Problem Connecting a 2-Wire Speaker to Arduino Esplora
Hello, I am currently trying to make a small video game system with the Arduino Esplora board, however ran into a bump. I will be using the TFT screen, and the Arduino Esplora does not have normal pins, so I am unsure of how to connect a simple 2-Wire speaker to it. My code is perfectly fine, as it is just a little platformer for now, and the screen is working fine. If anyone knows a workaround or something to do with this, the help would be deeply appreciated.
In general, you cannot connect speakers to digital outputs as the output pin can be damaged. Beware of lots of bad tutorials that do so anyway!
You should use an amplifier of some sort.
jremington:
Ok, will watch out for those.
jremington:
What amplifier are you talking about? Using the upper TinkerKit output pins?
