Problem error In function 'void loop()': 57:9: error: expected primary-expression before ')' token exit status 1
i have been trying to fix this for a whole hour and i couldnt . im a begginer and im trying to make a keyboard using arduino that can write a and b
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  pinMode(10,INPUT);
  pinMode(9,INPUT);
  if(digitalRead(10)==HIGH){
    lcd.print("a");
  }else(){if(digitalRead(9)==HIGH){
    lcd.print("b");
  }else(){
    lcd.clear();}
the error is here }else(){if(digitalRead(9)==HIGH){
please help
What's this do?
i think its one of the pre-made command for c++ that if the answer wasnt true then it will run another if command . i i did it for if the a key didnt get pressed it checks if b key is pressed
if (condition) {
    // block of code if condition is true
else {
    // block of code if condition is false
Does your C++ implementation of an else match the pasted syntax?
no its
if (condition) {
 else (no condition here){
    lcd.print("a");
  }else{if(digitalRead(9)==HIGH){
    lcd.print("b");
  }else{
    lcd.clear();}
Try that.
ok im doing it
thank u very much !!!! it worked
The ( and ) is not needed in the else of an if else
if (number >= 0) {
        cout << "You entered a positive integer: " << number << endl;
    else {
        cout << "You entered a negative integer: " << number << endl;
    cout << "This line is always printed.";
I knew it would work.
It is personal choice but I find that putting each { and } on its own line and always using them with conditional statements makes the code block for each condition much clearer, particularly when the conditions are nested
  if (digitalRead(10) == HIGH)
    lcd.print("a");
    if (digitalRead(9) == HIGH)
      lcd.print("b");
      lcd.clear();
Yea, I like breaking out the { and } as well.
void fScreenBlanking( void *pvParameters )
  int       TimeOfPause = 10000 * 1000;
  uint64_t  PauseStartTime = esp_timer_get_time();
  bool      Pause = false;
  const int brightness = 250;
  int       countUpDown = brightness;
  for ( ;; )
    if (!Pause )
      //if motion detect then show display otherwise blank display
      if ( !(gpio_get_level( GPIO_NUM_27)) )
        for ( countUpDown; countUpDown-- > 0; )
          ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
          vTaskDelay( 7 );
        Pause = true;
        ledcWrite( 4, brightness );
      // still detecting movement reset blanking pause time
      if ( gpio_get_level( GPIO_NUM_27) )
        PauseStartTime = esp_timer_get_time(); // extend pause blanking time
      if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
        Pause = false;
    vTaskDelay( 250 );
  vTaskDelete( NULL );
} //void fScreenBlanking( void *pvParameters )
Except when you don't :grinning:
