Problem connecting / getting my GSM shield to do anything
Hi! I’m new to the Arduino world aswell as this forum.
Few days ago I got my Arduino Uno and a GSM shield and I have been trying to set it up. I can get the Arduino to work fine and run a blinking program as intended.
Though all the LEDs are blinking proberbly on my shield I never seem to get any sort of response from it when trying to run the sendSmS test program.
Here is my code:
 SMS sender
 This sketch, for the Arduino GSM shield,sends an SMS message
 you enter in the serial monitor. Connect your Arduino with the
 GSM shield and SIM card, open the serial monitor, and wait for
 the "READY" message to appear in the monitor. Next, type a
 message to send and press "return". Make sure the serial
 monitor is set to send a newline when you press return.
 Circuit:
 * GSM shield
 * SIM card that can send SMS
 created 25 Feb 2012
 by Tom Igoe
 This example is in the public domain.
 http://arduino.cc/en/Tutorial/GSMExamplesSendSMS
// Include the GSM library
#include <GSM.h>
#define PINNUMBER "8025"
// initialize the library instance
GSM gsmAccess(true);
GSM_SMS sms;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Sender");
  Serial.println("TEST1");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    Serial.println("TEST2");
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("TEST3");
      Serial.println("TEST4");
      Serial.println("Not connected");
  Serial.println("TEST5");
  Serial.println("GSM initialized");
  Serial.print("Enter a mobile number: ");
  char remoteNum[20];  // telephone number to send sms
  readSerial(remoteNum);
  Serial.println(remoteNum);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNum);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
  Read input serial
int readSerial(char result[])
  int i = 0;
  while(1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if(inChar!='\r')
        result[i] = inChar;
        i++;
The program seems to be uploaded fine to the Arduino though I get some sort of error message. I don’t know if this means anything is wrong: avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude done.  Thank you.
When running the program on the Arduino I can open the Serial Watcher thingy which gives the following output:
SMS Messages Sender
TEST1
TEST2
Ergo my program seems to be stuck at if(gsmAccess.begin(PINNUMBER)==GSM_READY) and is never getting anywhere.
I don’t have an original GSM Arduino module, but this one:
http://www.geeetech.com/wiki/index.php/Arduino_GPRS_Shield#Indicator_LEDs
I have tried every possible configuration on the shield.
Does anyone have any ideas of what I could try next? I haven’t found anything on Google or on this forum. I have attached some pictures:
Thanks! :slight_smile:
this thing works for me. Remove your GSM Shield first before you upload the sketch or unplug and plug your usb port connecting in your arduino check also the hardware usb ports in device manager be sure it's updated...
try to use this library because the one you use eats a lot of memory.
http://www.gsmlib.org/download.html
Thank you I will try that.
But my SIM card has a PIN. I don’t see a way to pass that PIN like in the Original GSM library. Can you help me with that? :slight_smile:
