Problem ethernet connection and access to the results of scripts
hello,
I use Arduino for a week and I can not move. Everything concerning the upload script c on the map works very well working with LED too, but everything related to the network, ie out of the map and contact a server on my intranet does not work .
Note that I have a map Yun.
To give you a very simple example I used an example script "DhcpAddressPrinter." But the only answer I get the debugging console after uploaded the script is as follows:
Unable to connect, try again (1) ...
Unable to connect, try again (2) ...
Unable to connect, try again (3) ...
Unable to connect, try again (4) ...
Unable to connect: the sketches he uses the bridge?
I tried several other such as "WebClient" or "WebServer", setting the mac of the card and its internal IP address, with or without subnet mask and (or) gateway.
I do not understand anything.
My second problem is that I can not access it through my web browser to the results of my scripts c (html code returned by the println command). What address should I enter in the browser to access scripts loaded onto the card ???? When I type the ip I go smoothly to the administration interface of the card, but that's all.
All the examples I've found on the internet to not give me the answer.
Thank you for your help
