Hi guys, I am a beginner in programming and I have been trying to create my own library for controlling a four digit seven segment display. The problem is that when I was trying to import the library and create an instance from the class from the library in trial.ino, the compiler gave me an error message
trial:3: error: expected initializer before ‘Display’
Four_dig_7_seg_display Display;
C:\Users\XXX\Documents\Arduino\Sketches\clock_humidity_temp_gadget\trial\trial.ino: In function ‘void loop()’:
trial:11: error: ‘Display’ was not declared in this scope
Display.displayNum();
Using library four_dig_7_seg_display in folder: C:\Users\XXX\Documents\Arduino\Sketches\clock_humidity_temp_gadget\trial\libraries\four_dig_7_seg_display (legacy)
exit status 1
I was not able to find any problems with my codes in my library. I would really appreciate if somebody could help me out on my codess. Thanks very muchhhh:)
four_digit_7_seg_display.cpp
#include "Arduino.h"
#include "four_dig_7_seg_display.h"
Four_dig_7_seg_display::Four_dig_7_seg_display(int A, int B, int C, int D, int E, int F, int G, int H, int I, int J, int K, int L, int displayNumber) {
int i = 1;
while (i << 14) {
pinMode (i, OUTPUT);
digitalWrite(i,LOW);
i++;
pinA = A;
pinB = B;
pinC = C;
pinD = D;
pinE = E;
pinF = F;
pinG = G;
pinDP = H;
d1 = I;
d2 = J;
d3 = K;
d4 = L;
_displayNumber = displayNumber;
void Four_dig_7_seg_display::displayNum () {
switch (digit(_displayNumber)){
case 1:
digitalWrite(d1,LOW);
digitalWrite(d2,HIGH);
digitalWrite(d3,LOW);
digitalWrite(d4,LOW);
select(_displayNumber);
delay(10);
nth();
digitalWrite(d1,HIGH);
digitalWrite(d2,LOW);
C();
delay(10);
nth();
case 2:
select(_displayNumber%10);
delay(10);
nth();
digitalWrite(d3,HIGH);
select((_displayNumber-_displayNumber%10)/10);
delay(10);
nth();
C();
delay(10);
nth();
case 3:
delay(10);
nth();
select((_displayNumber%100-_displayNumber%10)/10);
delay(10);
nth();
digitalWrite(d4,HIGH);
select((_displayNumber-_displayNumber%100)/100);
delay(10);
nth();
C();
delay(10);
nth();
default: break;
int Four_dig_7_seg_display::digit(int num) {
if (num/10 < 1) {
return 1;
if(num/10<10) {
return 2;
{if(num/10<100) {
return 3;
else {return 0;}
void Four_dig_7_seg_display::select(int i) {
switch (i) {
case 1: one(); break;
case 2: two(); break;
case 3: three(); break;
case 4: four(); break;
case 5: five(); break;
case 6: six(); break;
case 7: seven(); break;
case 8: eight(); break;
case 9: nine(); break;
case 0: zero(); break;
default: break;
void Four_dig_7_seg_display::one(void) {
digitalWrite(pinB,HIGH);
digitalWrite(pinC,HIGH);
digitalWrite(pinA,LOW);
digitalWrite(pinD,LOW);
digitalWrite(pinE,LOW);
digitalWrite(pinF,LOW);
digitalWrite(pinG,LOW);
digitalWrite(pinDP,LOW);
void Four_dig_7_seg_display::two() {
digitalWrite(pinA,HIGH);
digitalWrite(pinC,LOW);
digitalWrite(pinD,HIGH);
digitalWrite(pinE,HIGH);
digitalWrite(pinG,HIGH);
void Four_dig_7_seg_display::three() {
void Four_dig_7_seg_display::four() {
digitalWrite(pinF,HIGH);
void Four_dig_7_seg_display::five() {
digitalWrite(pinB,LOW);
void Four_dig_7_seg_display::six() {
void Four_dig_7_seg_display::seven() {
void Four_dig_7_seg_display::eight() {
void Four_dig_7_seg_display::nine() {
void Four_dig_7_seg_display::zero() {
void Four_dig_7_seg_display::nth() {
void Four_dig_7_seg_display::C() {
digitalWrite(pinDP,HIGH);
#ifndef four_dig_7_seg_display_h
#define four_dig_7_seg_display_h
class Four_dig_7_seg_display
public:
Four_dig_7_seg_display(int A, int B, int C, int D, int E, int F, int G, int H, int I, int J, int K, int L, int displayNumber);
void displayNum();
private:
int i;
int pinA; // 6
int pinB; //7
int pinC; //8
int pinD; //9
int pinE; //10
int pinF; //11
int pinG; //12
int pinDP; //13
int d1; //5
int d2; //4
int d3; //3
int d4; //2
void one();
void two();
void three();
void four();
void five();
void six();
void seven();
void eight();
void nine();
void zero();
void nth();
void C();
void select(int i);
int digit (int num);
int _displayNumber; ;
#endif
trial.ino
#include <four_dig_7_seg_display.h>
Thanks very muchhhh :))))
