hello I’m trying to adapt the example code from “https://www.arduinoall.net/arduino-tutor/code/rfid_buzzer.rar”
and in the example look like this
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 9
RFID rfid(SS_PIN, RST_PIN);
// Setup variables:
int serNum0;
int serNum1;
int serNum2;
int serNum3;
int serNum4;
SPI.begin();
rfid.init();
if (rfid.isCard()) {
if (rfid.readCardSerial()) {
if (rfid.serNum[0] != serNum0
&& rfid.serNum[1] != serNum1
&& rfid.serNum[2] != serNum2
&& rfid.serNum[3] != serNum3
&& rfid.serNum[4] != serNum4
/* With a new cardnumber, show it. */
Serial.println(" ");
Serial.println(“Card found”);
serNum0 = rfid.serNum[0];
serNum1 = rfid.serNum[1];
serNum2 = rfid.serNum[2];
serNum3 = rfid.serNum[3];
serNum4 = rfid.serNum[4];
//Serial.println(" ");
Serial.println(“Cardnumber:”);
Serial.print("Dec: “);
Serial.print(rfid.serNum[0],DEC);
Serial.print(”, “);
Serial.print(rfid.serNum[1],DEC);
Serial.print(”, “);
Serial.print(rfid.serNum[2],DEC);
Serial.print(”, “);
Serial.print(rfid.serNum[3],DEC);
Serial.print(”, “);
Serial.print(rfid.serNum[4],DEC);
Serial.println(” ");
Serial.print(“Hex: “);
Serial.print(rfid.serNum[0],HEX);
Serial.print(”, “);
Serial.print(rfid.serNum[1],HEX);
Serial.print(”, “);
Serial.print(rfid.serNum[2],HEX);
Serial.print(”, “);
Serial.print(rfid.serNum[3],HEX);
Serial.print(”, “);
Serial.print(rfid.serNum[4],HEX);
Serial.println(” “);
/* If we have the same ID, just write a dot. */
Serial.print(”.”);
rfid.halt();
I’m trying to move the code inside loop to create a function and call the function instead but it doesn’t work
the other problems is I’m using 16-channels MUX to control 16 RFID and it doesn’t work too. Even I put the reading code inside loop
