Problem creating a log file header
Hi I'm trying to make a temperature logger though struggling to get a header automatically added to my csv files!
For some reason (beyond me!) I can log data to a csv file though can't initially add the headers.
Therm_temp_logger.ino (2.57 KB)
You must write the header just after opening a NEW file
robtillaart:
I thought I had done that in my sketch! Can you advise further please?
//Write Log File Header
  File logFile = SD.open("LOG.csv, FILE_WRITE");
  if (logFile)
    logFile.println(", ,");  //Just a leading blank line, incase there was previous data
    logFile.println("ID, Temp1");
    logFile.close();
    Serial.println("ID, Temp1");
    Serial.println("buggered");
some hints ..
  analogReference(EXTERNAL);
  delay(10000);
  Serial.println("Initializing Card");
  //CS Pin is an output
  pinMode(CS_pin, OUTPUT);
  //Check if card ready
  if(!SD.begin(CS_pin))
    Serial.println("Card Failure");
    return;   //////////////////////////////  will continue with loop!
  Serial.println("Card Ready");
  bool newfile = SD.exists("LOG.csv");  // something like this
  if (logFile)
    if (newfile)
       logFile.println("ID, Temp1, Temp2");
      logFile.println(", , ");
    logFile.close();
    Serial.println("Couldn't open log file");
robtillaart:
some hints ..
Unfortunately I'm still receiving:-
Initializing Card
Card Ready
1, 22
2, 22
3, 22
replace
with
File logFile = SD.open("LOG.csv", FILE_WRITE);
robtillaart:
replace
with
God how simple a mistake! Thanks, your a life saver! If only I could of asked you that 4 hours ago lol
I didn't see it in the first quick look either :wink:
