Good evening! I need help with this problem.
I have a little problem with my project, I'm new at this so from now on, I apologize if the code is messy and buggy. I'm still learning:D
My project is simple, it consists of a program that turns on a water pump, when certain conditions are met according to the humidity, light and rain sensors.
The problem that arose when I tried to include an LCD screen to the project.
I want to show the values that the sensors register in the lcd 16x2. To make it a little more fun I included a small animation at the beginning, what I wanted to achieve in the lcd screen was the following:
*- Have a fun animation displayed at startup.
- Then show an interface where the values recorded by the three sensors are shown and S.R = OFF/ON, to represent if the system is active or not..
My problem arose at the time when the values are printed on the LCD, because as I am working with numbers from 0 to 100, when it reaches 100 and then marks a value less than this, some characters remain on the screen (attached an image of how the error looks and the respective code).
Thank you very much in advance for your answer.
Un saludo, que tengan un buen día:D
Error: Description (As you can see, in the image there are some characters that I do not want, such as the "%%" that are in excess, and it only happens when the value recorded by the sensors gets to work with two digits -increases one more "%"-, or when it reaches 100, i.e. when the sensor records a value of three digits -increases two "%%"-)
Code: (I know there are variables declared unnecessarily, I am still in the process of testing, that's why you will see some things that don't make sense, I have been trying possible solutions but no help yet)
// libreria para pantalla lcd
#include <LiquidCrystal.h>
//Declaramos los pines para la lcd
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
//ANIMACIÓN DE ENTRADA
// Reloj de Arena
byte load1[8] = {
B01111,
B01101,
B00100,
B00100,
B00110,
B00011,
B00001,
B00000
byte load2[8] = {
B11111,
B01010,
B10101,
B01010,
B00100,
B00000,
B10101,
B11011
byte load3[8] = {
B11110,
B10110,
B00100,
B00100,
B01100,
B11000,
B10000,
B00000
byte load4[8] = {
B00000,
B00001,
B00011,
B00110,
B00100,
B00100,
B01100,
B01111
byte load5[8] = {
B11011,
B10001,
B00100,
B00000,
B00000,
B00000,
B00000,
B11111
byte load6[8] = {
B00000,
B10000,
B11000,
B01100,
B00100,
B00100,
B00110,
B11110
//////////// fin pre-load //////////////
///////// animacion 1 ////////////////
byte load1a[8] = {
B01111,
B01100,
B00100,
B00100,
B00110,
B00011,
B00001,
B00000
byte load2a[8] = {
B11111,
B01010,
B10101,
B01010,
B00100,
B00000,
B10001,
B11011
byte load5a[8] = {
B11011,
B10101,
B00000,
B00000,
B00000,
B00000,
B01000,
B11111
/////////////////ani2/////////
byte load2b[8] = {
B11111,
B01000,
B10101,
B01010,
B00100,
B00000,
B10101,
B11011
byte load5b[8] = {
B11011,
B10001,
B00100,
B00000,
B00000,
B00000,
B01010,
B11111
///////////ani3//////////////
// load1a
byte load2c[8] = {
B11111,
B01000,
B10101,
B01010,
B00100,
B00000,
B10001,
B11011
byte load3c[8] = {
B11110,
B00110,
B00100,
B00100,
B01100,
B11000,
B10000,
B00000
byte load5c[8] = {
B11011,
B10101,
B00000,
B00000,
B00000,
B00100,
B01010,
B11111
////////// ani4////////////
byte load2d[] = {
B11111,
B00000,
B10101,
B01010,
B00100,
B00000,
B10101,
B11011
byte load5d[8] = {
B11011,
B10001,
B00100,
B00000,
B00000,
B00100,
B01010,
B11111
byte load6d[8] = {
B00000,
B10000,
B11000,
B01100,
B00100,
B00100,
B10110,
B11110
////////ani 5 ////////
byte load2e[8] = {
B11111,
B00000,
B10001,
B01010,
B00100,
B00000,
B10001,
B11011
byte load5e[8] = {
B11011,
B10101,
B00000,
B00000,
B00000,
B10100,
B01010,
B11111
//////// ani6 ///////
byte load2f[8] = {
B11111,
B00000,
B00001,
B01010,
B00100,
B00000,
B10101,
B11011
byte load4f[8] = {
B00000,
B00001,
B00011,
B00110,
B00100,
B00100,
B01101,
B01111
byte load5f[8] = {
B11011,
B10001,
B00100,
B00000,
B00000,
B10100,
B01010,
B11111
/////// ani7 /////////
byte load2g[8] = {
B11111,
B00000,
B00000,
B01010,
B00100,
B00000,
B10001,
B11011
byte load5g[8] = {
B11011,
B10101,
B00000,
B00000,
B00000,
B10101,
B01010,
B11111
///////ani8//////////
byte load2h[8] = {
B11111,
B00000,
B00000,
B01000,
B00100,
B00000,
B10101,
B11011
byte load5h[8] = {
B11011,
B10001,
B00100,
B00000,
B00010,
B10101,
B01010,
B11111
///////// ani 9 //////
byte load2i[8] = {
B11111,
B00000,
B00000,
B00000,
B00100,
B00000,
B10101,
B11011
byte load5i[8] = {
B11011,
B10001,
B00100,
B00000,
B01010,
B10101,
B01010,
B11111
////////ani10/////////
byte load2j[8] = {
B11111,
B00000,
B00000,
B00000,
B00000,
B00000,
B10001,
B11011
byte load5j[8] = {
B11011,
B10101,
B00000,
B00100,
B01010,
B10101,
B01010,
B11111
///////giro1////
byte giro1[8] = {
B11000,
B10000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte giro2[8] = {
B10000,
B01000,
B00100,
B00100,
B00100,
B00100,
B00110,
B00011
byte giro3[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11110
byte giro4[8] = {
B01111,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
byte giro5[8] = {
B10000,
B11000,
B01000,
B01010,
B01001,
B01010,
B00101,
B00010
byte giro6[8] = {
B00001,
B00000,
B00000,
B10101,
B01010,
B00100,
B01001,
B10010
/// giro2///
byte giro1a[8] = {
B00000,
B00000,
B11000,
B11110,
B10011,
B10000,
B10000,
B10000
byte giro2a[8] = {
B00000,
B00000,
B00000,
B00001,
B10011,
B11110,
B01100,
B00000
byte giro3a[8] = {
B00000,
B00011,
B01111,
B11001,
B10011,
B00001,
B00011,
B00001
byte giro4a[8] = {
B10000,
B10000,
B10001,
B10011,
B11110,
B11000,
B00000,
B00000
byte giro5a[8] = {
B01100,
B11110,
B10011,
B00001,
B00000,
B00000,
B00000,
B00000
byte giro6a[8] = {
B01011,
B00101,
B10011,
B11101,
B01011,
B00111,
B00000,
B00000
///// giro3///
byte giro1b[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B01111
byte giro2b[8] = {
B00001,
B00010,
B00100,
B00100,
B00100,
B00100,
B01100,
B11000
byte giro3b[8] = {
B00011,
B00001,
B00000,
B00101,
B01010,
B10101,
B01010,
B10101
byte giro4b[8] = {
B11000,
B10000,
B00000,
B00000,
B00000,
B00000,
B00001,
B10011
byte giro5b[8] = {
B00011,
B00110,
B00100,
B00100,
B00100,
B00100,
B01000,
B10000
byte giro6b[8] = {
B11110,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000
int tiempo = 250;
int t = 100;
// AQUÍ ACABA ANIMACIÓN DE ENTRADA
//Declaramos variables para el funcionamiento del sistema de riego
int pin_bomba = 8;
int pin_sensor_luz = A0;
int pin_sensor_humedad = A1;
int pin_sensor_lluvia = A2;
int ultima_distancia_L = 0;
int ultima_distancia_H = 0;
int ultima_distancia_LL = 0;
//Para el lcd
// Definimos las dimensiones de la pantalla
lcd.begin(16, 2);
//Definimos las salidas para los pines
pinMode(pin_bomba, OUTPUT);
pinMode(pin_sensor_luz, INPUT);
pinMode(pin_sensor_humedad, INPUT);
pinMode(pin_sensor_lluvia,INPUT);
letras();
for(int i = 0; i<4; i++){
preLoad();
lcd.clear();
//Variables para guardar los datos recibidos por los sensores
int cantidad_luz = analogRead(pin_sensor_luz); // leemos y guardamos la entrada del sensor de luz
int cantidad_luz_porcentaje = map(cantidad_luz, 0, 679, 0, 100); //convertimos la cantidad de luz en porcentaje:D
int humedad = analogRead(pin_sensor_humedad); // leemos y guardamos la entrada del sensor de humedad
int humedad_porcentaje = map(humedad, 0, 1023, 0, 100); //convertimos la cantidad de humedad en porcentaje:D
int lluvia = analogRead(pin_sensor_lluvia); // leemos y guardamos la entrada del sensor de lluvia
int lluvia_porcentaje = map(lluvia, 0, 1023, 0, 100); //convertimos la cantidad de lluvia detectada en porcentaje:D
// PARA EL LCD
lcd.setCursor(0, 0);
lcd.print("LUZ:");
lcd.print(cantidad_luz_porcentaje);
lcd.print("%");
lcd.setCursor(0, 1);
lcd.print("HUM:");
lcd.print(humedad_porcentaje);
lcd.print("%");
lcd.setCursor(9, 0);
lcd.print("LL:");
lcd.print(lluvia_porcentaje);
lcd.print("%");
ultima_distancia_H = humedad_porcentaje;
ultima_distancia_L = cantidad_luz_porcentaje;
ultima_distancia_LL = lluvia_porcentaje;
delay(100);
//CONDICIONES DE RIEGO -- CEREBRO DEL PROGRAMA!
// + Se regará siempre y cuando sea de noche (sensor ldr menor al 30%)
// + Se regará siempre y cuando exista una humedad del suelo inferior al 50%
// + Se regará siempre y cuando el sensor de lluvia registre un número inferior del 15%
// En caso no se cumplan con las tres condiciones
// El sistema no regará 7u7
if (cantidad_luz_porcentaje < 30 && humedad_porcentaje < 50 && lluvia_porcentaje < 15){
digitalWrite(pin_bomba, HIGH); // Se enciende la bomba de agua
lcd.setCursor(9, 1);
lcd.print("SR:ON");
digitalWrite(pin_bomba, LOW); // Se apaga la bomba de agua
lcd.print("SR:OFF");
void letras()
for (int a=15; a>=6;a--)
lcd.clear();
lcd.setCursor(a,0);
lcd.print("Sistema");
lcd.setCursor(a,1);
lcd.print("De Riego");
delay(100);
// Animación del reloj de arena que actua como un pre-load
// Se van sobrescribiendo los caracteres creados en cada fotograma.
void preLoad()
lcd.createChar(0,load1);
lcd.createChar(1,load2);
lcd.createChar(2,load3);
lcd.createChar(3,load4);
lcd.createChar(4,load5);
lcd.createChar(5,load6);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(0,load1a);
lcd.createChar(1,load2a);
lcd.createChar(4,load5a);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2b);
lcd.createChar(4,load5b);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2c);
lcd.createChar(2,load3c);
lcd.createChar(4,load5c);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2d);
lcd.createChar(4,load5d);
lcd.createChar(5,load6d);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2e);
lcd.createChar(4,load5e);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2f);
lcd.createChar(3,load4f);
lcd.createChar(4,load5f);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2g);
lcd.createChar(4,load5g);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2h);
lcd.createChar(4,load5h);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2i);
lcd.createChar(4,load5i);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(1,load2j);
lcd.createChar(4,load5j);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(0,giro1);
lcd.createChar(1,giro2);
lcd.createChar(2,giro3);
lcd.createChar(3,giro4);
lcd.createChar(4,giro5);
lcd.createChar(5,giro6);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(0,giro1a);
lcd.createChar(1,giro2a);
lcd.createChar(2,giro3a);
lcd.createChar(3,giro4a);
lcd.createChar(4,giro5a);
lcd.createChar(5,giro6a);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
lcd.createChar(0,giro1b);
lcd.createChar(1,giro2b);
lcd.createChar(2,giro3b);
lcd.createChar(3,giro4b);
lcd.createChar(4,giro5b);
lcd.createChar(5,giro6b);
lcd.setCursor(2,0);
lcd.write(byte(0));
lcd.write(1);
lcd.write(2);
lcd.setCursor(2,1);
lcd.write(3);
lcd.write(4);
lcd.write(5);
delay(t);
