Problem connect blynk my owner server
#define BLYNK_PRINT Serial
#define RELAY_PIN_1 32  // F1
#define RELAY_PIN_2 33  // F2
#define RELAY_PIN_3 25  // F4 - 3 second hold
#define RELAY_PIN_4 26  // RESET
#define RELAY_PIN_1 V10 // F1
#define RELAY_PIN_2 V11 // F2
#define RELAY_PIN_3 V12 // F4 - 3 second hold
#define RELAY_PIN_4 V13 // RESET
#include <BlynkSimpleEsp32.h>
int wifiFlag = 0;
#define AUTH "Jt******************pVONIkZrZam"   // Blynk token
#define WIFI_SSID "******"               //Enter Wifi
#define WIFI_PASS "*******"           //Enter wifi Password
#define wifiLed   23
BlynkTimer timer;
int pinValue = 0;
// Select your pin with physical button
const int btnPin1 = 21;  // FULL
const int btnPin2 = 19;  // MAX
const int btnPin3 = 5;   // MIN
const int btnPin4 = 16;  // F1  led
const int btnPin5 = 15;  // F2  led
WidgetLED led1(V1);   // FULL led
WidgetLED led2(V2);   // MAX  led
WidgetLED led3(V3);   // MIN  led
WidgetLED led4(V4);   // F1  led
WidgetLED led5(V5);   // F2  led
// LED Widget represents the physical button state
boolean btnState1 = false;
boolean btnState2 = false;
boolean btnState3 = false;
boolean btnState4 = false;
boolean btnState5 = false;
void checkBlynkStatus() {  // called every 3 seconds by SimpleTimer
  bool isconnected = Blynk.connected();
  if (isconnected == false) {
    wifiFlag = 0;
    digitalWrite(wifiLed, LOW); //Turn off WiFi LED
    Serial.println("WiFi Not Connected");
  if (isconnected == true) {
    wifiFlag = 1;
    digitalWrite(wifiLed, HIGH); //Turn on WiFi LED
    Serial.println("WiFi Connected");
  if (WiFi.status() != WL_CONNECTED) {
  bool status = WiFi.status();
  if ( status != WL_CONNECTED) {
    WiFi.reconnect();
    WiFi.begin(WIFI_SSID, WIFI_PASS);
    Serial.println("Try to Connect WiFi");
  // if your relay is HIGH triggering
  if (digitalRead(32) == 1) Blynk.virtualWrite(V10, digitalRead(32));
  else Blynk.syncVirtual(V10);
  if (digitalRead(33) == 1) Blynk.virtualWrite(V11, digitalRead(33));
  else Blynk.syncVirtual(V11);
  if (digitalRead(25) == 1) Blynk.virtualWrite(V12, digitalRead(25));
  else Blynk.syncVirtual(V12);
  if (digitalRead(26) == 1) Blynk.virtualWrite(V13, digitalRead(26));
  else Blynk.syncVirtual(V13);
void buttonLedWidget() {
  // Read button
  boolean isPressed_1 = (digitalRead(btnPin1) == LOW);  // FULL
  boolean isPressed_2 = (digitalRead(btnPin2) == LOW);  // MAX
  boolean isPressed_3 = (digitalRead(btnPin3) == LOW);  // MIN
  boolean isPressed_4 = (digitalRead(btnPin4) == LOW);  // F1  LED
  boolean isPressed_5 = (digitalRead(btnPin5) == LOW);  // F2  LED
  // If state has changed...
  if (isPressed_1 != btnState1) {
    if (isPressed_1) {
      led1.on();
      led1.off();
    btnState1 = isPressed_1;
  if (isPressed_2 != btnState2) {
    if (isPressed_2) {
      led2.on();
      led2.off();
    btnState2 = isPressed_2;
  if (isPressed_3 != btnState3) {
    if (isPressed_3) {
      led3.on();
      led3.off();
    btnState3 = isPressed_3;
  if (isPressed_4 != btnState4) {
    if (isPressed_4) {
      led4.on();
      led4.off();
    btnState4 = isPressed_4;
  if (isPressed_5 != btnState5) {
    if (isPressed_5) {
      led5.on();
      led5.off();
    btnState5 = isPressed_5;
    // Debug console
    // relay
    pinMode(RELAY_PIN_1, OUTPUT);
    pinMode(RELAY_PIN_2, OUTPUT);
    pinMode(RELAY_PIN_3, OUTPUT);
    pinMode(RELAY_PIN_4, OUTPUT);
    digitalWrite(RELAY_PIN_1, HIGH);
    digitalWrite(RELAY_PIN_2, HIGH);
    digitalWrite(RELAY_PIN_3, HIGH);
    digitalWrite(RELAY_PIN_4, HIGH);
    pinMode(wifiLed, OUTPUT);
    WiFi.mode(WIFI_STA);
    delay(200);
        Serial.print(".");
  // Setup physical button pin (active low)
    pinMode(btnPin1, INPUT_PULLUP);
    pinMode(btnPin2, INPUT_PULLUP);
    pinMode(btnPin3, INPUT_PULLUP);
    pinMode(btnPin4, INPUT_PULLUP);
    pinMode(btnPin5, INPUT_PULLUP);
    timer.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 2 seconds
    timer.setInterval(500L, buttonLedWidget);
    Blynk.config(AUTH, "***********************.com", **080);
    BLYNK_WRITE(V20) {
     pinValue = param.asInt();
  Blynk.run();
  timer.run();
no working connect wifi ever again again....
what is the wrong code?
thank you
I'm not sure what all your code does but network connection seems OK.
I suggest you try to delete everything else except WiFi stuff and see if it works (Serial.print something after connection is established, try local IP for example).
