32bit version. When I try to compile the example UDPSendRecieveString or the UDPNTPClient both give the same compiler error. error: 'rawIPAddress' was not declared in this scope. Ant suggestions. I have a .pde that works with version .23 and would like to update it to the newer UDP API.
When I try to compile the example UDPSendRecieveString I get this "compiler error":
Binary sketch size: 9194 bytes (of a 30720 byte maximum)
rawIPAddress is not mentioned anywhere.
I have done some more testing and it seems to be a premissions problem. Still unknown why, but it works when accessing as root or using sudo ./arduino. Permissions are the same as arduino 0.23 which work fine with its support files. Will update if I find the problem.
