Hi, I'm new on Arduino projects and after long hours trying I´ve not been capable to accomplish the code work so would like some help, please.
The project is a 6 Servo motor based robotic arm to be controlled through a website.
I´ve based my project from https://create.arduino.cc/projecthub/phpoc_man/arduino-control-arm-robot-via-web-379ef3
This is the code that I'm using but it gives back a wrong compilation message: conversion from 'int' to 'arduino::String' is ambiguous
Could anyone help with that?
Thanks in advance!
#include <Servo.h>
#include <SPI.h>
#include <WiFiNINA.h>
char ssid[] = "";
char pass[] = "";
int angle_init[] = {90, 101, 165, 153, 90, 120}; // when motor stands straight. In web, the angle when motor stands straight is {0, 90, 130, 180, 0, 0};
int angle_offset[] = {0, 11, -15, -27, 0, 137}; // offset between real servo motor and angle on web
int cur_angles[] = {90, 101, 165, 153, 90, 120}; // current angles of six motors (degree)
int dest_angles[] = {0, 0, 0, 0, 0, 0}; // destined angles
int angle_max[] = {180, 180, 160, 120, 180, 137};
int angle_min[] = { 0, 0, 0, 20, 0, 75};
int direction[] = {1, 1, 1, 1, 1 ,-1};
int angleSteps[] = {3, 2, 2, 2, 4 ,4}; // moving steps of each motor (degree)
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Servo servo[6] = {servo1, servo2, servo3, servo4, servo5, servo6};
int status = WL_IDLE_STATUS;
WiFiServer server(80);
int stepNum = 0;
//start serial communication
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
delay(10000);
server.begin();
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
servo1.attach(2); // attaches the servo on pin 2 to the servo object
servo2.attach(3); // attaches the servo on pin 3 to the servo object
servo3.attach(4); // attaches the servo on pin 4 to the servo object
servo4.attach(5); // attaches the servo on pin 5 to the servo object
servo5.attach(6); // attaches the servo on pin 6 to the servo object
servo6.attach(7); // attaches the servo on pin 7 to the servo object
for(int i = 0; i < 6; i++)
servo[i].write(angle_init[i]);
WiFiClient client = server.available(); // Listen for incoming clients
if(client) {
String angleStr = client.read();
if(angleStr) {
Serial.println(angleStr);
int commaPos1 = -1;
int commaPos2;
for(int i = 0; i < 5; i++) {
commaPos2 = angleStr.indexOf(',', commaPos1 + 1);
int angle = angleStr.substring(commaPos1 + 1, commaPos2).toInt();
dest_angles[i] = angle * direction[i] + angle_offset[i];
commaPos1 = commaPos2;
int angle5 = angleStr.substring(commaPos1 + 1).toInt();
dest_angles[5] = angle5 * direction[5] + angle_offset[5];
stepNum = 0;
// move motors in many small steps to make motor move smooth, avoiding move motor suddently. The below is step calculation
for(int i = 0; i < 6; i++) {
int dif = abs(cur_angles[i] - dest_angles[i]);
int step = dif / angleSteps[i];
if(stepNum < step)
stepNum = step;
// move motors step by step
if(stepNum > 0) {
int angleStepMove = (dest_angles[i] - cur_angles[i]) / stepNum;
cur_angles[i] += angleStepMove;
if(cur_angles[i] > angle_max[i])
cur_angles[i] = angle_max[i];
else if(cur_angles[i] < angle_min[i])
cur_angles[i] = angle_min[i];
servo[i].write(cur_angles[i]);
stepNum--;
delay(20);
