Problem DFPlayer Mini + Accel
I need help to get my project running.
My project is playing a mp3 with DFPlayer Mini after detecting acceleration. I use arduino uno. Volume is controlled by an poti. In order to fit all into a box a protoshield is used.
Error is following
11:06:24.451 -> ADXL345 is connected!
11:06:24.451 ->
11:06:24.451 -> DFRobot DFPlayer Mini Demo
11:06:24.483 -> Initializing DFPlayer ... (May take 3~5 seconds)
11:06:25.190 ->
11:06:25.190 -> 1.Please recheck the connection!
11:06:25.222 -> 2.Please insert the SD card!
DFPlayer is not defect. I tested it separately.
// Ausgabe an serielle Konsole
#define verbose 1
// ADXL345 Accelerator
#include<Wire.h>
#include<ADXL345_WE.h>
#define ADXL345_I2CADDR 0x53
/* There are several ways to create your ADXL345 object:
 * ADXL345_WE myAcc = ADXL345_WE()                -> uses Wire / I2C Address = 0x53
 * ADXL345_WE myAcc = ADXL345_WE(ADXL345_I2CADDR) -> uses Wire / ADXL345_I2CADDR
 * ADXL345_WE myAcc = ADXL345_WE(&wire2)          -> uses the TwoWire object wire2 / ADXL345_I2CADDR
 * ADXL345_WE myAcc = ADXL345_WE(&wire2, ADXL345_I2CADDR) -> all together
ADXL345_WE myAcc = ADXL345_WE(ADXL345_I2CADDR);
int isMoving();
// DFPlayer - A Mini MP3 Player For Arduino
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#define busyPin 10
SoftwareSerial mySoftwareSerial(12, 13); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
int isplaying = 0;
int ismoving = 0;
int numsong;
int AnzahlDateien;
int isPlaying();
// constants won't change:
// interval at which to play without acc (milliseconds)
const long interval = 20000;
// Lautstärke über Potentiometer
int Poti = A0;
int laut_raw;
int laut_new;
int laut = 20;
void setVolume();
  mySoftwareSerial.begin(9600);
  // ADXL345
  Wire.begin();
  if(!myAcc.init())
    Serial.println("ADXL345 not connected!");
    while(1);
    Serial.println("ADXL345 is connected!");
    isMoving();
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  // Nummer des Ordners, der Ordner muss Daten enthalten
  int Ordner = 1;
  // Anzahl der Dateien im Ordner feststellen und anzeigen
  AnzahlDateien = myDFPlayer.readFileCountsInFolder(Ordner);
  // wenn sich im Ordner keine Daten befinden
  if (AnzahlDateien == -1)
    Serial.println("Der Ordner enth\u00e4lt keine Musikdateien!");
    Serial.println("Das Programm wird beendet!");
    while(1);
    Serial.print(String(AnzahlDateien) + " Dateien im Ordner " + String(Ordner));
  // DFPLayer starten und pausieren
  pinMode(busyPin, INPUT);
  // Zusätzlich LED verwenden
  // LED ist an, wenn istplaying
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  unsigned long lastacc;
  // Warten
  delay(100);
  ismoving  = isMoving();
  isplaying = isPlaying();
  if (verbose)
  int static tmp1 = -1;
  int static tmp2 = -1;
  if (ismoving != tmp1 || isplaying != tmp2)
      Serial.print(" ismoving ");
      Serial.print(ismoving);
      Serial.print(" isplaying ");
      Serial.println(isplaying);
      tmp1 = ismoving;
      tmp2 = isplaying;
  // Sensor bewegt, Zeitstempel setzen
   if (ismoving){ lastacc = millis(); }
  // Sensor bewegt, dann Musik
  if (ismoving && !isplaying){
    numsong = random(1, AnzahlDateien);
    if (verbose)
      Serial.print(" numsong ");
      Serial.println(numsong);
    myDFPlayer.play(numsong);
    lastacc = millis();
// es spielt, dann Lautstärke setzen
if (isplaying)
    setVolume();
    // myDFPlayer.volume(laut);
    digitalWrite(LED_BUILTIN, HIGH);
  // Sensor ruht und spielt
  if (!ismoving && isplaying)
    if (millis() - lastacc >= interval)
      FadingOut();
int isPlaying()
  static unsigned long lastcheck = -1;
  int isplaying;
  int intervall = 200;
  lastcheck = millis();
  if (millis() - lastcheck <  intervall)
    isplaying = !digitalRead(busyPin);
  return isplaying;
int isMoving()
  xyzFloat raw;
  int diff;
  int diffx;
  int diffy;
  int diffz;
  static int oldx = 0;
  static int oldy = 0;
  static int oldz = 0;
  // Status ADXL345
  raw = myAcc.getRawValues();
  diffx = oldx - raw.x;
  diffy = oldy - raw.y;
  diffz = oldz - raw.z;
  oldx = raw.x;
  oldy = raw.y;
  oldz = raw.z;
  diff  = sqrt(diffx * diffx + diffy + diffy + diffz * diffz);
  if (diff >= 20)
  { return 1; }
  { return 0; }
void setVolume() {
  const int laut_max = 30;
  static int potval_old = -1;
  int potval, laut;
  // ständiges Setzen der Lautstärke verursacht
  // Knacken im Lautsprecher; Ursache Verstärkung
  // serieller TX/RX durch DFPlayer Amp, was stört
  potval = analogRead(Poti);
  delay(200);
  // Wert von laut kann flackern
  // daher nur Änderungen > 1
  if (abs(potval - potval_old) > 10)
    laut = map(potval, 0, 1023, 0, laut_max);
    potval_old = potval;
    if (verbose)
      Serial.print("Wert vom Poti : ");
      Serial.println(potval);
      Serial.print("Lautstaerke : ");
      Serial.println(laut);
void FadingOut() {
  const int steps = 5;
  const int wait  = 200;
  int potval, laut;
  Serial.println("Fading out : ");
  for (int i = laut; i >= 0; i -= laut / steps)
    Serial.println(i);
    myDFPlayer.volume(i);
    delay(wait);
  myDFPlayer.volume(0);
  myDFPlayer.stop();
Wiring and a picture of setup
Any idea? Wrong wiring?
Better resolution
Try swapping 12 and 13.
Arduino Rx goes to DFPlayer Tx etc
Thanks!
This was the point despite a loose connection.
