Hi I recently bought a DFR robot CO2 sensor Infrared_CO2_Sensor_0-50000ppm_SKU__SEN0220-DFRobot This was all good and I was able to get a simple code running and get the data displayed on the serial monitor. but my project idea was to store this data on SD card and use a battery so the computer does not have to attached. I found a simple data-logger example in the Arduino software and started to work on it, but I found this hard because the sensor doesn't seem to use there same sort of data string as other sensor code. I also found the sensor uses digital pins unlike most other sensors I have seen.
It would be greatly appreciated if anyone could show me how form this data-logger code.
these are the two codes.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
unsigned char hexdata[9] = {0xFF,0x01,0x86,0x00,0x00,0x00,0x00,0x00,0x79}; //Read the gas density command /Don't change the order
while (!Serial) {
mySerial.begin(9600);
mySerial.write(hexdata,9);
for(int i=0,j=0;i<9;i++)
if (mySerial.available()>0)
long hi,lo,CO2;
int ch=mySerial.read();
if(i==2){ hi=ch; } //High concentration
if(i==3){ lo=ch; } //Low concentration
if(i==8) {
CO2=hi*256+lo; //CO2 concentration
Serial.print("CO2 concentration: ");
Serial.print(CO2);
Serial.println("ppm");
and
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
