Problem converting int to char...
I'm trying to place an int into a char[0]. Looking at this code:
  int a=5;
  char b=a;
  char c='5';
  Serial.print("a isDigit()=");
  Serial.println(isDigit(a));
  Serial.print("b isDigit()=");
  Serial.println(isDigit(b));
  Serial.print("c isDigit()=");
  Serial.println(isDigit(c));
  Serial.println("---");
I'm trying to place the int a into the char[0] b, and have the results be the same as if I wrote:
char b='5';
When done, it should evaluate true to isDigit().
I know that's a confusing description, let me know if that's not clear, and thanks for any help.
int anInt = 5;
char aChar;
  aChar = anInt + 48;
  Serial.print(aChar);
  Serial.println(isDigit(aChar) ? " is a digit" : " is not a digit");
Why add 48? Would it not make more sense to add ‘0’? I know it’s the same but it makes the intent a little clearer.
sterretje:
Why add 48? Would it not make more sense to add '0'? I know it's the same but it makes the intent a little clearer.
I am not convinced that it makes the intent any clearer. Perhaps a variable named asciiOffset with a value of 48 would make it clearer.
In any case, I suspect that the OP has bigger problems such as when he refers to placing the into
the char[0] b
