I can confirm that the faulty data is being sent over the SPI bus (tested with logic analyzer), so I don't think the display is at fault. I'm directly comparing the first bytes of the image array with the first bytes being sent to the display after the proper commands (also verified).
Here is the current image:
As it shows up:
First bit of the image array:
FLASH_ARRAY(unsigned char, test,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
And part of the SPI data stream:
The first bytes on the left are the row and column address commands being sent, followed by a command to enable writing to the RAM. Between the markers are roughly 280 bytes, corresponding to about 565 pixels (just over 2 rows). The first couple dozen bytes of 0xFF followed by a couple hundred bytes of 0x00 matches exactly what is seen on the screen. So the display itself seems to be working as it should, but the data being sent is faulty. If you look at the array, you see it is all 0xFF for a good while at the start.
After this I am confident that something is going on inside the Arduino that I am not understanding.
