Hello! This is my first post regarding my first ever experience with microcontrollers. So far it has been great fun even though I haven’t done anything but make a light blink
Anyway I’m trying to connect my HMC6352 to my Lilypad. I have the data line connected to 4, the timing line to 5, VCC to + and GROUND to -.
I’ve tried variants on what code to use but this is what I have currently:
#include <Wire.h>
int HMC6352Address = 0x42;
// This is calculated in the setup() function
int slaveAddress;
int ledPin = 13;
boolean ledState = false;
byte headingData[2];
int i, headingValue;
// Shift the device’s documented slave address (0x42) 1 bit right
// This compensates for how the TWI library only wants the
// 7 most significant bits (with the high bit padded with 0)
slaveAddress = HMC6352Address >> 1; // This results in 0x21 as the address to pass to TWI
pinMode(ledPin, OUTPUT); // Set the LED pin as output
Wire.begin();
// Flash the LED on pin 13 just to show that something is happening
// Also serves as an indication that we’re not “stuck” waiting for TWI data
ledState = !ledState;
if (ledState) {
digitalWrite(ledPin,HIGH);
digitalWrite(ledPin,LOW);
// Send a “A” command to the HMC6352
// This requests the current heading data
Wire.beginTransmission(slaveAddress);
Wire.send(“A”); // The “Get Data” command
Wire.endTransmission();
delay(10); // The HMC6352 needs at least a 70us (microsecond) delay
// after this command. Using 10ms just makes it safe
// Read the 2 heading bytes, MSB first
// The resulting 16bit word is the compass heading in 10th’s of a degree
// For example: a heading of 1345 would be 134.5 degrees
Wire.requestFrom(slaveAddress, 2); // Request the 2 byte heading (MSB comes first)
i = 0;
while(Wire.available() && i < 2)
headingData = Wire.receive();
- i++;*
_ headingValue = headingData[0]*256 + headingData[1]; // Put the MSB and LSB together_ - Serial.print("Current heading: ");*
- Serial.print(int (headingValue / 10)); // The whole number part of the heading*
- Serial.print(".");*
- Serial.print(int (headingValue % 10)); // The fractional part of the heading*
- Serial.println(" degrees");*
- delay(500);*
The code compiles and uploads OK but the heading is ALWAYS 0.0. It’s like the compass unit isn’t receiving the commands, or it is receiving them but returning nothing. Any ideas? I’m not even sure what my next step should be…I read something about reducing the power from 5V to 3.3V but I’m not sure I’m comfortable doing that just yet if it involves cutting up my Lilypad!
