I've been spending in vain my last days to get the Libellium GPRS Shield (bought mid of March) with my Arduino boards running. I followed and tested all instructions on http://www.libelium.com/squidbee/index.php?title=New_GPRS_module_for_Arduino_(Hilo_-_Sagem) [soldered a 220uF capacitor, have been able to make use of a second arduino to eavesdrop the serial communication, trying the stand alone and usb variant] and couldn't get a response from the shield.
While I can measure that the shield is powered (4.99V on the voltage reg) it seems that it can't be switched on - neither with the button nor programatically (i didn't forget to change the jumper). I haven't been able to get any serial response from the shield.
I've got two GPRS shields and don't believe that both are broken. Making me believe that I might do something wrong. Has anyone experienced the same or some tipss?
Jumper set to Arduino 5V
Result
o Pressing on for 2s does not result in any PSSK greeting message
o I can issue at which returns OK
o I cannot pass AT+CPIN=”****” – it usually dies after max an additional AT
Case 2: External Powered
Power supply feeds shield (via Arduino board)
Measured 5V at the base of capacitor
Jumpers still set to USB gateway (so I can talk to it)
Jumper set to V Ext.
Result
o Pressing on for 2s does nothing at all (no greeting)
o Cannot talk to the shield using Putty/serial at all - zip - nada - nothing
The switch on the GPRS is a tiny push-down button. I have no reason to assume it's defect. Is that switch defect?
